Question about Hotpoint RGB745 Gas Kitchen Range
Gas Range has inconsistent gas flow
I have a Whirlpool SF385PEY gas range that is 12 years old. Recently, there seems to be a problem with gas flow. When I light the oven, and it is heating up past about 240 degrees, the range top burners will get weak flow and either will not light or go out if they were lit. Then, occasionally, the oven will quit working. If I don't run the oven, there is glow to the stove top, but it doesn't seem as strong as it used to.
The supply line looks strong and intact. The electronic ignitors seem to function well.
  • jakewisk Jan 27, 2009
    Thanks. The model is SF385PEY. It is about 12 years old, free standing. I'm assuming we have good gas pressure, as the furnace is also natural gas, and doesn't have any problems. At this age, is it worth having repaired?
    Scholar:
  • 42 Answers
From what you've described and what I understand; the only part that requlates the gas flow "low or intermitten gas flow/pressure" is the "gas pressure regulator" located where the incoming gas flex-line connects directly.
The pressure regulator is about 3" x 3" metal square blockish' type device and can be replaced fairly easy. However, if and when replacing the pressure regulator, ensure you are using the proper gas - yellow teflyon tape of pipe dope paste to thread in the new part.
What is the model number of the range? (free standing - gas pilot only)
(The above suggestion is assuming you have the proper gas supply pressure to your home/range)
Posted on Jan 27, 2009
Wfg361lvs oven clicks 1 times, lights and then clicks three more times and turns off.
manually check the burner and the gas jet area for blockage that would prevent lightup.. the safety is kicking in to prevent gas explosion..
Jan 12, 2014 | Whirlpool WFG361LVS Stainless Steel Gas...
I have a kenmore electric oven, which is 13 years old. i used it two weeks ago, and it was fine. now when i turn on the oven, there is a strong gas smell coming from it that not only envelopes the...
Hello Cheryl Davis...
Your posting came in UNDER A DUAL FUEL
ELECTRIC - GAS combination...
If you are smelling gas... you are in immediate DANGER.
PLEASE turn OFF the gas at the wall...
The gas is not only toxic it is highly EXPLOSIVE ...
Do not experiment with your health & safety...!!
GAS appliances are very dangerous...
A single HOT-SURFACE ignition failure
should have caused the GAS to not flow...
If it is flowing ... you are in EXTREME DANGER.
Aug 12, 2017 | Whirlpool SF315 Dual Fuel (Electric and...
Gas range won't ignite. We had PGE and come over
This sounds like a failed burner igniter, also called a spark module. These are pretty easy to replace since the module itself is located at the back of the stove under an access panel. The price is around 40 to 60 dollars. Lately it seems that these newer stoves have weaker spark modules. I see dead modules on models less than 2 years old, where it used to be more like 5 or more years on the older ones.
Mar 24, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Will gas top flowing if pilot lights go out?
hI no they will stay on you should be able to turn them off
Jan 07, 2010 | Tappan 24 in. Freestanding Gas Range...
Gas won't flow through range
might be a clogged line, could be your diaphragm in the regulator that is bad, you will need to disconnect the regulator where you hook up your gas line to the range then from the burners blow compressed air through them, I would suggest replacing the regulator, should cure the problem.
Jan 19, 2009 | Stoves 600SiDOm Gas Kitchen Range
8 year old kitchenaid gas range nom fire in the oven
I went to the kitchenaid web site for parts and found a trouble shooting section. I read about how a electronic glow coil works and discovered that mine was just old and did not reach the right voltage to open the gas flow valve.
Feb 20, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
GE Profile Gas Range Igniters working but gas takes a while to start flowing
HI thanks for your question. the igniter is the cause for this problem. the heat from the glow bar is just not hot enough to ignite the gas. i would replace the igniter. thanks
Nov 26, 2007 | GE Profile JGSP48 Gas Kitchen Range
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool oven won't ignite
you do have a problem that needs to be attended to by a certified tech.you same to have a gas flow problem.maybe a valve problem.
Jun 03, 2007 | Whirlpool GS445LELS Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
351 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
