Question about Air-O-Swiss 7133 Humidifier
Runs for a few minutes then stops - Air-O-Swiss 7133 Humidifier
Forget the visually appealing white mist humidifiers that leave you with a white slime to clean up. Get yourself a warm mist humidifier without the hassle, works better and no mess to clean up!
Posted on Nov 03, 2013
Tank is full, but after a few minutes why does it stop and the 'Tank Empty' light comes on?
Reset light comes on, unit stops operating when tank is full ...
www.fixya.com/support/t384577-reset_light_comes_unit_stops_operating
Feb 6, 2008 - Question about Vicks Warm Mist V745A 1 Gallon Humidifier ... Tank is full. ... for about another 5 minutes when the unit stops, reset light comes on etc. ...the humidifier since the reset light keeps going on immediately after I turn ... water in the tank because of course, the heater is on, but no water is getting ...
How to Fix a Humidifier ' HomeTips
www.hometips.com/repair-fix/humidifier-doesnt-work.html
Jan 17, 2016 | Humidifiers
Why does my Honeywell HMW450 humidifier keep shutting off?
Here are a few things to check:
-make sure the heating element is clean. If there is a thick layer of scale (mineral deposit), then the unit will not turn on.
-there are magnets on the water reservoir that allow the unit to turn on. If these magnets are not lined up properly, then the unit thinks there is no tank, and thus, not turn on.
-turn the humidity up past your target point. The humidity near the unit could be a lot higher than the rest of the room, causing it to shut off prematurely.
Hope this helps!
Apr 29, 2012 | Honeywell HWM-450 4 Gallon Humidifier
After the humidifier runs for a few minutes it just shuts off.
You might need to clean around the heating element...
we have very hard water and calcium builds up on and around the heating element and all the surrounding parts. I take it apart and pour CPR around the element and scrub with a brush .. once you get it clean it should stay running.
Dec 29, 2010 | Holmes Products Warm Mist HM5700...
Hi. It keeps going from the green light to the red light so its not generating any moisture. It does this on its own sometimes it runs for a while and sometimes it does it right away. Any idea what is...
This is usually a problem with the water float. Clean the float and assembly (see the instruction manaul) and that should fix it. The light is coming on cause the unit 'thinks' there is no water.
The unit works for a few minutes (green light) and then stops - is typical of a float that sticks when it gets to the bottom. So pay attention to that part of the assembly or the bottom of the float having grime or buildup.
Dec 12, 2009 | Crane Frog EE-3191 1 Gallon Humidifier
The humidifier only stays on for a few minutes even if it is on the highest setting
Not sure where you are located (Northern US?) but it really isn't cold enough for the air to hold much water. It is shutting off because the air in your home is already at 40-45%.
Nov 17, 2009 | Aprilaire 600 Humidifier
MOTOR IS NOISE
Sounds like your motor bearings are going bad. If at all possible lubricate the motor bearings using a few drops of a NON detergent oil. If the motor has sealed bearings with no oil ports then you should replace the blower motor.
Good luck
Mar 29, 2009 | Essick Air 447 302 Console Whole House...
Aprilaire 440 won't stop running
Disconnect the two low voltage wirings going into the solenoid valve. If the water does not stop running after a few minutes the valve is bad. When you check your local area to price a new valve. Also get a price for a new humidifier. You will be surprised to find that a whole new unit isn't that much more. Or should I say that you will find that the replacement parts are overpriced.
Good Luck
HVAC Teacher
Feb 23, 2009 | Humidifiers
Fan shuts off too soon after oil burner stops
That is an old style t-stat i would replace it with a more up to date model. Your problem may be in the limit switch. But yes to answer your question most fans can be adjusted just depends on if it has a manual limit that looks like a silver box on the interior of your furnace or if it has a mother board control system.
Jan 04, 2009 | Honeywell Power Humidifier: Furnace...
Motor replacement
probably a fractional horsepower open frame motor - go to grainger dot com and see if you can find a replacement
Jan 20, 2008 | Bemis 4D7-800 Humidifier
Air-O-Swiss 7133 Humidifier Logo
248 people viewed this question
Top Air-O-Swiss Humidifiers Experts
Mack Baxter
Dennis
Are you an Air-O-Swiss Humidifier Expert? Answer questions, earn points and help others
