Question about Toshiba 42H82 42" Rear Projection HDTV-Ready Television
Toshiba 42h82 no sound
I have a Toshiba 42h82 that I got in 2003. Today when I turned it on there was picture, but no sound. I unplugged the tv but the problem is still there. Any advice?
  • 1 more comment
  • John Rodriguez Jul 19, 2007
    Cable is straight to tv. Only things connected to tv are cable and x-box.
    the switch in the back has been turned off since I get the tv. Checked menu everything is on.
    Checked menu and everything for sound is on. The switch in the back has been off since I got the tv.
  • 147 Answers
Are you using a Cable Box?Using HDMI? Need more Info........
Posted on Jul 19, 2007
  • Perry Mellott
    Perry Mellott Jul 19, 2007
    Check your Menu ,Under Sound and Make sure it did not get turned off also in Back by Cable going in See if there is a Switch for Internal and external Sound,Let me Know TTech
  • Perry Mellott
    Perry Mellott Jul 20, 2007
    The Switch since you never moved it Flip it back and forth see is your sound gets Restored
6ya staff
SOURCE:
It has shrunk to about 6 inches all the way around the screen so the total picture sizr is 36 inches instead of the 42 inches otherwise clear picture little fuzzy when turning on but becomes a clear
Don't know what wires your using to connect to tv. It does matter, sometimes the connections go bad, either at the tv or cable box. Have you tryed to stretch picture in settings?
Feb 10, 2012 | Toshiba 42H82 42" Rear Projection...
Toshiba 42H82, no sound after fixing hyperboard.
Search for the audio amplifier - it's a chip with a radiator on it - the jack for the speakers should be close by.
Jan 09, 2010 | Toshiba 42H82 42" Rear Projection...
My toshiba rear projection TV's picture just went black. Sound is good just a black screen.
high voltage is not coming up. possible fuse locates on power supply board on the right if you are sitting behind set with back off. if fuses are good, possible horizontal output transistor shorted. sounds horrible but easy repair
Nov 10, 2009 | Toshiba 42H82 42" Rear Projection...
Have a Toshiba 42H82 rear projection TV
Sounds like a power supply problem. You will need your tech again.
Nov 13, 2008 | Toshiba 42H82 42" Rear Projection...
Toshiba 42H82 problem
bad capacitors on the hyper module. there are 11 surface mount capacitors that need to be replace and that should fix it. the caps themselves only cost around $14 for all of them together
Jan 05, 2008 | Toshiba 42H82 42" Rear Projection...
NO SOUND
Someone answered this as a premium solution two years ago :). There was a switch on the rear of the TV that was in the wrong position.
Nov 18, 2007 | Toshiba 42H82 42" Rear Projection...
No pic no sound
sounds like convergence drive ics or power supply.would be about $350.00 +++ for these type of repairs
Sep 07, 2007 | Toshiba 42H82 42" Rear Projection...
Toshiba 42H82 RPTV: Sound but no picture
It sounds like the 200v supply to the crt's is missing. this is the source for driving the tubes, other than the high voltage generated by the flyback transformer. If the set got really bright gray with wome white lines that are kinda on a diagonal, this is generally the cause. the source for this voltage is a diode on the secondary of the flyback transformer.
Jul 11, 2007 | Toshiba 42H83 42" Rear Projection...
Jittery picture
the jittering will get worse with on time this tv needs a hyper module and some are still available for replacement id get a new hyper module or have it rebuilt needs caps in the module forget about doing this repair yourself just like the guy on csi miami "they never listen"
Dec 06, 2006 | Toshiba 42H82 42" Rear Projection...
Toshiba 42H82 42" Rear Projection HDTV-Ready Television Logo
129 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
