Question about Sony Cyber-shot DSC-H50 Digital Camera
SONY DSC-F717... SHADOW WHEN USING FLASH - Sony Cyber-shot DSC-H50 Digital Camera
    Genius:
  • 1,019 Answers
Hello John, Have you tried a different flash setting ? Do you have a lens shade installed ? or a lens adapter tube installed ?
Hope This Helps.
Best Regards, Russell
Posted on Jan 25, 2013
t00nz
  • 4738 Answers
SOURCE: Sony Cyber-Shot DSC-F717
All three of you are in luck! This definitely sounds like it might be a defective CCD imager. If so, Sony should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/11/sony-konica-minolta-cameras.html
Applicable cameras include:
Cyber-shot DSC-F717, F88, P10, M1, P12, P2, P31, P32, P51, P52, P7, P71, P72, P8, P92, T1, T11, T3, T33, U10, U20, U30, U40, U50, U60, V1
CD Mavica MVC-CD250, CD400, CD500, and FD Mavica MVC-FD100, FD200
Posted on Nov 20, 2007
  • 51 Answers
SOURCE: sony cyber shot DSC F717
Hi
Switch your camera to Setup on the control **** located on the top.
Take out the memory stick and press the reset button located inside the battery compartment.
Now switch on the camera and insert the memory stick.
If you do not get the error go to the little toolbox on the menu. Select the format option and proceed through the warning messages. Remeber you will loose all data on the memory stick.
Things should now work. If not some simple thing that sound bezare but has worked for me is pushing the memory stick in and out before the camera displays the error. Do this several times until the camera actually reads the stick and them format the stick first chance you get.
Good luck.
Posted on Mar 09, 2008
SOURCE: flash not working on Sony Cyber-shot dsc-p100
this has happened to me a few times and all you do is make sure you take out your memory card, push in the reset button for about 3 seconds and it will work again!
Posted on Mar 07, 2009
  • 13 Answers
SOURCE: Sony DSC F717, screen and view finder now show
Please take a look at the symptoms listed here, and see if it's what you're experiencing.
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCF717&news_id=161
Sony had a certain issue with the CCD chip on this camera. If it's this issue, they'll fix it free plus $20 until March 2010.
Posted on Dec 25, 2009
SOURCE: Defective CCD - Sony DSC F717 Digital Camera
sonyfsd is right.
In the UK the process was very painless for me a couple of months ago (Dec 2009). Using their online fault-reporting service, I was told to use the words "Known Fault" in the description of the problem. Freepost label and free return meant no charge to me whatsoever.
Only problem was Parcel Force who left the repaired camera, unsigned for, outside my house all day long. Anyone could have stolen it.
Posted on Feb 08, 2010
Built in flash on Sony DSC-F717 will not open up. Have reset and checked all settings.
BAD battery !!The high quality Rechargeable Sony Cyber-shot DSC-F717 Battery [Non-OEM], It can provide extended power for your Sony Cyber-shot DSC-F717 digital camera, this battery is made specifically for your digital camera and to meet or exceed the original manufacturer specifications, we will ensure optimum performance saving you time and money.
Sep 04, 2011 | Sony Cyber-Shot DSC-F717 Digital Camera
O flesh da minha camera sony dsc f707 nao esta funcionando gostaria de saber o problema sera que tem alguma configuracao
hi sony f707 and f717 have very common flash fpc(flexible printed circuit) torn due to flash defuse unit up/down many time. it just need replacement. Thanks and best regard!
May 24, 2011 | Sony Cyber-Shot DSC-F707 Digital Camera
Dsc-f717
The Sony DSC-F717 will only take upto a 256MB Memory Stick - larger size Memory Sticks will give the C: 13:01 error. Use a correct memory stick and your camera should be fine. Regards, Andrew
May 10, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
yes sony chang the ccd free of cost all over the world
Feb 04, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
I have a sony DSC-F717, and when i take pictues, the white colors on the image come out pink and other types the picture has like a green shadow over the picture.
Symptoms shows its start-up of CCD Imager problem in DSC-F717 and in few days, CCD Imager will not give picture data to camera circuit. CCD Imager is part which converts image in electronic signal and that signal / data goes to camera circuit for further process.
Sony will repair CCD Imager problem in DSC-F717 free of cost. Check Sony CCD Imager Support for details.
Jan 06, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
Yellowish/Green cast seen through viewfinder
Symptoms of your DSC-F717 shows problem in its CCD Imager IC and needs to replace.
Sony announced scheme of free of cost repair for your camera model with same symptoms. Click Sony CCD Issue for details.
Regards,
Sep 14, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-Shot DSC F717
Your Sony DSC-F717 has bad CCD Imager IC and camera will be ok after part replacement.
Good news that Sony will repair it free of cost as they have a scheme. Please click on Sony CCD Scheme for details.
Regards,
Sep 12, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
When using flash the reflection have a pink tint
Lens block assy may be defactive. Consult Sony service center
Jan 16, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-shot DSC-H50 Digital Camera Logo
32 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
