Question about Dell Computers & Internet
Long beeping sound and Appear ascii code on the top of DELL logo.
Before going to login menu. I also updated the bios to A11, but the problem still there. Pls. help me to solve this problem.
  • Dell Master
  • 1,102 Answers,39043052,50002608r-39026454s,00.htm
check this website may have what your lookin for if not go to bios setup and default settings then press F10 to save and exit
Posted on Jan 27, 2009
F2 does not open bios
  • After switching on your computer, let the DELL logo appear before pressing the F2 key until Entering Setup is displayed on the screen.
  • Previous versions of DELL might require you to press CTRL+ALT+ENTER to access the BIOS set up menu.
  • The DELL laptops use the Fn+ESC or Fn+F1 keys to access the BIOS set up.
Dec 05, 2013 | Dell Computers & Internet
F2 doesnt bring up bios
Beep codes dell
What model dell laptop ?
we've heard from Studio 17 customers who have the Core i7 processor here on Dell's Forum and other places like ForumDeluxx who are hearing a series of 7 beeps when they try to start their systems.
Yesterday, we posted a new Studio 17 BIOS (A05) to that should ensure the Studio 17 does not have this issue once the updated BIOS is applied. For those of you who have a system that sounds a series of 7 beeps when you try to start it, there are two solutions - one is a DIY fix and the other is contacting Dell and having a service technician come out and take care of it (see bottom of this post for options on contacting Dell).
The fix involves reseating the CMOS (a.k.a. coin) battery inside the system and then (this is important) updating the BIOS as noted above.Even if you are not experiencing beep codes, we recommend updating to the A05 BIOS.
Here is a link to the Service Manual that will explain how to reseat the internal CMOS Battery.
You will need to remove the back plate from the system, so please make sure you are comfortable performing this task.
1. Turn Off and unplug the system and turn it bottom side up
2. Remove external main battery from the laptop.
3. The rear plate for the system is held on by 6 screws.
Remove all 6 screws and remove the plate.
4. With the battery compartment facing you, looking in the top right hand corner you will see the CMOS battery.
5. Using a minimal amount of force and a flat tool, pry the battery gently from its seat (it is held on by sticky substance)
6. Unplug the battery from the motherboard by disconnecting the white connector.
7. Wait for approximately two minutes and then reattach the battery cable and reseat the battery.
8. Replace the rear plate and the retaining screws and reseat the main battery.
9. Attach the AC adapter and power on the system.
10. Update to the A05 BIOS revision
11. If a 5 beep code is heard, switch off the system and restart it.
Aug 24, 2013 | Computers & Internet
Bios revision a11
What other information is shown? Does it gets stuck at the BIOS logo?
Jun 13, 2013 | Dell Computers & Internet
How do I program my latitued lap top so it gors directly ine to the windows sart up , instead of having to enter a pass code to go thru the bios program. Once I eneter the bios pasword it will activate...
It seems that the Dell is not publishing the BIOS reset info online. You can try following the below steps once. ( Article ID: 184659)
During the initial boot of a computer the BIOS supplier will be displayed. If OEM logo splash screen is displayed, press ESC key to see the boot up information. Press the Pause/Break key if text displays too fast.
In the BIOS window, select Security tab and delete the BIOS password.
Jul 04, 2010 | Dell Latitude D610 Notebook
My Dell Inspiron 530, works fine once its powered up, but it take three attempts for the computer to boot on. I have taken the following steps. Checked that all fans are operational, they are. I have...
OK, here is what dell says:
BIOS checksum failure. Possible motherboard failure.
Try re-seating your memory modules and see if the beep code disappears
Also, Try using the Dell Diagnostics which is located on a hidden diagnostic utility partition on your hard drive or on the Drivers and Utilities Cd that came with your computer.
  1. Ensure that the computer is connected to an electrical outlet that is known to be working properly.
  2. Turn on (or restart) your computer.
  3. When the DELL™ logo appears, press <F12> immediately. Select Boot to Utility Partition from the boot menu and press <Enter>.
Press any key to start the Dell Diagnostics from the diagnostics utility partition on your hard drive.
Dec 29, 2009 | Dell Inspiron 530 Desktop Computer
I think I updated BIOS from Dell incorectly. Downloaded to "C" drive,replaced old BIOS with update. Resart. Blank screen, six beeps ( four then two), power light green,hard drive spins fast & blank...
Sounds like the BIOS upgrade didn't take. Those beep codes are audible indicators that the motherboard has failed POST (Power On Self Test).
Here's is a list of the codes for your specific BIOS/PC:
Sep 04, 2009 | Dell Dimension 4700 PC Desktop
Dell dimension 2400
Click this link:
It contains the list of the beep codes for dell dimension 2400.
There is also a guide on how and what to troubleshoot. Motherboards use beep codes to indicate what error might caused the system to malfunction.
Dec 17, 2007 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
42 people viewed this question
Alun Cox
