Question about Basyx Furniture
Replacing wheels on a Basyx office chair
Different size stem for the casters or wheels
    Genius:
  • 1,669 Answers
Why not keep it simple? Go on down to your local hardware store with a sample of the wheel assembly and match it up!
Posted on Jan 22, 2013
Where do i find replacement casters?
That type of caster is widely available in bigger hardware stores
Aug 10, 2014 | Mainstays Deluxe Laptop Cart, Black
Does this chair have breaks?
This chair doesn't have breaks but it comes with casters that will hold it in place. Each caster, which should be placed on the floor where you want the chair stationary, is three inches by three inches. The casters are included with the chair/cammode.
Feb 16, 2014 | Generic Lightweight Portable Shower Chair...
Broken chair castor
the stem does not come out but u can find @office chir parts.com
Oct 09, 2012 | Calligaris New York Office Chair
What is an executive office chair?
An executiveoffice chair is a fancy office chair that is made from high quality fabric orleather. Its' unique feature is the high back rest that is generally not found in regular office chairs.
Jul 30, 2012 | Furniture
I need to replace the tires and casters on my probasics wheelchair. I am not sure what I should order and whether the tires come on the wheels ot what.
As a general rule, it is best to replace the caster as a complete assembly consisting of tire and wheel hub. Usually this is the only way to replace casters when the tire is molded on to the wheel hub. It is the best way to replace the caster since you get a tire, wheel hub and 2 new bearings.
With regard to the drive wheels on a manual wheelchair you can get just a new tire. With a plastic mag wheel and hand-rim you can sometimes get just a replacement snap-on tire to replace the existing.(Snaps on like a rubber band using tire irons). If the hand-rim, wheel, spokes, and bearings are worn or broken, you are usually better off replacing the wheel assembly. With power chairs, it is more cost effective to only replace the drive tires and use the existing wheel rims. Hope this helps.
Dec 23, 2010 | Probasics Health & Beauty
How do you raise the metro to make it sit higher off the floor? Is it adjustable
This mnaual wheelchair has dual position rear axles and caster forks to allow seat to floor height changes with no additional components. What this means is that the wheelchair is adjustable in height based upon the position of the front caster wheel axles and rear wheel axles. Raising the axles lowers the chair. Lowering the axle postion raises the chair. If the rear axles of the rear wheels are in the top position you can lower the wheels and raise the chair. Likewise, if the caster axles of the front wheels are in the top hole of the fork then put the wheels and axles in the lower hole to raise the chair. It is easy to accomplish this with basic tools.
If the front and rear wheels are already in the lower holes (the chair is in its highest position) you have another option. This option is a more expensive way to raise the chair by buying 4 new wheels. Lets say for example you have 24" diameter rear wheels. If you purchase new 26" diameter wheels you will raise the chair 1". If you have 6" casters and put on 8" casters this raises the chair 1" in the front. Hope this helps.
Nov 23, 2010 | Everest & Jennings 18" Metro Ic3...
My mother-in-law has a jazzy 113 for about 6-7 years and the 2 wheels broke in half. How can this happen when it is a solid wheel? Please let me know what to do. Its the back wheels.
Liz First Did Medicare buy MIL's chair? If they did contact me @ lennieg2000@yahoo.com and I'll give you more info. Now after that long the tires get brittle and usually need replacement. You can contact the provider where MIL got her chair and have them get the caster wheels for the chair. Hope this helps
Sep 29, 2010 | Pride Jazzy 1113 Power Chair
Front caster wheel has cracked rim, what is correct replacement size?
Bob I can't answer without knowing what chair you have. contact tech service at Drive Medical @ Toll Free Phone: (877) 224-0946
They can help getting the right caster hope this helps you
Sep 07, 2010 | Drive Medical Health & Beauty
Wheel broke of my Power Chair
I assume you are referring to the caster tire, not the drive tire. You will need to check to see if the rim is a split-rim or a solid rim. A split-rim will have 4 or more bolts holding the two halves of the rim together. If you have flat-free tires i.e., foam-filled solid tires, evidenced by the lack of a valve stem which is used to inflate non-flat-free tires (pneumatic), you would remove the wheel from the caster by rermoving the center bolt acting as the axle. Then remove the bolts holding the rims together. Reposition tire on top of one of the rim halves, then place the other rim half on top so that the bolt holes in the top one line up with the holes in the bottom one. You need to buy a couple of bolts that are about 3/4 in or more longer than the bolts that you removed, as you now must press the two halves back together and the stock bolts probably won't reach through. Put the two longer bolts in opposite of each other in two holes and tighten down. When the rims are pressed together, then put the stock bolts in, remove the two longer ones and replace with stock bolts. Place wheel back on the caster. If you have pneumatic tires (requiring air), make sure to always deflate the tire completely before attempting to loosen the bolts holding the rim-halves together. The same process is used for drive tire replacement. If the rims are not split rims, then it is easiest to buy an entire new wheel and tire as getting it back on is quite a chore requiring a press and lots of tequila! It's easy to break the rims. Good luck.
Jul 15, 2009 | Invacare Pronto M51 Power Wheelchair
Changing the dual axle on an Invacare recliner to lower seat
You will need to remove the rear tires and front casters. If you look at the front caster fork there should be some extra holes where you can re-position the caster wheel. Likewise on the hole where the rear tires mounts there should be a hole above it where you can re-mount the tire. So just move the caster and wheel up to the next hole. If there are no holes to move up to then you cant lower the chair. The only other options would be to install a drop seat which you`ll have to purchase from a dealer or install smaller wheels and casters. So, for instance,say you have 8" casters and 24" wheels you would then install 6" casters and 22" wheels. Good Luck and let me know how it turns out.
Jan 16, 2009 | Invacare Lightweight Tracer SX5 Wheelchair...
Furniture Logo
112 people viewed this question
Top Basyx Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Basyx Furniture Expert? Answer questions, earn points and help others
