Question about Kenmore Dryers
Kenmore 700 series dryer little temperature difference between delicate and high
I have a Kenmore 110.67761600 that is a couple years old. My wife says the temperature difference between delicate and the highest (cotton) is negligible. I took the bottom panel off today and cleaned out the lint, confirmed the coil isn't shorted and measured the exhaust temp on the lowest and the highest. On delicate the range it cycles between 120F and 150F. On cotton (highest) between 120F and 160F. Note: I was using a quick-reading kitchen thermometer. What else should I be checking? How can I tell what the normal temperatures should be? Thank you.
  • markdigger69 Jan 22, 2013
    Correction - delicate 120-160F and high 120-170F.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
Using that thermometer I am guessing that the readings are close to what they should be. Typically there is not as big a temperature change between the two settings. What made her first think there was a big problem in the temperature settings?
Posted on Jan 22, 2013
Testimonial: "Vince, thanks for the reply. My investigation was prompted by my wife's feeling that even on delicate it was too hot. A 10F difference between the lowest delicate and the highest (cotton) seems strange. Perhaps it is due to what I'm measuring with? Any idea where I can get the specifics on what the temperature range should be?"
jtbjtb
  • 135 Answers
SOURCE: Kenmore Dryer 90 Series shutting down. overheat?
Your motor is very likely overheating and needs replacement. A simple test is the motor will be so hot you cannot even touch it. Hope this helps!
Posted on Jan 05, 2009
  • 130 Answers
SOURCE: Kenmore dryer 110.64962300 will not heat. I
check the thermal switch. it looks like a torpedo with 2 wires attched to it. it is on the back of the dryer after he back is off. it is located on the dryer line usually near the bottom.
Posted on Feb 23, 2009
tony2155
  • 64 Answers
SOURCE: Dryer runs fine but no heat
change the fuse in back of the dryer
Posted on Jun 23, 2009
Jahn27
  • 1554 Answers
SOURCE: My kenmore 90 series gas
What causes the dryer heating to cycle off and on is the cycling thermostat. Therefore, the cycling thermostat is malfunctioning if the dryer doesn't cycle off and on in the right temperature. Verify this by bypassing the cycling thermostat located on the blower housing alongside with the thermal fuse.
Make sure power is disconnected then disconnect the cycling thermostat wires and connect them together. Insulate the connection properly then reconnect power and start the dryer. If the dryer continues to heat up and seems to overheat, the cycling thermostat is indeed malfunctioning and needs to be replaced. Do not run the dryer fro long with the cycling thermostat bypassed or else you will end blowing up the thermal fuse, thermal cut-off, and/or the high-limit thermostat.
Indicate the exact model number of the dryer should you need further assistance. You don't have to accept or rate this solution in order to post comments or information. But accepting a solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need assistance regarding the issue stated herein.
Posted on Jan 01, 2011
TheMobilian
  • 8220 Answers
SOURCE: kenmore dryer problems
I worked on one with the same problem check it out:
DRYER TUNE-UP FROM PAW PAW
Posted on Jan 02, 2013
Testimonial: "PawPaw, You are the man! Want to move to Baton Rouge to help out over here? Papa"
Dryer warms..... but not enough heat to dry...about 10 years old 80 series Kenmore electric dryer
Probably has a broken heating coil...as the temperature goes up it expands and moves from natural position of touching....that would give the false indication of continuity in the coil when it cools back down and touches again. Visually inspect coil.
Nov 02, 2013 | Kenmore 800 7982 Dryer
The Dryer is getting hot.put there is no change in heat when you change setting to delicate are cotton,on how the heat is the same
You have a bad temperature switch or if it has a small board that could be the problem as well I would recommend a qualified service technician come look at it to rule the problem out it will save you allot of time and money sorry for the troubles hope this helps.
Jan 16, 2011 | Kenmore 700 6972 Dryer
I have a Kenmore Electric Dryer #76974150. It only works right the higher heat setting. Will not heat at all on the low heat settings? Any ideas?
If the dryer is running then the thermal fuse is okay.
The temperature is controlled by three parts. There is the operating thermostat which is on the blower housing and is rated at 150 degrees. This is high heat.
The operating thermostat sits in a thermostat heater which is controlled by the temperature switch. The temperature switch controls how much voltage passes it to the thermostat heater. This is how we achieve lower temperatures. There is about a 15/20 degree difference between high heat and low heat.
The restricted vent may have caused the appearance of the dryer running hot.
I would suggest you check the temperature coming out of the exhaust. It can be checked with the vent hose pulled off. Any thermostat with a range between 120 degrees and 160 can be used. With the vent removed check the temperature of the air in the exhaust. At high temperature it should cycle between 135 degrees to approximately 155 degrees. This is high heat.
If you turn the temperature switch to a lower setting such as delicate you should see a lower temperature in the exhaust. It may only be 15 degrees lower but it should show a lower temperature.
I hope this information helps to resolve this problem.
Jan 08, 2011 | Kenmore Dryers
I have a Kenmore 64812 (110-64812200) electric dryer that produces a high heat at every temperature level, even "delicate/cool" is hot. With two thermostats and a fuse, what could be broken first?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Thermostat is bad...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 05, 2010 | Kenmore 64812 Electric Dryer
Kenmore 500 series dryer blows cool air only
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 10, 2010 | Zanussi TC180W Electric Portable Dryer
Gas never ignites in any cycle in a 10yr old Kenmore dryer.
Chances are your igniter has gone bad. It must pull atleast 3.2 amps to open the gas valve and ignite the gas. A new igniter could probably purchased for 20 or 30 dollars.
Mar 13, 2009 | Dryers
Kenmore dryer only heats on delicate
I am not familiar with this particular dryer but most of the Kenmore family use different thermostats for different temperature. They are usually located in the rear and are clustered on the blower housing. Take the two wires off one thermostat at a time and test. It should be closed when cold if not replace it (Usually around $15 each) You probably have a very dangerous clogged exhaust. This will cause thermostats to fail. and can cause a fire. CLEAN It out and dont use flexible plastic duct pipe. The other cause of thermostat failure is if the washer doesn't spin properly and the clothes are too wet when dried. A properly operating dryer will not take much longer than 45 minutes max to dry a load.
Jun 14, 2008 | Dryers
how to install rubber belt on kenmore gas dryer number 110.72712101 ?
Jun 14, 2008 | Kenmore Dryers
Kenmore dryer won't heat on low temp
Hi , the high temperature causes the heat sensor does not work properly , in delicate setting are having heat , the heat sensor are busted or open elements was not heating .
Jan 25, 2008 | Dryers
Dryers Logo
232 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
