Question about Sharp Mx-2700n Color Copier / Network Printer / Network Scanner / Fax
Issues with scanning from Sharp MX2700N after replacing our wireless router.
I had to replace the wireless router in our office that all of our (8)computers connect through. There is also a wireless router that is attached to the copier. I was able to get into that router and change the settings so that we were able to print again. However, I have been unable to scan to computers on the network which I was able to do prior to changing the router. I have verified the IP address is correct. The only other thing I can think of trying is to uninstall and reinstall the driver software. Should that fix it, or is there an easier way?
4 Suggested Answers
  • 163 Answers
SOURCE: Scanning Problem
THERE IS NO NETWORKING PRINTER IN UR SHARP COPIER IT WILL WORK WITH ONLY ONE SYSTEM
Posted on Sep 08, 2007
  • 6 Answers
SOURCE: Computers cannot find the Sharp Scanner on the network
Are you using Sharpdesk? first check the firewalls, allow the exception, if that is not it, then from network scanner tool profiles, Change the Port, I believe it defaults to port 4687 - or 4689? (this uses an FTP port,) Allow this port in the exceptions. If the network scanner tool is not running, your machine will not communicate with the PC.
Posted on May 08, 2009
support741
  • 337 Answers
SOURCE: Issues with scanning from Sharp MX2700N after replacing our wireless router.
Driver software wont affect the scanner functions unless its twain via USB. Sharpdesk is weird and thst unit can scan to smb, ftp, and smtp very easy. check DNS settings. Try putting the copier in dhcp mode and let it pull the TCP/IP info from the router again, then set the static address back to what it needs to be. Also turn the firewall in the router off.
Posted on Jan 30, 2013
Line on copies in the same place all of the time sharp mx2700n copier
Replace drum OR main charger OR clean glass OR replace blade d
Feb 11, 2013 | Sharp MX-2700N Color Copier
Jan 22, 2013 | Sharp Mx-2700n Color Copier / Network...
I have installed a **** DI524 router at home . I have secured it with WPA encryption and password. I have no problems connecting using my home laptops. But my office laptop takes very long time to connect...
As far as I know, Windows XP OS works much better with WEP encryption rather than WPA. Changing the security encryption of your router might resolve your issue but I would leave the decision to you if you really want to change it.
Sep 11, 2011 | D-Link AirPlus DI-524 Wireless Router
Error code u2-10 on a sharp mx2700n photocopier
U2-10 SRAM user authentication index check sum error. I know, gibberrish right? To clear this error, put the machine in "simulation mode" by pressing "c" "*" "p" "*". then type 16, press the copy button, then press "execute" then press "yes". Hit the "ca" button to go back to ready. This should clear the error code. If the code returns, then the PCU PWB board needs to be replaced. I hope this helps.
Jan 27, 2011 | Sharp MX-2700N Color Copier
The Belkin wireless router was working for our home computer and one laptop, but the other laptop was not working. Later we figured out the laptop that was not working had other issues, but after calling...
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Oct 24, 2010 | Belkin (F5D7231-4) Wireless Router
Sharp AR-BC260 shows the network error CE-02
You need the Sharpdesk Software CD and you will have to install it in order for the scanning function to work.
Feb 03, 2010 | Sharp AR-BC260 Color Copier
Mac os dual network config on the wireless nic
Go to system preferences then to network on the network configuration that is working go to location and then click and scroll down to edit locations click on the gear wheel icon and rename the location to e.g. home or work. Then apply
Then at the bottom left hand corner click on the plus sign and then setup say your wireless network (or as apple calls it airport and once this is done rename that location to what you prefer.
Hope this helps
Dec 12, 2009 | Apple Mac OS X 10.4
MX2700N printer keeps giving A4 paper error.
Go to system setting, under printer setting there's a menu to forced output print or A4/Letter changing, if you can not find it try the key operator program/ admin mode ( default password for admin is admin )
Feb 19, 2009 | Sharp MX-2700N Color Copier
Sharp-MX2700N Maintenance Code VK
VK = 100,000 pages printed on the developer counter or 715,000 revolutions of the developer unit (as mixing can occur even when pages are not being printed). Developer can break down over time and or the seals can be damaged - so service by a technician is indicated. If maintenance was recently performed and the developer replaced then the counter needs to be reset.
Feb 04, 2009 | Sharp MX-2700N Color Copier
Sharp Mx-2700n Color Copier / Network Printer / Network Scanner / Fax Logo
41 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
