Question about Watches
Looking for a 7T32B or a Y182 replacement movement
  • Craig Ridley
    Craig Ridley Aug 14, 2013
    I also am looking for a NOS 7T32B Seiko (Hattori?) movement for my 7T32-6A50 (A4). Any leads to a working movement email me at Craigsridley@gmail.com
Where is AC when replacing a Casio watch battery
This varies depending on what module is in your watch. Check over the back of the movement - what you are looking for is a gold/brass contact spot on the circuit board with 'AC' printed next to it. or 'AC' stamped into the metal right next to it.
Oct 19, 2017 | Casio Watches
Watch won't turn on after battery replaced
Hello Rey Anthony,
In all cases where I have encountered this issue...
From a WORKING WATCH...
It was caused by a DEFECTIVE BATTERY...
My best suggestion
(rule: easy/cheap solutions go first):..
((Only for METER owners ... test the battery))
>> Get another battery and try again...
If the battery consct looks the VERY slightest
surface corrosion very gently rub the contact with
a regular pencil lead... (VERY GENTLY)...
ELSE...
You are looking at a replacement MOVEMENT
Carnac the Magnificent
Jul 29, 2017 | Watches
I have a rectangle face bulova watch with 3 diamonds. Case says L3 movement says L1. How do I find the name and possible value. It was handed down, so not looking to sell.
From the watchophilia site -http://www.watchophilia.com/general-info...
It appears you have a case and movement that don't belong to each other. The case is '54 and the movement is '52.
I think. Maybe.
Check their site and see what you think. http://www.watchophilia.com/general-info...
Jun 23, 2017 | Bulova Watches
I need help rewinding my Pulsar Movement Japan watch. Ive been looking for answers but none seem to work. Its suppose to rewind by movement i guess. Any help?
if it's automatic it means the movement of your wrist keeps it wound up ,but if it's not been worn for long time you can still wind it with the winder, if it still doesn't work it may need to go for a service at the jewelers.
Jan 03, 2013 | Watches
The scond hand on my tag formula 1 has stopped and wont resest,but the watch still works with the time. What could the likely problem be? Could it be the battery? or could it need servicing?
Sean, This watch has a disposable movement(guts). That means the battery is the only part that can be replaced. The thing is glued together instead of screwed. Take it to a watchmaker that can get the replacement movement from Tag as the ordinary movements out there are different from the genuine Tag movements. Date wheels specifically are different. Anyway, a professional watchmaker, not a jeweler or store clerk please, will be able to tell you if that is the correct course of events to take. Probably looking at 200 to 250 Michael, Watchmaker to the Stars!
Mar 17, 2011 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Have a Giorgio watch Movement #579-005 or 579-105 looking for a cross reference movement Thanks...Frank
There are millions of movements novadays. You have to get an eyeglass and examine your movement. Then submit all the details. Do not forget to mind if it is mechanical, quartz, solar, e.t.c.
Jan 22, 2010 | Watches
I have a Citizen Aqualand Promaster 200M circa 1991 and the analog has stopped working. It was sent back to Citizen repair facility in CA last year and they said it cannot be repaired because movement is...
First of all they should be giving you explanation why the watch needs whole movement replacement and what is the cause.
As the watch movements are upgraded and made more sophisticated every year, some of them are discontinued and the next generation movements are replacing them. Watch manufacturing companies usually try to produce interchangeable movements, so, the newer one can replace the older.
In your case (if there is no newer version replacement) you have no option, but to shop around for exact new movement for replacement.
All you have to do is to find out your watch's movement number (that Citizen facility in CA should give that) and then shop for it. Plenty of movemevts on ebay, not to mention specialized watch part supplier companies. All available over the internet - just takes some time and nerve.
Rate, please.
Jul 23, 2009 | Citizen Promaster Cyber Aqualand Nx Dive...
Does anyone know where to get a replacement 'movement' for the Michael Graves's Alessi mantle clock.
Yep - I know a clock repairman in California who still has some of the original Hechinger Quartz Movements for the Alessi pendulum clock . Definately worth repairing .
Jul 13, 2009 | Watches
Bought pulsar- no instructions
Go to the pulsar website to see if they have a PDF file with instructions or scour Google with the Y182 etc. information. That info is the movement model number the Seiko website may also have information. Knowing the movement information may link you to instructions. Call or go to Otto Frei website, call them and they may point you to the right direction. They probably sell that movement.
Nov 16, 2008 | Watches
How do i remove crown?
Hi, on the back of the movement there should either be a screw or a dimple in line or next to the line of the stem. If a dimple, press in with a pin or similar sturdy tool and gently withdraw the stem. If a screw, only one turn should be enough to release the stem
Nov 13, 2007 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Watches Logo
333 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
