SOURCE: Kyocera FS1000+ firmware upgrade
Kyocera won't give it to you. You will have have an authorized Kyocera technician load it.
SOURCE: kyocera Km 2050 firmware need to be upgraded
Firmware up dates for these machines need to be done by someone with experience. There are two seperate for the machine, printer, fax, and scanner and are done differently. THe updates are provided by the manufacture to dealers that are trained to work on these machines and should not be done by others because there can be a negative outcome if done improperly, leaving your machine nonfunctional.
That is the bet advise I can give you.
