Question about Kenmore Refrigerators
My refrig temp guage 107 degrees. I know it's not!! What to do??
It is 68 degrees in the house. Refrig has been closed most of the day.
    New Friend:
  • 169 Answers
Get a thermometer and place inside the refrigerator, to determine if you really have a problem with the cooling or if you have a faulty temp gauge.
Posted on Jan 22, 2013
VANMAN69
  • 23 Answers
SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Posted on Jun 29, 2007
Amigaman
  • 248 Answers
SOURCE: temperature 94 in refrig. normal in freezer
Check to see if refrigerator door is lower than freezer door. If so remove toe panel, (bottom front). Under refrigerator door hinge at bottom right is adjuster for door. Adjust upward so door is even. On some models when door is too low it causes light to stay on some times, raising ref. temps.
Posted on Nov 16, 2007
  • 1073 Answers
SOURCE: The refrig is Model ET8HKXM003
the drain tube on the machine has frozen in the freezer section
remove the back panel and with a hair dryer thaw the drain tube
you will see an alluminum sheild with a 1/2 inch hole in the bottom of the shield this is where you want to direct the heat
it may take 20-30- mins to unfreeze it to make sure it is unfrozen pour som water into the valley of the sheild if it runs into the drain pan it is unthawed if it pools up keep unthawing
Posted on Apr 16, 2008
  • 69 Answers
SOURCE: GE PFS22SISBSS Refrig compatment freezing
There is an internal door between the fridge and freezer section that allows the freezer air to enter the fridge side to keep the fridge cold. Sounds like the internal door is stuck open. Steve
Posted on Dec 21, 2008
  • 103 Answers
SOURCE: freezer works but refrig has 60 degree temp .evap coil is caked
Hi: Did you check the defrost heater itself? I checked Jennair and Sears parts to no avail. If you didn't check the heater it will be at the bottom of the freezer behind where you removed the back cover. A glass tube with a coil in it. If the coil or tube is broken replace that insead. I hope I helped, Jeff I found a website with the defrost timer, but not the location of the timer on the fridge. http://www.appliancepartsworldwide.com/store_SearchResults.aspx?S=1131392&ST=PBM
Posted on Jun 01, 2009
Fridge and freezer at 50 degrees with settings on max cold. I can hear compressor cycling and all power is on. Suggestions?
Your Refrig/freezer should be set as follows:
Refrigerators: 36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
Then check the door seals around the edges to see if any splits, tears or cracks have messed up the seal. This will cause your compressor to constantly run as it's trying to cool off the warm house is being sucked into the freezer (or Refrig). A sure sign the door seals are damaged is lots of ice in the freezer door area or water pooling in the bottom area of the refrigerator.
Wait about 4 hrs after you readjusted the Refrigerator/Freezer settings so everything settles down. If you still have problems then the coolant may need to be serviced (topped off) or the motor serviced/checked.
Don't procrastinate because a water heater and Refrig/freezer are the 2 largest energy users in your home- they run 24 hrs a day.
Hope this helps...
Nov 23, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
My refrig is freezing items on the refrig side.
likely a bad temperature control. also, some model GE's have a bad fresh food inlet cover, that fails to cutoff airflow from the freezer.
Feb 19, 2010 | Refrigerators
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
Amana refrig refrig wont get lower than 42 degrees
that is defrost timer every 8 hrs it turns on heater to defrost evap coils, unless there is major ice behind freezer panel after 1 day which i doubt, that would not be problem ...im trying to go through steps i would take as tech at your house
Jan 03, 2010 | Amana Easy Reach 18.1 cu. ft. Bottom...
Cannot control temp on refrigerator side
thermostat problem replace that if you know how to do that or call a technician who will help you
Sep 12, 2009 | GE Profile PFS22 33" Artica French Door...
Freezer set to 0 actual temp - 1 Refrig side set to 37 actual temp drops to 30 and frezes items in refrig.
Set the refrig temp to 42 degrees . Also check to see if the damper (top left in refrig section ) is closing to stop the air flow into the fridge section . Sometimes they will stick due to ice build up inside the damper . Sometimes also , putting a knife inside and wiggling it around , will break it free , however , it may have to be replaced along with the #1 thermistor .
Aug 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge has loud clicking noise; model freezer on bottom.
The problem is the main control board on back of refrig . Relay bad and clicking . Have to replace the complete board .
Jul 23, 2009 | GE GBS18KBM Bottom Freezer Refrigerator
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Admiral refrig
thats the fan hitting ice. sounds like a defrost problem. does the back of the freezer panel have any frosty ice build up?
Aug 18, 2008 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
41 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
