Question about Panasonic TH-37PWD8UK 37 in. EDTV-Ready Plasma Television
Panasonic th-37pwd8uk hook up
How do i hook up my screen with a coax coming from my direct tv cable. canno t get to work only have the phrase no signal in upper right
Have you tried using the video out and audio out RCA jacks from the directtv receiver and inputting this signal into the composite video and audio inputs on your EDTV?
Posted on Jan 27, 2009
Screen freezes, and buttons don't work!
It sounds that the main digital board to your TV has the fault. To check and locate the fault to this board is a very skilled work. Contact any service technician.
May 28, 2013 | Vizio SV421XVT 42 in. LCD TV
Panasonic Plasma TH-42PZ80U HDMI do not work after lightning storm
I don't have a solution, unfortunately, but your problem is nearly identical to mine. It even seems to have happened on the same date (7/27/12)! Do you live near Dener by chance? Anyway, we have Direct Tv, and ended up with 2 fried HD DVR boxes and 2 TVs on which the HDMI connections don't work after lightning hit close to our house on 7/27. Those boxes were replaced, as was part of the Direct TV dish. The only difference is, whereas on one TV component connections (red/white/yellow cables) allowed the TV to work normally, on the other (my 50 inch Panasonic Plasma TCP50S30) even the red/white/yellow cables did not work. Now I'm scouting the net for tips on what else to try before I possibly have the Panasonic looked at, which I am hedging on doing since I got it for only $600 new in the first place. Have you found out anything else since you posted this? Good luck to you...
Jul 27, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic TH-L32S1OZ digital TV set. Message on
Make sure the cable is hooked up then press ok on your remote (or enter). If you have your tv hooked up a different way (like hdmi) just change the tv source to the correct one.
Mar 04, 2011 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
CT-32SL 13 antenna busted off, how can we hook up
you can use your rca connectors for your cable if your cable box have rca all you need is rca jacks if you don't have a box and all you have is the coax , then you can use a vcr or a dvd with coax input and rca output "hope i explain this right {" tv-----rca's--2---rca jack output vcr ---coax input ---hook up coax CABLE
May 14, 2010 | Panasonic CT-32SL14 32" TV
HDMI inputs are not working
As crcelect suggests you can run the TV on RCA. You should also be able to use coax directly from your cable box. If you don't have cable you can use an rf converter to connect coax.
I have exactly the same problem with my Panasonic TH-42PX75U. I've been told that I may need to run a setup on my cable box to fix the problem. If I find a solution I'll provide details in a future post.
Nov 01, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Hooking Up Panasonic sc-ht670 home theater to Dish DVR 625 and Panasonic TH-42PHD7UY Plasma TV
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
May 13, 2009 | DISH Network DVR-625 DTV Receiver /...
TV volume is half of want it should be.
the problem is not the cable into your house, but the amplifier it self, if the amplifier is not been powered if a rightful voltage, that can happen. if you are not happy with the output than take your tv to a repair shop, so that an amplifier can be worked on.
Mar 16, 2009 | Panasonic TH-42PZ77U TV
Panasonic plasma TV has a black screen after disconnecting Dish TV
proably not tied in tv nomore dish will take over that prot if u got dish hd u get locakls form dish free in hd dont need attc nomore
Oct 10, 2008 | Panasonic TH-37PD25U/P 37 in. EDTV-Ready...
New TV - no picture at all
Try pressing input on your remote and make sure the source is selected to what you have it plagged in. For example cable box plugged into hdmi1 set input to hdmi 1. Also can you access tv setup at all? If not your tv might be bad to begin with.
Apr 26, 2017 | Panasonic TH-50PHD7UY 50 in. HD-Ready...
Panasonic TH-37PWD8UK 37 in. EDTV-Ready Plasma Television Logo
132 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
