Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
How do you fix a Triton TriClean Wash System Quiet Power III that wouldn't drain?
I have the Triton TriClean Wash System Quiet Power III and there are at least 2 1/2 inches of water, because it wouldn't drain. How do you resolve the problem?
4 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: triton triclean not draining
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Sep 26, 2009
SOURCE: GE Profile Triton Triclean wash system - quiet
I hit the pump with a hammer and it started washing and continues to do so. Thanks
Posted on Nov 16, 2009
  • 3 Answers
SOURCE: GE TriClean Quiet Power I. will not drain. Have
Check the corragated pipe from the filter to the sink drain. I had the same problem and cleaned the filters aswell didnt fix it.
It was a bread bag tie that got past the filter that was stuck in the drain pipe.
Posted on Nov 17, 2009
Our GE Triton TriClean III didn't drain, and now won't even give me an "on" signal when I lock it. Is it dead?
Check the circuit breaker before you make any hard-and-fast decisions. Find the appropriate circuit breaker, turn it off, wait fifteen seconds, then turn it back on. Now try it.
Aug 12, 2014 | Dishwashers
Sanyo washing machine problem
Check for debris blocking the drain pump. Also check for power to the drain pump.
May 04, 2013 | Washing Machines
I have a Whirlpool Gold Quiet Partner III dishwasher. When I unload the "clean" dishes, there is some type of film or crud on the dishes. I have to hand wash them to get this off. It seems like a...
You need to check the drain system completely, look for plugged screens, pump impellers, valves and the drain hose. You need to witness a large volume of water flow during drain.
Sep 19, 2010 | Whirlpool Dishwashers
My 6 year old Whirlpool dishwasher is loud
This is a bad wash pump. Looking at about $175 for just the sump assembly. You could do it yourself, but unit would need to be uninstalled.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
GE TriClean Quiet Power I. will not drain. Have cleared all the filters.
Oct 04, 2009 | GE Dishwashers
No power or functionality - DOA
Ensure power is available to the unit, check the door switch for proper operation
Mar 23, 2009 | Dishwashers
RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Mar 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore quiet pak III dishwasher has a whining noise
Most of these dishwashers have separate circulation and drain pumps and there is a good chance that there is an issue with the circulation pump impeller issue under the lower wash arm. The bottom panels under the door can be removed to check it out.
Chris Z --- www.repairclinic.com
http://www.repairclinic.com/Kenmore-Dishwasher-Parts
Jan 25, 2009 | Kenmore 24032\24036 Top Load Washer
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
62 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
