Question about Lenovo 3000 Computers & Internet
Liquid leaking from bottom of laptop
Clear liquid leaking from bottom of my laptop when it's on.
  • Lenovo Master
  • 5,660 Answers
In none of your three posts did you state the laptop manufacturer, and model number.
Model number is on the Bottom of the laptop.
Post back in a Comment.
Clear liquid?
I really for the life of me cannot think what that would be.
IF, Electrolytic Capacitors are used on the motherboard, and IF one or more were bad; the Electrolytic Paste ooze from inside would be more of a Yellow, or Brownish liquid.
Someone spill part of a drink on your laptop, clean it up off the top real good; and not tell you?
The Cooling Tube is part of the cooling system.
Slightly flattened copper tube, sealed on both ends, and filled with Nitrogen.
Wonder if a pinhole developed in it?
I guess the only way to know is to L@@K inside, huh?
Post the Product Number in a Comment.
This is on the Bottom of the laptop.
http://support.lenovo.com/en_US/FindProductNumber.page
I'll start by seeing if there is an HMM for it, and then look for pictorial info; on disassembly for you; AND give you guidance step by step as best as possible.
Regards,
joecoolvette
[Oh, I know! Tell the little man inside not to slop water out of the bathtub!
JUST KIDDING! ]
Posted on Jan 22, 2013
  • joecoolvette
    joecoolvette Jan 22, 2013
    Well now I know, thanks to an old solution White Zombie posted. Perhaps it is the LCD screen.
2 Suggested Answers
  • 4961 Answers
SOURCE: screen leaking sticky liquid
Yes...the liquid is toxic. LCD solution can be highly toxic and ought not be touched. I would definitely put it somewhere where your cats can't get close to it, and bring it to a repair shop.
Posted on Jun 05, 2012
Clear liquid leaking from adapter of laptop charger
unplug it.if theres any warranty then contact supplier.if not find another online to replace..could be a component breaking down like capacitor..but it shouldnt be leaking anything
Dec 01, 2015 | Computers & Internet
Screen leaking sticky liquid
Jun 04, 2012 | Dell Latitude D630 Laptop Computer PC...
Clear liquid is leaking from the bottom of my 2009 sentra
There is little I can think of that is going to be a clear liquid in your car. The only things that I can think of 1. Condensation coming from the drain of your A/C unit(most likely), 2. If it is a small amount and it is coming out of the tail pipe, it is water. The catalytic converter turns most of the unburned gas from your engine into water.
Automatic transmission fluid is RED, Antifreeze is Green in Nissan products, Brake fluid will be a semi clear liquid with a brownish hue to it. Manual transmissions use gear oil which is a golden color. Engine oil, depending on how well the car has been maintained, will be a light goldish to a black.
I hope I have answered your question.
Aug 06, 2011 | 2002 Nissan Sentra
Fisher & paykel fault "F1" is displayed on the top
hello
F1 means the flood sensor senses water at base of machine at PC board.
You need to take out bottom drawer and check for water puddle under where the drawer was.If there is water you can get the machine going again by comletely drying it out(F1WILL CLEAR),but it still means you have a leak.With bottom drawer out you can really see whats going on.Once F1 is clear you can actually run upper drawer and see if it leaks.Most likely culprit are the lid actuators.Replace all 4 . It'll run like new.Don't overload drawer .That can cause lid leak too.Also the PC board may be damaged and may start to go crazy giving fake F1 codes.$80 easy fix.
good luck
Jul 27, 2011 | Fisher and Paykel 23 in. DD603H SS...
Leaks water out of bottom
If it is a small leak and you are not using the timer put all the dry ingredients in first and push the "start" button. Have your liquid ready and slowly trickle it in so that the dough slowly forms. That way you won'f have a lot of liquid passing through. Once all the liquid is in the pan, just close the lid and you should be OK from there on. This will at least work until you can buy a new machine or get a new pan assembly.
Apr 17, 2011 | Kitchen Appliances - Others
!998 Dodge Caravan is leaking a clear liquid left of battery.
antifreeze by the sound of it ,but it could be battery acid from a damaged battery casing
May 16, 2010 | 1998 Dodge Caravan
LOOKS LIKE SCATCHES BUT THE SCREEN ISN'T SCRATCHED AND BLOOBS OF LIQUID ON THE INNER SCREEN. A LINE DOWN THE CENTER OF THE SCREEN TOO
That really sounds like the LCD screen is cracked. The front will not feel cracked because of a clear plastic cover sheet but behind it is the LCD panel. The liquid you see is part of the screen leaking. The LCD actually means "liquid crystal display" and that is what you are seeing leak out between the cracks in the panel. You will need to have the panel replaced to clear the problem. You can get the panels from Ebay if you want to do the repair yourself. This type of repair is not covered under the Acer warranty. If you have any questions just use the email address below.
Buddy
Corporate Computer
www.ccl-la.com
h@ccl-la.com
Dec 16, 2009 | Acer Aspire One PC Notebook
There is a leak under my hood and i don't know what it is
The only clear liquid I can imagine in that area is brake fluid.How do your brakes feel?Check the master cylinder.
Dec 08, 2008 | 2000 Mitsubishi Eclipse
D52W19 No pix, sound good - now green light blinks, no come on
First of all you need to find out which CRT leaked and replace it before any other repairs are done. The clear liquid is conductive and has done damage to the CRT board or boards.
Jun 15, 2008 | RCA D52W19 52" Rear Projection Television
Computers & Internet Logo
608 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
