Question about LG WM1814CW Front Load Washer
Water pouring from the back of the machine - LG WM1814CW Front Load Washer
    Genius:
  • 1,669 Answers
Check the drain hose connection and the drain hose for a tear or hole!
Posted on Jan 22, 2013
Descaling?
Depends on the type of coffee machine, but with a normal pour and drip machine, you swing the water nozzle away from the filter cup so that the water goes back to the reservoir where you pour the water in. Mix CLR to the recommended strength and run the coffee machine for about 20 minutes recycling the water the descale solution. Then carefully swing the nozzle back over the filter holder. Run three normal cycles with fresh water and that's it.
For fixed and plumbed in coffee makers, there is a tank that you fill with descaler and a lever that cuts off incoming water and takes it from the tank. You would need to refer to the maker's instructions.
On a free flow machine, you can just make enough solution to fill the tank and run it. Then rinse with fresh three times.
Oct 12, 2016 | Coffee Makers & Espresso Machines
Cme256 scotsman
Is it dumping water or is it pouring water back into the ice bin? if it is pouring water back into ice bin than check your water float to make sure it is not calling for water also make sure the water valve is not letting water seep buy you can cut power to machine and if you here water still entering sump tray then replace water valve. if not then turn machine back on check and see it the water full light is on if so and water is still entering sump tray then replace float switch. If water full light is not on and the sump tray is full of water than remove the water sensor and clean or replace it.
Jul 10, 2013 | Kitchen Appliances - Others
I think my bunn-o-matic VPR needs cleaning and I do not have a manual for this machine. Can you advise on how to do this?
To clean the vpr you will need to take the lid off the machine. Be sure to unplug while doing this. First clean the water tray. You can unscrew the nut holding this tray and clean the tray in your sink. Put the tray back in and put the lid back on. Plug coffee maker in. Fill one coffee pot with vinegar and pour it in machine. After the water finishes coming out let the coffee maker sit overnight. Before you start filling the maker with water at least 6 times, be sure to clean the spray head. Make sure the 5 or 6 holes are free and clear of any build up. Then start with fresh water. Fill the coffee pot with fresh clean water and pour into machine. Let it finish and do this at least 6 times. If you can still taste or smell the vinegar repeat until you cant.
Mar 19, 2013 | Bunn Pour-O-Matic VPR
HOW DO I CLEAN THIS COFFEE POT
I suggest you use vinegar acid.
You need a solution with half part water and half part vinegar acid.
1) pour 4 cups of water into your coffee machines water tank.
2) pour 4 cups of vinegar acid into your coffee machines water tank.
3) turn on your coffee machine to decalc.
4) refill tank with clean cold water and let it run through ( 2 times)
REMEMBER !!! ALWAYS POUR ACID into WATER !!!! AND NOT THE OPPOSITE !!!
If you pour water into acid it can explode and make terrible damages and cause chemical burns!!!
Hope this will help ypu
Jun 28, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
My washer pour water just from the back hose ... doesn't suppose to pour water from the right side of the washer ? it used to do so..but not anymore
Hi just read your posting.Now can you tell me where the machine is leaking the water from.Is the water coming out of the black drain hose?Or is the water leaking from the inlet hoses from the taps? Or is it leaking under the machine?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Coffee starts dripping down before I can get the water all poured in and the pot on the warmer, causing a mess.
This is common with bunn coffee makers, if you are not fast enough, coffee starts dripping. The only solution I found is to use a water pitcher, first fill coffee pot to cup mark you are using, then pour into pitcher, put pot back on machine, then pour in water. You can mark a line on picture, so you know where to fill to each time.
Jul 15, 2010 | Bunn NHB Coffee Maker
Water pouring out the vent back into the reservoir...
i have a water problem but mine is .. when i turn the machine on it just starts pouring water out and does not stop.. and the machine still says not ready all the time the water is pouring out.. anybody know how to fix this ??
Jun 20, 2010 | Keurig Elite B40 Coffee Maker
Washer won't start. water pours down sewer pipe
Hi, If the water is going out the drain hose, raise the drain hose so that its highest point is as high as the top of the washer. This should take care of the issue. If the water is coming out of the bottom of the machine, tip it back against the wall and look under the washer to see if a hose has broke or came loose.
If I can assist you further, please let me know.
Vic
Jul 18, 2009 | Roper RAS8445KQ Top Load Washer
Our church received a Bloomfield Koffee King model 8571 and no instructions on how to set up and use the coffee machine.
Hi, Get 2 pots place one under the spray head with the filter cone in....now fill the other coffee pot and start to pour water through the lid top front...keep pouring water through (about two and a half pots) until water starts to pour through the cone....now the tank is full plug her in and turn on the power switch at the back and also the front if there is one....place filter in cone..put coffee in filter...pot on burner...wait about 25 minutes until water in tank is hot...when light on front comes on pour another pot of cold water through the top and you will get a pot of hot coffee in bottom....I also think this machine can be hard wired into water main....get plummer to hook up...follow same procedure but instead of pouring water through top for coffee..hit brew switch. if it poors too much of too little you will find a timer in the machine you can adjust to allow more or less water...hope this helps.
Jun 25, 2009 | Bloomfield 8571 Coffee Maker
Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
LG WM1814CW Front Load Washer Logo
15 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
