Question about Whirlpool Duet GHW9150P Front Load Washer
Is there anyway to have the whir;ppool duet washer just spn? not rinse and spin?
  • Whirlpool Master
  • 17,130 Answers
Choose from the MANUAL mode. refer to the owner's manual to select the manual spin mode.
Posted on Jan 22, 2013
SOURCE: Duet washer leaks during use; rinse cycle?
I am having the same problem with my Duet and would like to know if you will send me the link? nitewind44620@yahoo.com
I have found socks in the boot and I thought that solved the problem which was a tip by someone, but my wife says its still is leaking from time to time. Would like to see what this entails on the change and the cost of the seal. Thanks for help in advance.
Posted on Jan 28, 2008
Coldcut
  • 1554 Answers
SOURCE: My whirlpool duet washer indicates "5d"...
unplug.
open the bottom panel,3 screws on bottom
check the drain plug ,
remove the plug , mop up water ,
look inside for clogs ,
look above the ball,
look inside the propellers, spin the pumps propeller by hand.
reassemble.
close panel.
finally .
feel around the inside of the front rubber gasket for items.
Posted on Oct 31, 2008
fridgetech
  • 473 Answers
SOURCE: Code F1 @ Whirlpool Duet Sport Washer
An F1 is almost always a defective main control board. Could try unplugging the unit for a few minutes and see if it will reset. The part # for the board is W10110072. Sears sells it for $119.46 http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WFW8300SW01&productCategoryId=0153200&brandId=1198&modelName=RESIDENTIAL-WASHER&diagramPageId=00003&componentDescription=CONTROL%20PANEL%20PARTS&documentId=W0607261&backToLink=Return%20to%20Sub%20Components%20list.
Posted on Dec 12, 2008
aborcass
  • 2651 Answers
SOURCE: My Duet washer doesn't run
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
sure the pump is running.
4. Check the drain pump filter for foreign objects.
Posted on Jan 11, 2009
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Posted on Mar 01, 2009
Wont rinse or spin
I think your washer's drive belt has broken, Joanne. You'll need to have someone replace it. That's a pretty easy fix, but they'll need to know your washer's model number before they arrive so they can bring the correct belt to fit it.
Aug 06, 2014 | Indesit Washing Machines
Lg intellowasher wf t8501tp
My washer WF-T8501tp shows a PE error code.
Can anyone tell me what's wrong with it
Nov 17, 2013 | Washing Machines
Whirlpool Duet sounds like a jet engine during the spin cycle
There should be a whirring sound to it. If it is excessive, bvearings might be bad
Aug 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
How do I get my duet to drain and spin only. I do not want to rinse.
I have a Whirlpool Duet, though possibly a different model. I had the same question. I finally figured it out. On p. 14 of the manual, there is a section "To drain the washer manually". This says to select the RINSE/DRAIN & SPIN cycle and deselect the EXTRA RINSE option. In this case it cancels ALL rinsing for the cycle. This is how you get a spin-only cycle! Talk about idiotic, obscure user-interface design and bad manual writing!!! Didn't they think people would want clear instructions how to get a spin-only cycle?
If you have trouble with things being too wet after washing & needing an extra spin, you should try lowering the spin speed when you wash. This is what the BULKY setting does. If you have an unbalanced load, the washer cannot get up to the high spin speed the normal cycle calls for, and it is so dumb that it gives up and gives you a soaking wet load at the end instead.
Feb 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Have a whirlpool front load duet. Will not rinse or spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Mar 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
Stopped during rinse/spin cycle
try removing the bottom front panel and see if there is something blocking the drain.
Oct 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
56 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
