Question about Garden
I have a poulan 4218 it starts but has to be wide open to run there is no mid range or idle just wide open.
    New Friend:
The carb might need adjusting the adjustment screws my be turned in to far witch is causing it to run wide open and not having slow idle or mid idle
Posted on Jan 22, 2013
Chainsaw won't idle- runs fast only
Gently Tighten the carb adjustment screw fully tight then adjust it out 360 (full turn) then again a further 180 ( half a turn) and your idle speed should be set correctly. Let me know how you get on
Oct 02, 2014 | Oregon Poulan/Poulan Pro 10" Chain Saw...
How can i get my poulan pro 4620avhd to idle ?
I have referenced the Poulan Pro 4218 Manual so you can see a similar troubleshooting guide which should be close to the 4620 version.
Nov 18, 2012 | Poulan Pro Chain Saw 46cc 20"
1994 jeep wrangler engine missing at mid range
check fuel pressure regulator and fuel pressure. should be between 45-50 psi and hold steady.. shut off car and let sit 5 min if pressure drops more than 10 lbs one of the two is bad...
Jul 07, 2012 | 1998 Jeep Wrangler
Where do i find model no. on my 4218 avx 42cc poulan pro chain saw?or is that the model no.
4218 is the model, the key is part of the flywheel, so if the key has sheared it will require a new flywheel.
Mar 17, 2012 | Poulan Garden
So i've been using a poulan pro 4218 all summer, ran like a champ for me everyday all day. then the crankshaft holding the clutch and sprocket snapped.. not a problem bought the part and replaced it....
Sounds like a carb issue, the L screw on the carb adjust the fuel mixture from idle to half throttle, i would richen the L screw by unscrewing 1/4 turn, this should improve the running, however there is a special tool to adjust the screws, part no. 530035560, the screws are fuel, not air screws, increase a shade more if it is still not idling or accelerating properly.
Oct 30, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Runs to fast
You need to adjust the idle and high speed screw settings on the saw. Consult your user manual for tuning the engine.
Feb 13, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Dies running wide open
Hi
Check the air and the gas filtetrs.Change the plug with a new one with the same heat range.Adjust the carb H and L.
High speed H=2 turns and low speed L=2 1/2 turns
best regards savumihai71
Jan 29, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
70 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
