Question about Remington REM 18586 700 BDL STK/FOREND MAG SYN
I have a remington squeeg-e part stuck in the barrel of my gun. how can i get it out?
I've tried pulling it out, oiling it and pulling it out, and ive tried blowing it out with an air compressor
Front filter blowing out after washing it
Did you ever find out what caused the problem? My vacuum is doing the same thing!
Jun 17, 2013 | Shark Navigator Professional Lift-Away...
I need Instructions
look on the internet use the name and style they should show you something.
Jan 05, 2013 | Remington Style Solutions Ultimate Stylist...
Frigidaire Gas Self Cleaning Oven door open in lock position
Hello ericndiana6b - Was the unit in self-clean mode? Try pressing and holding the "Clear/Off" button to stop any operation of the EOC. Do this at the same time while pushing and hold the light switch to the left of the door lock. Usually this will trick the oven into unlocking the door. If it is ineffective, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and redo the steps. If door continues to maintain locked while open, the unit may possibly have a faulty door latch or a communication problem with the EOC. Contact a professional to move forward accurately.
Nov 27, 2012 | Frigidaire GLGF376DQ Free-Standing Gas...
My shark navigator is getting hot
Yes, tear it down as far as you can and make sure there are no obstructions- take it apart as shown in the manual and run warm water through all the hoses to clear them.
They're like an artery and the more they get clogged the more heat the motor will have to generate to make suction.
Also check the beater bar and make sure there's no strings, etc. hung up under there- use a box cutter to carefully cut any tough strings and see how you do.
Chances are, that's all you need.
-Jim from Shark Navigator reviews
Nov 16, 2012 | Shark Navigator Professional Lift-Away...
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
My remington straightener won't work properly. HELP?!
Try wiggling the lead where it goes into the straightener and then the plug. If it works it may be a broken cable in the lead
Jul 29, 2012 | Remington Keratin Therapy 1-In. Hair...
Remington pearl plates won't heat with blue light?
1) you have to test the power cord for broken or fault with VOM
2) inside there are thermal fuse, test it and replace with VOM
3) test the heating element for open and replace, and test for ground
4) test the thermostat, and adjust it.
God bless you
Jul 22, 2012 | Remington T-Studio Pearl Ceramic 1" Slim...
Black and decker all temp steam iron stopped working while ironing and now it won't turn on.
please see the cause and fix it:
a) tank or ports clogged. Dissasembly and inspect replace tank and seal if badly clogged. Emptying iron after each use allow heats to evaporate remaining water and helps prevent clooging. Inspect valve and linkage: clean or replace as necessary
GOD BLESS YOU
Jul 22, 2012 | Applica Black And Decker All Temp Steam...
Remington REM 18586 700 BDL STK/FOREND MAG SYN Logo
Top Remington Irons Experts
Are you a Remington Iron Expert? Answer questions, earn points and help others
