Question about Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel
Fitting extensions to 1/4 turn taps
I fitted extensions to taps and can,t get any water presure
  • 979 Answers
There is an air gap that is causing the problem. I had the same problem. Replace the sprayer. Try first cleaning the head of the sprayer by taking it apart.
Posted on Jan 30, 2013
Water hammer bangs about 6 - 8 times at start up, then stops(furnace humidifier)
get a plumber in to determine the reason for the hammer
if it is unavoidable have him fit an accumulator into the pipes to take the hammer out of the system
possible to change from quick stop taps 1/2 turn or ceramic taps to a tap that takes several turns to stop water flow but normally an accu,ulator fitted into the system will easy the problem
Nov 16, 2016 | Washing Machines
Stop tap was not turned off when new boiler was fitted and leaked for 5 months
sad but very true .there is nothing we can do about it for you either
Oct 17, 2016 | Water Heaters
Water temperature has reduced even on maximum setting
check tap had a shower myself that would start hot then 3 minutes later hot was cold! then hot after 5 minutes.
I turned off main tap on meter, Undid tap fitting on shower found the washer was worn but also the tap fitting was seized could not turn it for full movement. You could soak the tap screw fitting in CLR and pull apart and use a tap grease on the screw thread or just buy another tap fitting. I discovered most of my tap fittings had calcium build up in them. But I replaced the shower tap valve thingy as it was really seized up.
Nov 22, 2015 | Home
How to Connect to water supply to get ices?
The icemaker kit should have come with a 'tap' valve for tapping into a copper or a pvc water line. It is essentially a clamp with two 1/4" bolts and a 'tee' handle that depresses a stem. The stem is stainless steel and is sharpened to a point. That point is designed to puncture the copper water line to allow water to pass through the 1/4" 'compression' fitting on the 'tap' valve when the 'tee' handle is turned counterclockwise after the puncture is complete.
Sometimes there is a malfunction necessitating the shutting off of the water supply, so locate your shut off for that line. If the valve malfunctions and you create a leak, its time to shut it off and maybe go for a different solution. There are reasonably new fittings called 'shark-bite' fittings that make leak repair or adding an additional line very easy. Your water line will probably either be 1/2" i.d. or 3/4"i.d., so figure out which one and go to your local Lowe's or Home Depot and get a plumbing specialist to fix you up with a shark-bite 'tee' and valve and material that will get you down to the 1/4" O.D. tubing size that is required for connecting to your icemaker. It will be 1/4" O.D. not 1/4" I.D.
Aug 30, 2014 | Frigidaire Refrigerators
How to unistall franke mythos mtx taps
Turn off the water supply from the heater and at the main water supply line outside. place a container under the sink where the flick mixer is mounted to catch the water that will come out of the lines when you undo the fittings.
there should be 2 flexible braided lines coming from the mixer to the water supply lines, undo both fittings from those lines, then undo the brass nut that fastens the mixer to the sink, you may need a 10 or 12mm socket with an extension bar to get up under the sink to be able to undo the nut.
there should be a metal horseshoe shaped retaining plate that holds the mixer to the sink which should come off when the nut is undone.
You may or may not have to remove the flexible lines from the mixer which you should be able to sort out when you get to that point.
I hope this info helps you with your problem, the info may not be exactly how I have explained but that is how most mixers are fitted or removed.
Jul 05, 2014 | Emerson InSinkErator HC-View-SS Satin...
I Have a cold water dripping in my sink the taps are mixer taps i have fitted a new washer but it still drips also it is tight to turn on and off. also my Hot water tap is hard to turn on it turns quite...
you need to check the seating in the tap for pitting, the new washer will not seal if the seating is pitted. you could fit some TAP REVIVERS which are available from most plumbers merchants.
Sep 08, 2011 | Home
Lisbon monobloc kitchen taps just installed the
Put some cooking oil around the o-rings to sofen them up so they would seat around all fitting surfaces. Hope this helps.
Aug 12, 2010 | Home
How to connect the cold water supply to K 3.65 Jubilee? In the instruction leaflet, figure J, number 1, 2, and 3 I seem unable to connect it. The above is a pressure washer.
Hi all you need is a 3/4 tap fitting from a diy store.
Maybe a hoselock 3/4 male and female fitting that will fit a standard 1/2" hosepipe. If struggling I can send you a link to the fitting on ebay but if you type in karcher tap connector you will see it by the seller vavcandwash.
Feb 14, 2010 | Karcher 1750 psi Electric Pressure Washer
Clarify application of straight ball valve 1/4 turn
The ballvalve is normally a compression type fitting and so would not normally require soldering, however you could use a threaded adaptor soldered to the copper supply line and then thread a 1/2" ball valve to that then reduce down to the correct thread to meet the tails from your new tap. Or alternativeley you can insert the valve in the supply line, and extend the pipe to nearer the sink to enable easier connection of the tap.
Nick
Mar 28, 2009 | Plumbing
Cold water only very slowly trickles into the washer. Hot water works fine. Cold water has very good pressure and volume at all other sources in the house. The cold water hose at back of washer is clean...
there can be 3 reasons for this I will tell u the easiest way to test this first
Problem1)turn the water off at the blue tap fitting that is proberbly under your sink take the blue pipe off at the washer end and place it into the sink turn the blue tap back on if the water comes out quick then the problem is more then likely your cold water solenoid that is either slightly blocked were it fits to the washer,But if it doesnt come out quick then the other 2 problems are as follows.
Problem2)the blue tap that u turn the cold water on to the blue pipe undue the little screw in the middle of the tap and pull the blue fitting off now with a pair of pliers turn the square metal fitting that was under the blue fitting making sure that the end of the pipe is in the sink if it comes out quick then that is the problem the blue tap fitting is rounded off when ot should be square turn the water of and replace the pipe and turn the water back on the cold water should be better now.
Problem3)the blue tap that u turn the cold water pipe of at the copper pipe is blocked or it has a broken shut off valve inside it this will need replacing these are the only problems that it could be let me know if this is any help to u peter
Jun 09, 2008 | Whirlpool Washing Machines
Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel Logo
62 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
