Question about Avanquest PowerDeskPro8.5
Installation files - Avanquest PowerDeskPro8.5
    Guru:
  • 571 Answers
Can you please add more details of your question?
Posted on Jan 24, 2013
I cant install applications contain .jar format in my nokia e71
  • Download the jar file onto your desktop.
    Right-click on the file and choose "Rename." Change the file extension from .jar to .zip. Click "OK."
  • Right-click on the file and choose "Unzip." Your computer will use its pre-installed decompression or zip application to open the file. If your system does not have a decompression application, you can download a free copy of WinZip using the link in the resource section.
    Click "Save" to save the file to your hard drive. Click "Open" after the file has finished downloading.
    Double-click on the file marked "Install" or "Set-up" to install the program files on your computer. If the file does not have one of these options, open the program that the files are intended for and it will automatically detect and install the files.
  • Double-click on the file. The Java Runtime program will automatically detect and open the file. If your system does not have Java Runtime, you can download it free from Java using the link in the resource section.
  • Click "Install" when prompted. Java Runtime will install the program on your computer for you.
    Click "Open" to open the program after the installation process has been completed.
    do in this way you will get it.
    BMW PARTS
    May 25, 2012 | Nokia E71 Smartphone
    Tip
    Cannot install a device driver by using its installation program in Windows...
    ISSUE- You cannot install a device driver by using its installation program in Windows Vista
    OVERVIEW-
    When you try to install a device driver by using its installation program in Windows Vista, you are unsuccessful.
    SYMPTOMS:
    You may experience this issue if the following conditions are true:
    • The driver uses an executable file-based installation program.
    • The installation program was not designed for Windows Vista.
    CAUSES:
    Problems with executable file-based installation programs may occur if any one or more of the following conditions are true:
    • The installation program is incompatible with Windows Vista.
    • The driver is incompatible with Windows Vista.
    • An issue occurs that is related to the user rights that are required to install the driver.
    RESOLUTION:
    To resolve this problem, run the driver installation program in compatibility mode. Or, use an account that has administrative credentials to run the driver installation program. You can also locate the .inf file for the driver, and then manually install the driver.
    Important Before you use one of these methods, we recommend that you contact the device manufacturer or the driver manufacturer for more information about how to install the driver in Windows Vista.
    To run the driver installation program in compatibility mode
    Configure the driver installation program to run in Microsoft Windows XP Service Pack 2 compatibility mode. To do this, follow these steps:
    1. Locate the executable file for the driver installation program.
    2. Right-click the file and then click Properties.
    3. In the PackageName Properties dialog box, click the Compatibility tab.
    4. Click to select the Run this program in compatibility mode for check box, click Windows XP (Service Pack 2) in the Run this program in compatibility mode for list, and then click OK.
    5. Double-click the executable file to start the installation program.
    To run the driver installation program by using administrative credentials
    Configure the driver installation program to run in the context of the Administrator account. To do this, follow these steps:
    2. Right-click the file, and then click Run as administrator.
    If you are prompted for an administrator password or confirmation, type your password or click Continue.
    3. Follow the steps to install the driver.
    To locate the .inf file and manually install the driver
    Use Device Manager to install the driver. To do this, follow these steps.
    Step 1: Locate the .inf file
    Locate the .inf file that is included with the driver installation program. Generally, the .inf file is located in one of the following folders on the driver installation media:
    • In the same folder as the Setup program.
    • In a subfolder that is in the folder that contains the Setup program. Generally, the subfolder has a name such as Windows XP, Drivers, or WinXP.
    If the driver files are packaged in a single executable file, you may be able to extract them or otherwise access them. To do this, use one of the following methods, as appropriate for your situation:
    • Use a file compression program to extract the files.
    If the driver files are packaged in a single executable file, you may be able to use a file compression tool such as WinZip or WinRAR to extract the contents of the driver package to a folder. The .inf file should be among the files that you extract.
    • Use the Windows Compressed Folders feature to extract the files.
    If you do not have the WinZip program or the WinRAR program, you may be able to extract the files by using the Windows Compressed Folders feature. To do this, change the file name extension from .exe to .zip. Then, use Windows Explorer to copy the files from the compressed folder.
    • Extract the contents from the .cab file.
    If there is no .inf file in the driver package, but there are one or more .cab files, you may be able to extract the contents of the .cab files.
    Note This method is usually unsuccessful. Typically, these kinds of driver packages are created by using the InstallShield program. The InstallShield program uses a special .cab format that is not designed to be accessed by tools such as WinZip or WinRAR.
    • Locate the files in the Temp folder.
    If you still cannot access the installation files, try to locate extracted temporary files. Typically, files are extracted to a local Temp folder when you install a program. You may be able to view the contents of the driver package by examining the contents of the Temp folder. To do this, follow these steps:
    1. Remove the contents of the Temp folder. By removing the contents of the Temp folder, you can more easily locate the temporary files that are created when you run the driver installation program. To remove the contents of the Temp folder, follow these steps:
    a. Click Start and then click Computer.
    b. Right-click the hard disk on which Windows Vista is installed, and then click Properties.
     In the Local Disk (DriveLetter) Properties dialog box, click the General tab, and then click Disk Cleanup.
     In the Disk Cleanup Options dialog box, click Files from all users on this computer.
     Under Files to delete, click to clear all the check boxes, click to select the Temporary files check box, and then click OK.
     When you are prompted to permanently delete the files, click Delete Files.
    c. Use Windows Explorer to open the Temp folder. To do this, click Start
    type %temp% in the Start Search box, and then press ENTER.
    d. Start the driver installation program.
    Note Some installation programs automatically delete the temporary files when the installation program exits. Therefore, leave the driver installation program running in the background.
    e. Examine the contents of the Temp folder to locate the driver files.
    Step 2: Manually install the driver
    After you locate the .inf file for the driver that you want to install, manually install the new driver. To do this, follow these steps:
    1. Click Start , right-click Computer, and then click Properties.
    2. In the Tasks pane, click Device Manager.
    3. In Device Manager, locate the device for which you want to install the driver.
    Note To display hidden devices, click Show hidden devices on the View menu.
    4. Right-click the device and then click Update Driver Software.
    5. Click Browse my computer for driver software, click Let me pick from a list of device drivers on my computer, and then click Have Disk.
    6. In the Install from Disk dialog box, click Browse, locate an .inf file for the device driver that you want to install, and then click Open.
    7. Follow the steps in the Update Driver Software DeviceName dialog box to update the driver.
    on May 10, 2010 | Computers & Internet
    I want to install my sound casrd.but i dont know how to install and which file should be installed.
    When you get a sound card it should come with installation software. You shouldn't have to worry about which file to install. When you insert the CD, the "setup" file should run.
    If you have downloaded the file instead of getting a CD, in the folder where you downloaded the file, you will need to click on the downloaded file to extract the various elements of the install. Then go find the "install" or the "setup" file and double-click it and the rest should be automatic.
    Jul 13, 2010 | Computers & Internet
    How can i install when there is only one file .jar
    hi,
    there is no such thing...
    installing games in s3310 is itself a difficult task to find.. and for installing games we need both .jad and .jar files..
    we cannot install .jar file without .jad...and with samsung high cost mobiles, you can directly install .jar files
    I hope,this solves your problem...
    Apr 17, 2010 | Samsung SGH-S5230 Cell Phone
    Installing java applications and games
    hey first of all you need a .jad file for all the java files.
    download jad maker from here
    http://www.brothersoft.com/jadmaker-25179.html
    drag and drop the java files to the jad maker window to create a jad file for that particular java file.
    once you're done copy both the java and jad files to the "other files" directory on the phone.
    Now exit all menus and type in this code: *#9998*4678255#.You should now get a 'Activated' message. [This is to enable java installation.]
    Then go to the other files directory where you placed the jad and java files. Open the .jad file and then click install.
    Once the installation is done you can disable java installation by re-typing that code again.
    Apr 11, 2009 | Samsung SGH-J600 Cellular Phone
    How can install .jar file
    Samsung phones could not rul .jar format...
    but don't worry, you have to find .jad file of same application and use both of them.
    also,there are some programs that make .jad file for a .jar file...
    just look for them on net.
    Ihope this helps...
    Mar 24, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
    T3 sync with PC- Windows XP
    Need to reload software in pc. Dropping stuff. If you found this helpful, please post as so. If you need to knwo how, live chat
    Sep 14, 2008 | Palm Tungsten T3 Handheld
    Problem in installing .jar file
    I m using nokia N-70 music edition, earlier I can install any application of jar extension,but right now I m unable to install jar file, when I transfer file from Computer to mobile, its dosent run, plz help me, bcoz I can install all file .sis,OK 3110 vairas problem
    Jun 25, 2008 | Computers & Internet
    Installing jar files on samsung i300
    in order to install a java application u need two files one is JAD and other is JAR some phones require both and opening the jad file will install the program.. transfer both jad and jar file onto same folder and then install
    Apr 01, 2008 | Samsung SGH-i300 Cellular Phone
    Avanquest PowerDeskPro8.5 Logo
    13 people viewed this question
    Top Avanquest Computers & Internet Experts
    Alun Cox
    Chris Larocque
    Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
