Dead CMOS battery on an AST Advantage! Adventure 575
Cannot find the cmos battery on the motherboard for an AST Advantage! Adventure 575
  • 32,281 Answers
Most motherboards use a coin size 20mm dia, 3 volt lithium battery type CR2032.
Posted on Jan 23, 2013
crayzeetrayn
  • 837 Answers
SOURCE: CMOS Battery location on samsung vm8000
cmos battery is underneath. Take off fan cover. remove fan screws x 4. Then lift black cloth on right hand side. You will see the offender. Lift the battery from the left hand side gently with a small flat head screw driver....
Posted on Dec 10, 2008
enuro12
  • 116 Answers
SOURCE: P4S5MG/GL+ MOTHERBOARD
Sounds like a heat issue, is the CPU fan spinning?
Are any of the capacitors swollen?
Posted on Oct 13, 2007
colliewob
  • 778 Answers
SOURCE: ECS motherboard dont start up when i clear the cmos
usually clear cmos is a 2 pin jumper you may have used the wrong one to clear cmos
Posted on Jul 27, 2008
  • 158 Answers
SOURCE: CMOS Battery do no work
Just change your CMOS battery with a new one and after that goto the bios settings and update the time and dare.
After that just save the settings and then check that the warning message is coming or not.
If its coming then it means you need to change the CMOS jumper settings.
Posted on Mar 09, 2009
SmartAviator
  • 449 Answers
SOURCE: CMOS battery low. I changed the battery but the message keep reapearing
Pull out the battery and clean the contact and try again. It may solve your problem. (ehteshamhusain@gmail.com)
Posted on Jul 19, 2009
Schematics for pavilion501n motherboard
In order to locate a schematic for a specific motherboard, you need to know the motherboard's manufacturer name, mode number and revision number which is stamped on the board. You cannot ask for a computer's motherboard diagram based on the computer brand name and model number.
How to Check Your Motherboard Model Number on Your Windows PC
You can use the the aforementioned link to also get the same info specs of the motherboard without opening the case by using the Command line (CMD.exe) or by downloading a GUI based software app.
However, I prefer looking at the main board for the stamped info.
How did you determine that the CMOS chip is re-configuring itself?
Are you confusing the BIOS with CMOS, which are two separate and distinct components.
If the CMOS battery on the motherboard grows weak, or becomes dead, your BIOS settings will reset each time you power off the computer.
Most CMOS batteries are replaceable; some manufacturers solder them in place.
One of the first tell tale signs of a weakening or dead CMOS battery, is having to reset the system clock.
Try changing the CMOS battery; make sure your computer is unplugged from the wall outlet (or Back-UPS); then replace the CMOS battery; plug the computer into the wall outlet (or Back-UPS); power up your computer, enter the system BIOS and configure it to your specs; remember to save the changes; warm reboot; after POST and O.S. start-up; turn off the computer normally- wait 10-20 seconds, do a cold boot to verify that the system BIOS configuration did not change.
Unless you had an electrical surge or spike that would damage the CMOS chip, in which case you might get a checksum error or.... someone is playing tricks on you by resetting the CMOS chip via its jumper; the only other culprit I can think of off hand is virus code infection to the CMOS chip.
Feb 23, 2017 | The Computers & Internet
Cmos battery for ast adventure 575
Jan 22, 2013 | AST Computers & Internet
Could round battery on motherboard be dead?
Motherboard battery is named "CMOS Battery"
CMOS Battery is like any other battery ahd it gets dead after a certin time>
Mar 18, 2012 | Dell Computers & Internet
Is the cmos battery on a vaio vgn-fe31m on the
Yes the cmos battery is on the motherboard.
Every motherboard that runs a computer has a backup battery to run the circuit while turned off. This battery runs the real-time clock (RTC) and is referred to as the CMOS battery. By keeping the clock active and running even when the computer is switched off, power up/down cycles can be logged and before the internet, your computer could keep dates accurately. It also serves to maintain the system configuration settings in BIOS memory based on RAM or FLASH RAM.
Jun 24, 2010 | Sony VAIO FX150K Notebook
I am getting an error code of 00161 and 00163 on my ibm think pad 2635
Error code 161 means your CMOS battery is dead and 163 is that system date and time are not set (which make sense as the CMOS battery is dead).
You need to replaced your CMOS motherboard battery to resolved this issue.
May 19, 2010 | IBM ThinkPad 380ED
I have a battery dead on the mobo. changed it, now i cant get past the cmos p-word. tried pulling the batt, and jumpers. nothing works.
Make sure power is off and unpluged. Pull the CMOS battery out and get a screw driver. Then touch the two battery tabs where the cmos battery goes for about 1 minute or so. This should reset the cmos.
Aug 05, 2009 | VIA : EPIA-M10000 C3 1GHz...
BIOS password locked
Try to reset the CMOS using CMOS jumper reset. Look this in its manual how to do it.
Or take out the CMOS battery out of its socket then place it back again this should clear CMOS and restore to its default setting. Without the BIOS password.
Apr 14, 2009 | Computers & Internet
Mar 09, 2009 | Asrock 845GV (P4I45GV) Motherboard
Im getting a boot time error called CMOS error and then i have to enter the sytem date and time every time i start the pc. After that it shows me an error like Invalid System Disk. wht does tht mean?
The CMOS error is caused by a dead motherboard battery. There is a small battery on the motherboard Usually a 2032 battery. The dead motherboard battery could also cause the Invalid system disk because a dead motherboard battery will also cause the motherboard to lose the Hard drive settings.
Nov 12, 2008 | Toshiba 4030CDT (P000271450) Motherboard
Computers & Internet Logo
140 people viewed this question
David Payne
David Payne
