Question about ASUS P5PL2 Motherboard
Fan error at boot up - ASUS P5PL2 Motherboard
  • ASUS Master
  • 3,606 Answers
Hello the manual can be downloaded here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5PL2&p=1&s=22
By selecting your windows system.
Open the manual folder, and click global for download.
Adobe reader, is needed to read the content.
I think you have a bad power supply, try to renew that.
Make sure the 4 pin +12 volts atx connector is properly connected.
Look also for bad caps on the mainboard:
If they look like this, the mainboard is dead.
It does not pay, to let them be changed.
Good luck
Posted on Jan 25, 2013
Gateway m255 laptop cpu fan wont let me boot up
open your laptop up and make sure the fan cabels are in correctly if not push them in if that dosen't work get a new fan for it
Jun 15, 2012 | Gateway M255-E Notebook
When the computer boots up. It makes almost a grinding noise and I get an error msg, saying the fan is failing. But it does boot up by hitting f2 which is one of the options after the error msg. The other...
The only resolution other than replacing the fan by sending the PC to repair, is to clean the fan.
Power Off the desktop
Open the side pannel using the thumb screw or the philips screwdriver
You will see two fans in the unit, one on the processor heat sink (CPU Fan) and other on the back (System Fan)
Try to clean the fan by blowing air using a hair dryer or a vacum cleaner (in light mode)
Put back the side pannel
Power on the PC to check for error message
If it's still there, you need to replace the fan if it wont allow you to pass through using F2
Regards,
Shrey
Jun 01, 2011 | HP Compaq Presario SR1830NX PC Desktop
WHEN BOARD BOOTS ERROR 512 - CHASIS FAN NOT DETECTED APPEAR LET ME KNOW HOW TO DISABLE THIS ERROR it does it every time i start, or restart the computer, and i have to hit F1 to get it to boot, what...
hi this is a setting in the cmos or bios you have to hit delete key or F2 depending on make of system to get into the menu, locate the setting for the chassis fan speed then disable that and you should not see the error on boot again...hope this helps
Jan 14, 2011 | Computers & Internet
I just installed a fan for my aspire x3200 and not it won't boot up. i found my Acer Recovery Disk but it's 1 of 2 . where can i go to download the boot up disk
Pfft. Before breaking things down to the minimum (and working up slowly to complete, to find the component stopping boot from happening;) just make sure the fan plugs and your videocards' seating in the PCIx slots are perfect. It won't boot if the BIOS is set not to boot when the CPU fan hasn't spun up. That's classic 4-pin-fan raison d'etre. Failing that, give the proper error or stopping point in the boot process and nevermind the recovery disks.
Jan 05, 2011 | Computers & Internet
Fan error and the fan is ok
Check the fan on top of processor is running peperly by keeping the pc opend
Oct 13, 2009 | HP Compaq Motherboard
At boot up, my Averatec 3150HS displays the error message "north bridge fan error, press F2 to continue" I can't find the fan.
Hello there:
boot into bios and look at the advanced section and see if the bridge fan is located there and if it is just enable it than press the f 10 key to save and than reboot the system
Aug 15, 2009 | Averatec 3150H Notebook
I have to hit the f1 key to continue the bootup process. Then I get a defective fan error message, but the fan is running, becasue I can hear it.
there may be more than one fan-- there also is a setting in the BIOS to disable the fan warning if you are SURE that the fan it is monitoring is working correctly.
Jun 24, 2009 | Gateway M350 Notebook
Re: t40 ibm fan error
Are you talking about the original fan being good or the replacement? If it's the original, then your problem may lie with the processor or mainboard. Try the download first, you will need to access another computer to make a bootable disc for the download to clear it. I believe with IBM you can make a bootable floppy or CD. If you have a floppy for your machine, some don't. Once you've made the disc or floppy, you will need to enter the boot menu, and boot from the proper drive. I'm out for the night, but I'll be back in the morning. Let me know.
Jul 29, 2008 | IBM ThinkPad T40 2373 Notebook
IBM RISC 6000 Error code
POWER supply failed or FAN failure 888-103-409-094
Aug 30, 2007 | IBM RS/6000 7013 (57FTOJ50) Server
Fan error during boot-up
Power supply, that can be the cause. Did you try disconnecting few devices to check if the CPU fan has enough power to turn itself on. Usually motherboard will have two connectors for the CPU fan, you may try connecting it directly to the power supply. Also Check through the BIOS and see if there is a setting to disable the CPU Fan monitor (Hardware Monitor??) It should be where the temps and voltages are. The BIOS in most computers has an option to monitor a CPU fan. If none exists, then the option needs to be disabled. I am assuming the error is occuring during the BIOS stage of bootup. If the error occurs in Windows, it may be that some software has been installed to monitor a fan that doesn't exist. Sometimes monitoring software comes on the motherboard CD and someone may install it, thinking it is a driver. It is not necessary. Good luck!
Jan 13, 2006 | HP (D9820-60007) Motherboard
ASUS P5PL2 Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
