Question about Acer Computers & Internet
White screen acer
White screen safe mode
  • Acer Master
  • 5,660 Answers
White screen when you start the laptop, and then when you connect an external VGA monitor, you can only operate in Safe Mode?
Or white screen except when you are Safe Mode?
Doesn't matter anyway, just wanted to see what you are stating.
1) Have you connected an external VGA monitor to the laptop, and seen if you get a good display on the external VGA monitor?
No display on external monitor?
You have at least 3 display options available;
A) Internal monitor of laptop ONLY
B) Internal monitor of laptop AND external VGA monitor.
C) External VGA monitor ONLY
Hold the Fn key down, and tap once on the F5 key.
(The F5 key is the Display Toggle-Over key)
Still no?
Hold the Fn key down again, and tap once more on the F5 key.
Good display on external VGA monitor?
Problem is the Video Cable, or inside the Display Assembly.
White screen on external VGA monitor also?
Problem is the graphics chipset.
[Actually it is probably inadequate cooling for the graphics chipset, and this makes a bad contact of graphics chipset TO motherboard. If this is found to be the problem I can explain further, and in much more detail ]
Inside the Display Assembly:
A) Screen Inverter if it is CCFL backlighting.
May or may NOT be a screen Inverter if it uses LED backlighting.
[ CCFL - Cold Cathode Fluorescent Lamp
LED - Light Emitting Diode ]
B) LCD screen.
Video Cable:
The Video Cable connects to the motherboard, in an area either under the Keyboard, or under the Switch Cover, or bottom of the laptop.
[Switch Cover,
Goes by many names. It is the strip of plastic above the Keyboard, and below the LCD screen. Usually has the Power On button, and LED indicator lights; plus speakers, sometimes ]
From there the Video Cable goes under the left Hinge, and up into the Display Assembly.
If a screen Inverter is used, a small cable comes from the main cable, and plugs into the screen Inverter.
The main cable connects to the back of the LCD screen.
Due to normal repeated opening, and closing of the laptop; the Video Cable may be pulled on.
This can create a bad connection on motherboard side, and/or screen Inverter cable connection, (IF used), or to the back of the LCD screen.
It can also cause damage to the Video Cable.
(Stretched/Broken wires)
Once you post the product number I can guide you step by step, show you the components I'm talking about, and track down a Service Manual link, and possibly pictorial disassembly information.
The Video Cable connections are checked first.
A loose connection can cause what you are seeing.
The sheath of the Video Cable is also scrutinized for damage.
Obvious damage to the sheath, may mean damage to the tiny wires inside the Video Cable.
Another thing that can cause what you are seeing.
Video Cable connections prove not to be the problem, then the Video Cable is to be removed, and a continuity test performed on it.
Multimeter set to OHM's. (1K)
If a multimeter is not at your access, then suggest taking the Video Cable down to the nearest small computer shop, and have the resident tech check it for continuity. Should only be a couple of bucks.
YOU MUST rule out the Video Cable as the problem, before going on.
Video Cable checks out?
Then if a screen Inverter is used, this is the next component in the diagnostic flowchart.
Problem is this; it requires a sensitive multimeter to test a screen Inverter. Think fairly expensive,
http://www.fonerbooks.com/test.htm
The plastic frame in front of the LCD screen, is the Display Bezel.
The screen Inverter is located behind the Display Bezel, and mounted down towards the bottom of the LCD Screen Frame.
Due to the multimeter issue, the above noted ease of accessing to replace, and the usually low cost of the screen Inverter; most decide to just replace.
Screen Inverter replaced? Same problem?
The problem is the LCD screen.
No screen Inverter used? The problem is the LCD screen.
Video Cable; Usually around $9 to $20
Screen Inverter; Same.
LCD Screen; from $70 to $240. Just depends on what Lenovo laptop we're talking about here.
This is why you diagnose first.
Would be foolish to assume the problem is the LCD screen, and purchase one; when the problem may have just been a loose Video Cable connection, or one of the $9 to $20 components stated above.
Ready to diagnose?
Post the Product Number back in a Comment.
Regards,
joecoolvette
Posted on Jan 22, 2013
After starting the computer it shows up the acer logo an after that i have just a black screen with a white blinking line.(AA 5935G)
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
May 15, 2011 | Acer Computers & Internet
My computer keeps going through start up it wont go to my home screen with all of the icons
Try to boot it in safe mode and do a system restore.
To get to safe mode, press F8 after you turn it on. Keep tapping on the F8 key until you see the white menu on the black screen. Choose safe mode and then do a system restore.
If this doesn't work, here are a couple of tips to try:
http://www.fixya.com/support/r4501608-when_windows_xp_start_primary_fix
http://www.fixya.com/support/r4501848-when_windows_xp_start_secondary_fix
and finally
http://www.fixya.com/support/r5438565-when_windows_xp_start_final_fix
Good luck
Mar 20, 2011 | Acer Computers & Internet
Doe's the acer aspire 7315 have a built in mic
Once the power button is pressed to turn On, keep tapping the F8 button on the keyboard until you see the "Advanced Boot Options" with the lists of options including "Safe Mode", "Safe Mode with Networking" etc...etc... Verify which option is selected by default, move the up-down arrow keys on the keyboard to navigate through the options and press enter to proceed with the selected options, i.e. Safe Mode (in your case), once the enter is hit, you'll see black screen with white texts, wait for several seconds/ or a few minute and proceed, you'll also see a warning pop up message, if so click "yes", there you are in the safe mode.
If you need further help, let me know
Good luck.
Thanks for using FixYa.
Oct 18, 2010 | Acer Aspire 3610 Notebook
My laptop turns on but displayed black background & white cursor
I would boot in safe mode and attempt to run a scan for viruses or malware. That is what I would think the problem was
You could also do a system restore to before this problem started in safe mode. If you dont know how to get to safe mode google it. something like "Safe mode Windows Vista"
Jan 06, 2010 | Acer eMachines 520-2890 Notebook
Acer Aspire 9300 turns on with black screen
Hello!!
Try entering thro the safe mode ... and restore the system. let me know the updates.
Cheers!
Jun 23, 2009 | Acer Aspire 9300 Notebook
Black Screen on ACER 5570Z
there is a os problem try to run system in safe mode or format it
Jun 08, 2009 | Acer Aspire 5500 5570-2609 Laptop
Cant get into safe mode. tried toggling f8/f7 together but nothing
the key to getting into safe mode....tapping F8 (only that key) super fast, not stopping until you hear a beep...and see the option to boot into safe mode.  The most common reason that it will not work is that it is not pressed fast enough or early enough.  You will know that you missed your chance if you see the windows loading screen......start pressing it right away when you restart your computer and don't stop pressing F8 until you see the black screen with the white letters giving you the option to boot into safe mode.
Good Luck!
May 08, 2009 | Acer Aspire 5100 Notebook
My Acer cannot log in the normal screen but the safe mode
Do you see the white cursor on the black background? If so, press CONTROL+ALT+DELETE keys. If the Task Manager window appears. You can start the PC from the CD/DVD and choose Startup Repair from the choices given.
Apr 19, 2009 | Acer Aspire 5920-6727 Notebook
White blank on acer 4315
It sounds like a Bios issue.
Go to http://support.acer-euro.com/drivers/notebook/as_4315.html
Download the latest Bios for the windows you are currently running and follow the Readme.txt and update the bios.
Hopefully this will fix the issue that is connect with the monitor and power setting in the bios.
Please Rate, Thanks.
Jan 06, 2009 | Acer Aspire 4315 Notebook
Acer Desktop doesn't boot
I have had the same problem than djlimit.
I have contacted ACER service on line (in France, were I live) . They propose a quotation for repair against 60 Euros.
I shipped the product through (prepaid) express parcel service. I got it back 10 days later. They simply exchanged the main PCB.
Jun 17, 2008 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
