Question about Acer Cromia Chromebook PC Notebook
My acer chromebook screen went blank suddenly
Screen went blank - won't power up when plugged in
    New Friend:
ALL YOU HAVE TO DI IS HOLD DOWN THE POWER BUTTON UNTIL A SCREEN COMES UP THAT SAYS:
"SUSTEM IS REPAIRING ITSELF".
That screen will stay on and along the top of the screen you will see a percentage progress line of the repair in progress. (It will take around 4-5 minutes)
Posted on Oct 31, 2014
4 Suggested Answers
latelesley
  • 7 Answers
SOURCE: screen picture froze, powerd down, powerd up, blank screen
Hiya
Try pressing Fn F5 or Fn F6, these usually turn the screen off and on. They usually have little blue rectangles on them, representing the screen. If another F key has the rectangles, try that one while holding the Fn Key. As it froze on you first, it could be more sinister, ie a hardware fault, You could try removing the power and battery for 20 seconds, then try powering on again once you replace them. If all this fails, i'm afraid it ack to the shop for a repair.
I hope this helps.
Lesley x
Posted on Jan 25, 2009
ruwidperd372
  • 279 Answers
SOURCE: I hace Acer aspire 4520. Suddenly the screen went
try to re-seating the memory card(s) located on back, clean it if necessary. If it has two cards, try one to another probably one of them is out of order
Posted on Apr 11, 2010
luis_david
  • 407 Answers
SOURCE: ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Posted on Sep 25, 2011
Bought a chromebook acer 14 but it will not turn on after fully charged
hi Diane.
How To Fix Your Chromebook If It Won't Turn On More users are reporting that their Chromebooks are not turning on or the screen stays black. For some the problem comes and goes but for others their machine just stays off all the time. If your Chromebook doesn't turn on there is a few different problems that can be the cause.
This article will go through all the possible causes. I've arranged them in order from simplest to fix to most complex so that you can go through them one by one until your Chromebook turns on again.
So just try each fix and stop when your Chromebook turns on! Cheers!
Fix #1: Connect Your Chromebook To Power Let's start with a very simple solution that worked for one of my customers at my computer shop. Simply take your Chromebook, plug it into the wall power outlet, and try to turn it on.
If that doesn't work no worries move onto Fix #2.
Fix #2: Power-Cycle Your Chromebook
  1. Unplug your Chromebook from power.
  2. Remove the battery is that is possible on your model of Chromebook (it isn't on most Chromebooks)
  3. Press and Hold the power button for one whole minute.
Now try to turn on your Chromebook.
Fix #3: EC Reset Your Chromebook Fix #4: Let Your Chromebook Charge For A Few Hours If the Chromebook is very low on charge it may just need to charge. Let it sit plugged in and charging for around four hours. I suggest leaving it plugged in over night.
Try turning it on in the morning.
Fix #5: Disconnect Battery And Power-Cycle (Advanced) Most Chromebook machines have a built in battery that is sealed inside. However most of the batteries are not that difficult to reach if you have a screwdriver and are careful.
Look up a disassembly video for your chromebook model on youtube and watch it to see where the battery is located.
  1. Unplug your chromebook.
  2. Open your chromebook to get to the battery.
  3. Disconnect the battery cable.
  4. Carefully move the chromebook so that you can reach the power button. Press and Hold the power button for one minute.
  5. Re-connect the battery cable. Make sure the connection is secure.
  6. Close up your chromebook. Plug it in.
Try turning it on now.
or try this link out might help you some more.
chromebook acer 14 but it will not turn on Google Search
Dec 03, 2017 | Acer Computers & Internet
Completely dead acer chromebook..working fine on battery when plugged in died
So did you unplug the power supply and try to restart it? When you plugged the power supply in did the power light come on on the power supply showing it was working? Blue light usually.
Sep 23, 2016 | Acer Computers & Internet
My Acer Chromebook 13 will not power on or charge so can anyone help me with my problem?
try this: remove battery, remove power cable, push and hold down the power button for 1 m (over 60s) do not short time. release the button, insert the power cable. wait 10s then push and hold power button till you see any lite flash release and see if you boot.
some time the static is built and that causes failure to start.
above should clean any static and allow reset of power adapter to function. if yes,. then once you shut down . insert the batter and ;et it charge for 3 mins.. then try to start.
Apr 02, 2015 | Acer CB5 311 T9B0 Chromebook 13 3 inch...
Acer chromebook c7 wont charge
You may need to replace the battery, especially if you have had your Chromebook for awhile.
Nov 07, 2013 | Acer C710-2487 4096MB 11.6" Chromebook
I've been using my chromebook for a year now with
Have you tried "forgetting" the wireless network settings on your account and then reconnecting?
Sep 18, 2013 | Computers & Internet
Monitor won't come on when power on
Try unplugging it and then plugging in again, and make sure the monitor is turned on.
Apr 20, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer aspire 6930 6941 won't boot
won't get the check disc option until it boots up and from your description is is a hard drive problem
take it in for a proper diagnosis
Apr 25, 2017 | Computers & Internet
How do I activate the Hp Link 5 wireless mouse in order to use it with my Acer Chromebook
if not coming on the mouse is either not switched on or not compatible with your chromebook
Feb 20, 2013 | HP Hewlett-Packard Link-5 Wireless Optical...
Nikon d40x suddenly stopped working- won't turn on- was working fine and when I connected it to laptop to download, it turned on , then suddenly went blank.
Do you get the 'push shutter button again' or 'turn off and on again ' message? If so the motor in the SQ unit that charges the shutter and moves the mirror up and down has failed. A very very common problem. The part is on constant back order at Nikon, and good luck getting it anyway as Nikon is going to stop selling parts to anyone in just a few weeks.
May 06, 2012 | Nikon D40x Digital Camera
The power went out here at work and my acer desktop wouldn't log into anything (ie email, internet) when the power came back on. So I clicked shut down and it turned off but now it won't turn back...
try taking out all peripherals like mouse printer keyboard leave screen pluggged n then press and hold the power button for 2 minutes then plug in your mouse and keyboard and see if it boots hope this helps
Sep 14, 2011 | Acer Aspireā„¢ T180 PC Desktop
Acer Cromia Chromebook PC Notebook Logo
975 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
