Question about Canon Service Manual For Ir 6000
How to change a pick up rubber in ir6000 - Canon Service Manual For Ir 6000
I have canon ir6000 printing not clear
Looks to me you may need to change the ink cartridge, or give the ink cartridge a shake you may get a few more goes before needing to change it.
Mar 22, 2017 | Canon Office Equipment & Supplies
How to solve this e000061-0001 error
Hi
The description for this error can be found here:
Error Codes Canon iR6000 Code E061 0001
and is the same for both the IR5000 and IR6000. There is a link on this page as well to download the full service manual for the model displayed, which should enable you to solve the problem.
On the right at the top of the page you can change the error code you are looking for to get a quick reference.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 27, 2014 | Canon iR5000-6000-L1 PS Ver 1.0
Canon ir6000 paper jamming & over heating
check the fans are working should kick in when you start to print anything or sometime when it is turned on. paper jam is the tray loader check that will need a torch to look in side you will probably find a corner of a bit of paper trapped in there, if not turn the rubber wheel by hand a bit. if it is lock then it is stuck and it is inside that has a problem may also be the belt has snapped that runs the rollers.
Oct 05, 2013 | Canon Service Manual For Ir 6000
Canon ir6000 touch screen is not working
my canon IR6000 touch screen is not working
Sep 23, 2010 | Canon imageRUNNER 6000 Copier
ImageRUNNER 7200 Copier: hi I'm Akar I have a canon ir6000 copier my...
The problem is with toner section. The copier cant get toner to toner unit or the toner motor is faulty.
In one case eaven the main pcb caused the problem.
I would try to replace toner hopper assy.
call service.
May 16, 2010 | Canon imageRUNNER 7200 Copier
Does not print,make all the noise like it is about to print but does not move the paper
maybe the problem is on your "pick up roller" use to move the paper...
take off your pick up roller and change the "rubber" on the pick up roller to the other side..just flip it to the other side (the rubber)..........
Jan 07, 2010 | Brother HL 2140 Laser Printer
Vinod canon ir6000 error e00061-00001 i cant
hai,one ir6000machine in oneand most problem eo61-01 please solution in this problem thnk you.
Dec 08, 2009 | Canon imageRUNNER 8500 Copier
Duplex printing problem
do you have to replese driver of printer for IR6000
Feb 10, 2009 | Canon imageRUNNER 5000 Copier
Canon Service Manual For Ir 6000 Logo
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
Computer Links
Tony
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
