Question about Sony Handycam CCD-TRV52 8mm Analog Camcorder
How can I turn off recording microphone on Sony Camcorder CCD-TRV52
When recording I don't want audio. How do I turn off mic when recording?
ctf1800
  • 4402 Answers
SOURCE: Sony Handycam Vision ccd-trv308
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Jan 22, 2008
welcomejee
  • 10594 Answers
SOURCE: SONY CAMCORDER CCD TRV 328 rec,problem
Your camera ccd-TRV328 has defect with ccd imager that's why not giving picture in camera / recording mode. This part (ccd imager) needs to be replaced and good news Sony will replace it free of cost.
Please click Sony Official Website for details.
Regards,
Posted on Sep 02, 2008
mistersony
  • 320 Answers
SOURCE: sony CCD-TRV118
The C31:22 error message means that the reels are not turning, or that the sensing mechanism for the reels is not functioning. You can reach a finger inside the mechanism and see if you can freely rotate the reels. If the reels rotate freely, then you have a drive problem. If you cannot rotate the reels, make sure they are not bent in any way. If none of this helps, you will need to have a technician look at the unit. Please be sure to rate this solution. Thanks!
Posted on Nov 08, 2008
welcomejee
  • 10594 Answers
SOURCE: Problem with Sony CCD TRV138 camcorder
Symptom shows bad CCD IMAGER in camera and requires replacement. (IC951 on CD-465 board, mounted at end of lens mechanism).
Nice to know that you are tech person so buy CCD IMAGER from any part store under following part number..
A-7013-219-A CCD BLOCK ASSY (CCD IMAGER) (TRV138/TRV338)
Good luck.
Posted on Mar 15, 2009
SOURCE: sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Posted on Jun 08, 2009
Hi i have a sony ccd tr805e and i have a problem ... the built in mic does not work ... if i hear the audio with a hearphones connected to my camcorder i hear a noise as covering the audio ...
I used to be an Authorised Sony Camcorder repair agent before I retired and a capacitor kit was available (for service centres) to cure many problems including no sound from the microphone. It could be the internal mic itself.
Dec 28, 2016 | Sony Computers & Internet
There is a horrible echo whenever i try to record and then there's a loud noice that sounds like a very high-pitched whistle and i don't know what to do.
This type of audio feedback loop can happen on any mic if you are playing back audio at a loud volume on speakers that are close to the mic while the mic is on - which tends to happen on Skype calls. Try lowering your speaker volume or using headphones to hear the audio, then speak into mic, and the feedback should be reduced.
Apr 12, 2012 | Labtec Microphone Microphone
ATR3350 Microphone: Battery in. Plugged into laptop. Recorded video. ATR3350 Mic is ignored. Audio is still recorded from my Logitech Webcam software. How does this thing work?
You need to tell your computer which microphone / sound source to use.
In he absence of other instructions it is defaulting to the built in microphone.
Normally your sound-card software should detect a new device plugged in and ask you to confirm it. However if it is not doing so you may need to change the audio settings.
How to correct this will vary slightly depending on which operating system you are using.
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls). If your webcam/ microphone is built in to the laptop there should also be a volume control called 'Internal MIC' - disable it by placing a check-mark in the mute box.
NOTE if microphone (or internal MIC) is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it but it is possible you may also need to turn off the microphone in the software for your web-cam.
Feb 09, 2011 | Audio Technica ATR3350 Microphone
Volume ccd-trv318 model
yes i believe the problem is the microphone in the camera, just open up unit find microphone disconect it and replace with exact mic from radio shack catalog...or try to find a mic from another electronic device of the same size ( fixed mine with a mic that was inside a cellphone headset wire.) hope this helps... but i am almost possitive your mic is shot from your syptoms
-Phil
Apr 12, 2009 | Sony Handycam CCD-TRV318 Camcorder
Can't get the external wireless mic to record...
This camcorder will record audio from an external STEREO mic plugged into the top connector on the right side of the unit (under the plastic cover). I find it works EXTREMELY well with the various Sony microphones traditionally sold for MD recording (I use a mid-size one: model #ECMMS907). Some microphones may have too low an audio level for these camcorders. Other microphones may not have a stereo plug, but most of the ones that do (and have a high output level) should work You simply plug in the mic. No fussing with settings should be necessary. The camcorder has an onscreen audio meter that can be enabled. I leave it on all the time, so I am sure the external mic is working (mine has an on/off switch as well as an AA battery -- so I really want to make sure!).
Mar 22, 2009 | Canon HV20 HDV Digital Camcorder
I am having audio issues with my Sony DCR-TVR900 NTSC Camcorder
If the problem is no audio recorded from the internal microphone, then it has likely failed. See http://www.bealecorner.com/trv900/trouble/micfix/index.html for a simple repair procedure you can do yourself.
Dec 17, 2008 | Sony Handycam DCR-TRV900 Mini DV Digital...
Same Cam shutdown Issue
hummm, thats fine. go ahead n let me know of out come for knowledge ;)
May 29, 2008 | Video Cameras
Sony HandyCam CCD-TRV52
download one here:
http://www.iq.sony.com/srvs/DocsConnect/docget.asp?manualid=7182&DL=true
Oct 21, 2007 | Sony Handycam CCD-TRV418E Camcorder
Sony handycam CCD-TRV128 Hi-8 camcorder
if your camera will play any previously recorded tapes , the microphone may have failed due to humidity - usually ; if your camcorder has an external mic input ? an external microphone - will confirm this ;
Jul 25, 2007 | Sony Handycam CCD-TRV128 Camcorder
Video Cameras Logo
83 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
