Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Broken door handle needs replacing
I need to replace doorhandle on model# 10650599003
  • Anonymous Mar 17, 2009
    How can I remove the door handle?
  • Anonymous Mar 14, 2014
    need to replace the door handles.
  • 410 Answers
I assume you need a paert number for the handle. according to the model number you gave I need to know the color of the refrig in order to get you the correct part number or you can go here input your model number then find youre part yourself. just remeber your looking for your color handle to be sure and get correct one. peyton
Posted on Jan 27, 2009
Both back doors are stuck. My window is broke it's cold in Detroit, can anyone help? The shop want $100
How to drill open a honda door that's stuck or won't open (no ...
? 0:19
www.youtube.com/watch?v=xHX6Up7HCfs
Jul 2, 2006 - Uploaded by SadieSummer How to drill open a honda door that's stuck or won't open (no real info on .... How To Install Replace Broken Rear Outside DoorHandle 1996-00 ...
How To Install Replace Fix Broken Rear Outside Door ...
? 9:52
https://www.youtube.com/watch?v=bUV6BZfVxDY
Jun 15, 2011 - Uploaded by 1A Auto Parts
How to Open a Honda Door that's STUCK! ... How To Install Replace Broken Rear Outside Door Handle 1996-00 Honda Civic - Duration: 5:47.
Honda Passport driver door lock stuck Questions & Answers ...
www.fixya.com > ... > driver door lock stuck > Cars & Trucks > Honda
Honda Passport cars & trucks driver door lock stuck questions and answers. Ask your ... 1996 honda passport defrost has stopped working ... dash vent ... Back seat doorsdo not open ... stuck. Any ideas of how to get them to open? It seems that ...
Oct 29, 2015 | 1996 Honda Passport
2010 Hyundai sonata passenger and driver door handle repair. how to repair doorhandles?
if they are broke. then you might have to replace them. they make stuff able to break to drive people nuts.
Mar 18, 2015 | 2010 Hyundai Sonata
Doorhandle
for passenger side:
1. unclip screw cover 'center flap' of inside door opener plastic cover, flap is 3/8"x 3/8" (center of plastic cover)
2. remove phillips screw now showing
3. push fabric panel (edge of door opener plastic cover-at hinged end of chrome handle) to allow uncliping of edge of plastic cover (top rt & lwr rt (for passenger side) of plastic cover)
4. open chrome inside door handle to allow plastic cover to be removed-slide plastic cover toward rear, free end of door to remove cover
5. remove switch panel-gently pry with wide non maring pry bar (cover wide blade screwdriver using cloth) do rear of sw panel 1st (don't pry front edge)
6. slide switch panel toward rear to allow removal
7. remove large phillips screw under sw panel
8. remove the 2 plastic covers near top, hinge edge -use plastic spoon handles to encourage caps to pop off. May also require small screwdriver approx 1/8" in to complete pop off
9. remove the 2 phillips screws w/ captive washers
10. remove 3 phillips/hex screws along the bottom inside of door panel
11. on outside/rear edge of panel push the 2 center pins of each in about 1/8"-this allows the clip to be pulled out w/ pin pushed in
12. remove plastic cover (REAR OF SIDE MIRROR)-pull window edge up and back.
13. lift rear of door panel (not hinge edge) up allow hinge edge to pivot around lower pin in door (hinge edge)
14. remove the 2 rt edge "L" brackets (gently pry center plastic pin out) (note the color and replace as removed)
15. slowly peel the clear plastc away from the non hinged end to expose the plastic panel with 3 phillips head screws
16. remove the 3 screws and panel for access to door handle.
17. using access area now available unlatch the rod attached to exterior door handle (unclip plastic to rotate clip up to allow rod to slide out-toward hinged edge)
18. using access area now available remove rod from ext door handle from inside door area
19. remove the 3 -10mm head bolts
20. remove the ext door handle (bottom edge out first)
reverse order to replace door handle
Mar 24, 2014 | 2003 Toyota Avalon
Door handle replacement.
the inner door panel is held on with plastic or metal clips and screws or bolts..these all must come off/out before taking the panel off..once off there should be holes to stick the socket needed to unbolt the doorhandle and remove it..need someone with small hands..
Dec 22, 2013 | 1995 Toyota Camry
How do you take the door off? I too have a broken handle and door...
If only the door handle is broken, it can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The door handle on this model has two parts (items 3 and 8). Depending on what is broken, you may only need to order one or the other. Both parts, combined, is still only about $20. The part numbers are WB15X10119 and WB15X10120, respectively.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges.
If you have any questions, please post back and let me know. I hope this helps you.
Jul 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The lower handle retainer is broke
If the model number is correct, this is a parts illustration of your oven door:
http://pcappliancerepair.com/model-display.php
If you have any questions, please post back with your and let me know. I hope this helps you
Jun 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
It's broken
The door handle can easily be replaced on most microwave ovens. You just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to access and/or replace the door handle:
The cost usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. However, price and configuration of your oven also depends upon the MODEL NUMBER. If the model number is correct, the part number for a replacement door handle is WB15X10023.
Jan 29, 2010 | GE JVM1631 Microwave Oven
Inside doorhandle replacement
the easiest thing to do is pull it off it may take a little longer but it cuts down on breaking the panel if your not careful i mean a panel takes a few seconds to pop off
Aug 03, 2008 | 1992 Suzuki Swift
Ford xd door handles
order a chiltons repair manual for $19.95 from
autozone or any other parts store.
Jun 12, 2008 | 1983 Ford Fairmont
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
221 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
