Question about HP Pavilion Computers & Internet
Show me how the hook up at back of the 8260 PC
Trying to connect PC to monitor but forget how, can you help with a diagram please?
    Genius:
  • 1,669 Answers
Check it yourself with the user's manual:
http://search.aol.com/aol/search?&s_qt=sb&q=8260+pc+user%27s+manual&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
Posted on Jan 22, 2013
Im trying to put a gas tank back on a 5 horsepower briggs and straton motor, i forget where the wires hook up and the smmal spring and the linkage rods. is there a picture or something that can show me...
If you have the Model, Type and Code off of the engine flywheel housing you can go to www.partstree.com and put it in on the Briggs and Stratton Engine Brand.   You have to scroll down to the lower part of the page. This should direct you to the correct engine and from there you can select what part of the engine you are needing help with. It will show you a diagram of how the parts go back together.
Mar 28, 2011 | Garden
I'm connecting to a tv with a VGA cable from my Acer netbook. My tv says No Signal. Windows makes the "ba dum" sound when I connect/disconect the cable, but under my display settings, it doesn't...
Don't forget that the TV source or input needs to be set to "PC". Once that is done turn the netbook OFF, then plug the VGA cable into the netbook and start the computer. The computer screen should automatically show up on the TV.
Nov 10, 2010 | Acer Aspire One PC Notebook
I have a toshiba satelite p2050-57802 laptop and im trying to figure out how to hook up monitor to laptop. Screeen got broken on laptop and misplaced manual. Can you help please ?
There is a monitor connection on the back of the pc, next to the ac adapter connector. Just plug in your monitor to it and make sure you plug the monitor's power cord into an electrical wall outlet.
Oct 06, 2010 | Computers & Internet
I am trying to hook up my monator to the computer(cpu) and only nave one wire to it. I think there should have 2. I was looking for a hookup diagram. Can't find one HELP
There should be two cables coming from your monitor -- one that hooks up to the computer and one that goes to the outlet, for power. The outlet cable looks almost like a normal power cable, with three prongs on one end and three holes on the other end.
The cable that hooks to your computer is likely a serial cable, with a blue connector that hooks up to the blue port on the back of your PC. Instead of the serial connector, you might have a DVI connector, which is skinnier and should have a removable white cap on it. If your computer has a DVI port, than you can use the DVI cable, otherwise you'll have to use the serial cable (with the blue connector).
Hope that helps.
Jul 14, 2010 | Dell Dimension 8200 PC Desktop
Can't connect to external monitor or to Sony bravia tv. When vga connected nothing happens at all on laptop but external monitor says " check cable" ( have tried another cable ). If connected in power off...
You need to:
- Connect everything with the laptop turned off
- Boot the laptop
- Use the Fn key plus F8 or F9 (I'm trying from a small picture of the keyboard!) to cycle through the external display options.
Dec 22, 2009 | Toshiba Satellite Pro L300 Notebook
How do i HOOK UP MY GATEWAY 506GR IN MY NEW OFFICE,,,,THERE ARE SO MANY PLACES FOR,,,? CAN ANYONE SHOW ME A DIAGRAM? IT'S FOR MY NEW BUSINESS AND I'LL NEED TO HOOK UP PHONE , INTERNET, AND SERCURITY...
Ideally, you should place the desktop below a table, which has a sliding sub-table for the keyboard/mouse. Since you mentioned music, do you want to hook up the computer's audio output to your Gym's speakers? In which case, in the back panel, (if you have an inbuilt sound card), you should find a audio out jack. Connect the ausio cable to your music system input.
I would recommend to use a flat LCD monitor, which saves a lot of space on your table to do other stuff.
If you are using a broadband network connection, the modem should be pluggable into the USB slot of the PC. You should also be able to locate the ethernet socket off your motherboard, and connect the modem to it. (The ethernet cable looks like a telephone cable, only slightly bigger)
Most camera security systems come with software which allows you to monitor your business areas from one spot. You will need to connect the surveillance cameras to some sort of a hub i guess which goes into the computer via USB or firewire. Somewhat like a webcam...
Hope this helps. All the best!
Aug 11, 2009 | Gateway Computers & Internet
After unhooking Dell monitor, can't get it to work again.
hELLO THERE:
You shouldnt have to hook both of them up.
turn off the computer and monitor unplug. the power cord to the power supply. leave the monitor hooked to the computer
remove the side panel on the left side of the computer.
look and find the wiring harness from the powersupply to the motherboard and remove it now press the power button on the computer for 1 minute this releasess any (esd) or Electronic Static Discharge. that may have built up over time.
wait for 3 minutes
during this time this will be a good time to blow out any dirt or debris that may be in the inside of the computere
now reinstall the wire harness back to the motherboard and connect everything back up and turn on the computer and then the monitor and see what happnes you should be ok after this ok?
let me know how this goes ok and please dont forget to rate the solutions that i have provided for you
best regards michael
(USN RETIRED)
Aug 06, 2009 | Dell UltraSharp 1905FP LCD Monitor
Can't find where to get the input from red/white/yellow cables
if u have a look on the back of the pc, u shud see a card with a lot of connectors on it, video, audio and an antenna, if this has then connect to the video in connector and set the tv tuner software to composite and then it show what is bein imputted...
hope this helps
Feb 15, 2009 | HP Media Center m7250n (ED842AA) PC...
Trying to get hooked up
I made a hook up from the shr 1040 to a pc monitor using a VGA converter box. Cost less then 40 ( check amazon) and simple to use as well as still use your pc on your monitor,
Aug 27, 2008 | Samsung 4 Channel Dvr
Computers & Internet Logo
15 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
