Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
Pool heater won't heat water
Model number LX400N. Natural gas. No error code shows. When the heater is turned on by selecting either pool or spa, the fan goes on and stays on. The temperature guage shows the set temp and the current water temp. Everything appears to be working but no hot water.
  • 5 more comments
  • TMay Jan 22, 2013
    prior, spa heated in 1 hour (55deg to 101deg). now no temp change in 2 hrs.
  • Mike Tellegen Jan 23, 2013
    Hello again. Is this a Pool/Spa combo? Meaning there is a pool & spa that share the same equipment, namely in this case, the heater? If so, then your automatic valves may have failed. Are you noticing that either the pool or spa is draining or overflowing? You may be sucking water from pool and overflowing into spa, and you will not achieve the same result as you stated that spa heated in an hour, with this type of problem with the valves.
  • TMay Jan 24, 2013
    Spa is full & shutoff from the pool when I run the heater (&filter) for spa.
  • TMay Jan 24, 2013
    No change in settings from when the spa heated. Bad ignitor maybe?
  • Mike Tellegen Jan 25, 2013
    From the begining of this discussion till current, I thought you had intended us to perceive that the heater was "ON", but you see no temperature rise? So, to confirm: Is the heater actually on? When the blower fan motor comes on, do you hear a click after a few seconds then feel warmth/heat at the exhaust vent plumbing?
  • TMay Jan 26, 2013
    No. The pilot/burners don't light. No heat at the vent. Blower stays on.
  • TMay Jan 26, 2013
    This was sudden, one day it lit, then after torrential rain/wind, it didn't
  • Jandy Master
  • 1,631 Answers
How big a pool? You normally will not notice a temperature rise immediately. On average, swimming pools will see a one degree rise in temperature every 45 - 90 minutes.
Posted on Jan 22, 2013
  • Mike Tellegen Jan 26, 2013
    There is a potential that the ignitor could be bad. But normally I don't change parts arbitrarily. Troubleshoot & diagnose, is the best way. With these heaters, an error code should show up if a part has failed.
PartsCenter
  • 125 Answers
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Posted on Feb 26, 2009
SOURCE: SPA Filter on while Spa is Heating
you have one jandy valve ( the suction valve in front of the pump) that is not working right when you press spa mode. have someone watch the valves to see if they move when you press spa mode and heat inside the house. if the one in front of the pump does not move and the switch is in operating mode then that valve is bad and will have to be replaced.
Posted on Aug 06, 2009
  • 246 Answers
SOURCE: Same Issue
the pump stop so will not drain spa dip # 4 may turn off for the delay but not sure if the pump will still turn off since this is new tech. good luck
Posted on Sep 14, 2009
  • 246 Answers
SOURCE: Jandy Lite 2 does not ignite
burners are plug with spider get a wire and bended get it inside the orifices where the gas come out every single one than try now ? magic heater comes on
Posted on Oct 16, 2009
ftw1952
  • 10319 Answers
SOURCE: The control panel on my
Most likely the main circuit board has a faulty relay incorporated on it. You can get top expereince help at this web site if you wish to determine the exact problem you have with these guys. They are good
http://www.poolspaforum.com/forum/index.php?showtopic=10966
Posted on Jun 29, 2011
What does CFH mean
this is not an error code. it means a call for heat. the pool water temp is colder than your tstat set point
May 25, 2014 | Rheem 266K to 399K BTU Swimming Pool...
AGS error code
check gas pressure if ok then see if runs 7 sec if shuts off then check flame sensor if blower doesn't start check safety circuit
Nov 24, 2012 | Jandy Lx Pool & Spa Heater - Electronic...
CLK code will not heAT
Not sure about your specific heater, but if the heat won't go on, it could be the water pressure sensor or one of the temperature sensors.
May 05, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
How do i replace the ignitor in a Jandy lx400n-l, the manual does not show how to remove covers to get to the ignitor? thanks mike
shut off power remove the burn rack pull out ignitor wire goes under rack replace and put back together make sure no gas leak
Jul 13, 2011 | Jandy Lx Pool & Spa Heater - Electronic...
Shows r 5 code when power is turned on. sta-rite
The R5 is a sequence code in the boot up sequence where your error is occuring. There is nothing in the users manual for these pool heaters that explains this error. Your best bet, unfortunately, is going to be to call Sta Rite. Here is their customer service number: 1-800-831-7133
May 08, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Fan for the heater will not come on showing service HI LIM SW on screen
That would mean the high limit switch. Check it and see if you can reset it. It may have gone bad. Check first and if needed find a replacement part. Good luck...Lee
Nov 25, 2009 | Jandy Lx Pool & Spa Heater - Electronic...
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
199 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
