Question about Nokia E7-00 Smartphone
My nokia e7 is saying "please disconnect usb" when its nothing connected
It keeps saying that I need to disconnect a USB or a lead, when there is nothing actually connected. A USB symbol is also flashing in the corner of the screen and I'm not sure why that is.
Change connector if it's not work
cheak
n3300 and D3300
but it's was always prob with dust so that 1000% solve with changing connector it's it's not solve so than check d3300 after that check n3300
Posted on Jul 05, 2013
  • 82 Answers
SOURCE: While running firmware update,USB cable disconnected and it damag
reprogram your phone,all files saved to phone memory will be erase including contacts,picture,songs,and video.
Posted on Dec 27, 2009
  • 5 Answers
SOURCE: nokia n91 cannot connect to pc thru usb cable
plz connect the data wire to the phone and also connect it to the PC go to connectivity and choose pc suite or data transfer or data storage or mass storage
Posted on Oct 17, 2008
SOURCE: Need A Driver for Nokia 2600c USB DATA CABLE
i want nokia 2600 c data cable driver
Posted on Sep 19, 2010
martin702
  • 17 Answers
SOURCE: my nokia e7 screen has gone to a black and green glitch back ground
Have you tried a reset by holding the power key down for 10 seconds?If that doesn't work you can try removing the battery for a few seconds.
I had a similar problem with my E7, it was dead and wouldn't respond even when I plugged it into my PC. But once I had removed and replaced the battery it was working fine and its not gone wrong since. Here's a good guide on removing and replacing the battery
Posted on Dec 28, 2011
  • 547 Answers
SOURCE: my nokia E7 phone's charging pin is loose connection.has the mother board damaged?
it is difficult to know, because you need to open device and check or show some oficial repairer
Posted on Jun 23, 2012
My Nokia E7 phone's charging but not conected on PC,what can i do.
BEFORE PLUGGING UP TO COMPUTER
menu -> settings -> wireless and networks -> USB utilites -> connect storage to PC (click this button) -> it'll give you a message "Connect USB cable to use mass storage" ... connect the usb cable -> the android man will pop up w/ a msg saying "Phone connected to computer via USB. Tap the button below to copy files between computer and Android's USB storage" theres a button below that says "connect USB storage" (click on this).
your all set
Dec 13, 2012 | Nokia E7 (16 GB) Smartphone
Dead nokia 2700 classic usb connection disconnects automatically ?
1. Please make sure your USB cable is working fine. better to connect your phone using another USB cable.
2. Change the phone's battery, or make sure its more than 80% charged and in good condition.
3. Try to connect with different USB Port on your PC.
Hope your problem will be solved.
thanks
Dec 02, 2012 | Nokia Classic 2700 Cell Phone
How to change nokia e7 charging point
Remove the battery, get some methelated spirits some paper towel and a toothbrush. (Do Not Use TURPS!) Gently dip the toothbrush into some metho then scrub out the usb port with it facing down, so that minimal metho gets into phone. It will evaporate fairly quickly so don't be worried. Use the paper towel to soak up excess metho. Then use a magnifying glass or jewelers lube and check if all the pins are entact, do likewise for the charger end also. Should work ok after that, if not buy a new charger. Good Luck! :)
Sep 21, 2012 | Nokia E7 (16 GB) Smartphone
I need a lead to connect my Nokia RM-364 mobile phone to my computer's USB port.Can you please let me know were I can buy one.Many thanks Bill
Your best bet is to go to a cell phone shop. They will make sure you get the correct USB cable for your cell phone.
Jul 18, 2012 | Cell Phones
Forget security code nokia e7 how to unlock
The default security code for Nokia is 12345 or 00000 you can use it.
If you want to unlock your Nokia E7 you can use the codes ie the
unlock codes. Get the unlock codes using the site Onlinegsmunlock.com
and unlock it easily.
Apr 21, 2012 | Nokia E7 (16 GB) Smartphone
Nokia E7-00 will not charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
May 12, 2017 | Nokia E7 (16 GB) Smartphone
When i connect my usb data cable on my nokia7230 It says that"connected device uses too much power.disconnect cable"any one please help me. thankz in advance
there might be a problem on your USB cable, a little rust could make some problems to your connections, try replacing it or have your technician check your cellphone
Jun 24, 2011 | Nokia 7230 Cell Phone
Is there any way to connect a usb memory stick to my 5800 so I can play music tracks off the stcik
No only Symbian^3 phone like Nokia N8 , C7 and E7 supports USB On the GO
If you like the answer kindly give me all thumbs up
Farhan www.senseapplied.com
May 21, 2011 | Nokia 5800 XpressMusic Smartphone
E7-03 error code on work center xe88 xerox
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Xerox WorkCentre XE88 Laser Printer
Nokia E7-00 Smartphone Logo
379 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
