This is an indication of a bad water sensor. It also tells me that the pressure switch may be bad because if it is working then the light on the panel will light up telling you that the spa water is heating.
Hi, For comfort cooling w/ r22, you can expect a delta- t of 20 degrees F across the evaporator, or a seventeen to twenty degree drop from return to closest supply grill, so if your return air temp. is 72 degrees, you should see from 52 to 55 degree air temp. at grill. Other factors come into play as well, how well insulated the duct work is, r-6 is industry standard now, and how well insulated the attic space is as well as temp of attic space, ridge vent works well, and so do solar barriers to keep heat out of attic space. This should help.
these freezer are designed to run about 70 percent of the time the temp displayed can vary by +/- 3 degrees..make sure you have fan operation in the freezer and the air flow is not blocked or restricted. also make sure that the door is sealing properly
Make sure the vent on the back of dryer is not blocked. Most dryers use 240 volts. Read the data plate on rear of dryer to confirm this. Example number 912.25879
Beneath Or Inside door Compartment On Cabinet Frame
