Question about Onkyo TX-SR605 Receiver
Sky hd to onkyo sr605 getting NO hdmi signal
From my sky hd box via a HDMI CABLE 24AWG to my onkyo sr 605 getting no signal [displays on screen "NO SIGNAL"] I have done the settings ok i think because if i remove this cable out from the sky box and plug it into my dvd player i get sound coming from my onkyo unit so i know its working/and the wireing [ps got no tv/projector yet so cant test for picture]just doing the wireing side to know im getting signal,any help would be very grateful.thanks for reading.
4 Suggested Answers
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Posted on Jan 06, 2009
SOURCE: Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Posted on Apr 19, 2009
  • 4 Answers
SOURCE: onkyo tx-sr608 - when I Plug in HDMI from sky hd box to Onkyo I loose dolby digital sound from Sky input
onkyo receiver
Posted on Oct 31, 2012
Onkyo receiver TX SR 605 saying no signal input from cable when everything appears to be plugged in correctly and powered on and it was working 10 minutes ago. All other connetions (Apple TV, dvd player)...
Hello, I am sorry about your issue. Please plug the cable box into a known good HDMI port on the receiver. Confirm that there are no issues with the cable or plugs. Thank you, CB
May 30, 2017 | Onkyo TX-SR605 Receiver
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
May 08, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Onkyo sr 605
Check with and download the firmware update from the Onkyo web site.
Mar 16, 2008 | Onkyo TX-SR605 Receiver
HDMI SOUND
True HD can only work with HDMI interface and is only available on some newer HD DVDs. Check the DVD to see if the True HD encoding is available.
Feb 11, 2008 | Onkyo TX-SR605 Receiver
Sound won't play thru stereo from t.v.
take the main tv digital opti outto sterio ok on ch or from dish box to sterio on a ch
Feb 02, 2008 | Onkyo TX-SR605 Receiver
Onkyo 605 HDMI Sound
Change the setup in the Hardware control/HDMI/ HDMI Audio...
Jan 17, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 conected to Mitsubishi DLP TV
What I think I did and how I fixed it!
FACTORY RESET ON EVERYTHING!
All you have to do is to do a factory reset on everything, but I thing mostly on your 605, but I would do it on the TV as well. I think what had happened is after I set everything up for the first time, it worked great. As the days when on I started to play with all of the futures the 605 and the TV had to offer. I was turning them on and off to see what everything did. What I think I did was, I turned on something in the 605 that the TV did not know how to cope with. If I had to guess, I think it is the Lip-sink feature (Spelling?) in the 605.
Anyway disconnect everything, look in your manuals of the TV and the 605 to see how to do the factory reset on both. Then turn your TV on. After it does it’s start up for the first time (again), start connecting the 605.
It has been working great for me after I did this. Do not count on help from the people you bought it from or the people who made it. This stuff is so new they do not really know how to fix it.
Robert…
Jan 04, 2008 | Onkyo TX-SR605 Receiver
No video throught HDMI output
press set up go option number 1 then go hdmi monitor and input yes. then press set up again
Dec 11, 2007 | Onkyo TX-SR605 Receiver
Analog RCA input to HDMI output?
You have said the correct thing HDMI is digital therefore Analog will not pass.
You might have RCA audio outputs on your cable box so either send them into the TV from cable or into the AMP then use AMP volume to listen to TV audio (select unused input and remember it is for TV) the key is to remember that cable box will drive the initial vol so raise or lower cable vol then use AMP vol to obtain desired volume.
Nov 29, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver Logo
51 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
