Question about OTC Transmission Output Shaft End Yoke Remover 7075
Only 3 speeds.
1973 volvo 164, want to know if I can put newer auto trany to my car, right now have, warner borg type 35 auto trans. Thanks
  • 2,559 Answers
Short answer is YES
The BW 35 and later called the BW type 65 has been is use in many makes and models and continued in many models under different lettering such as these, AW70 or AW71 autobox.
If you need detailed list of vehicles which these were in,Please let me know.
Posted on Jan 27, 2009
Resistance specs on borg warner E 262 coil packs
I don't know if this is feasible, but connect two in series for 12 kilohms?
Feb 11, 2015 | Ford Cars & Trucks
I would like to know if I can install an borg warner m8 tail section onto an borg warner m12 transmission that way I would not have to change from the torque tube subsention
I just found out that all that you have to do is . You have three options to go with one change the bellhousing from a borg warner m12 transmission. two use and borg warner m12 transmission but use the yoke head from the m8 onto the yoke of the m12 yoke .Three use a chryler/amc tf727 torque command transmission.Use the yoke from the m8 weld the head on to the spline of the 727transmission weld the m8 tail section onto eather transmission and that way you can keep the torque tube suspension on your classic 770 with the 287.Your rear end should be an AMC 20 to stand the torque from the AMC 360 engine with about 350 hp .last but at lease get the trany mounts.
Feb 10, 2015 | AMC Cars & Trucks
What type of grease or oil goes in a manual 4 speed transmission on a 1984 ford F-150 pickup
I know the four speeds (Borg warner) uses 80-85 weight gear lube. Don't worry about using synthetic.
Mar 03, 2011 | 1984 Ford F 150
No clutch pressure on a hydraulic clutch system borg warner transmission 4 cyl. 5 speed
look for leak....under the dash on the floor if its wet there its the master. Just follow rod from clutch peddle to master. Check the line and not sure if your slave is on the outside of the trans look there or if its in the trans see if its wet coming out of the bell housing (where trans meets engine) and replace that part and bleed system
Mar 01, 2011 | 1995 Isuzu Rodeo
hi chris, this is one of the first fuzzy logic auto boxes to be fitted to a european car,followed by vw(zf make them,as do borg warner)
try this, just to make yourself aware of whats happening,without touching the gas,put the car in drive and let it accelerate itself ,right upto top gear,stop, then using 1/3 pedal,do the same,stop, then floor it,you will feel the differances right away,(the car will try to make you drive more smoothly,saving gas).other than checking fluid level,
every 6k,the only fix,if needed, is a rebuild.
but,if you know why it baulks in 2nd,(big drop in revs,between 1st and 2nd),you will feel better.
this is not in any handbooks.
Mar 31, 2010 | 1986 Volvo 740
After backing out of driveway, doesnt want to go into drive. seems to happen more when its cold
Just by your question I am assuming that it is an automatic trany. Probably a domestic car with about 90+ miles on it.
However, even though I have ESP could you please provide mre details
Isuspect though you need to add trany fluid. Probably an AC-DELCO GM Borg-Warner. if s you neen a reverse clutch band adjustment
Feb 01, 2010 | 2002 Chrysler 300M
Isuzu rodeo manual trans id
cheap truck 4cyl borg warner 6cyl mua
Jan 15, 2010 | 1991 Isuzu Rodeo
Automatic Tranny to 4-speed tranny swap
Ford dealer can with the VIN of both vehicals or only one if your nice to them at the parts dept. They caneven print it out but you need to be nice to them. Bring your pretty sweetheat with you or even have her get it for you of course the parts girl may not care. But it's worth a try.
Aug 29, 2009 | Warner Manufacturing Borg Warner DS111...
You leave in drive,after a few miles your going no where
i would recomend getting the tranny looked at with one of those trany computer shops
Nov 28, 2008 | 1996 Ford Explorer
What transmission the five speed in my 3.1 v6 firebird
yes u can put a V8 in, just need the correct wiring harness and emission parts, u can use any of the medium to heavy duty 5 speeds made by Borg Warner, model T5 chevy bolt pattern, which by the way is most likely what is already in your car.
Nov 09, 2008 | 1992 Pontiac Firebird
OTC Transmission Output Shaft End Yoke Remover 7075 Logo
83 people viewed this question
Top OTC Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an OTC Measuring Tool and Sensor Expert? Answer questions, earn points and help others
