Question about Prestige Aps101n Car Alarm Security System
Bought a car with a prestige alarm system, car won't start, and can't find valet switch!!
Valet/Bypass Switch Location 1995 Honda Accord
Wow no idea at all ,is this the original factory alarm or a add on one
Jul 17, 2013 | Prestige Aps95bt2 Elvat5c Replacement...
Valet switch location
The valet switch is usually located around the drivers side. Each installation is different, as are most alarms. The valet switch could be part of the flashing LED or, it could be incorporated into the on glass antenna. If not, it should be located below the driver side dash. If you can see the alarm, locate the blue two pin plug and trace the wire to the push button valet. If the unit is manufactured by Directed (Viper, Python, Avital, Clifford, Valet, Automate, Hornet, etc.) turn ignition on then off, press and release valet within 10 seconds, LED will illuminate solid to show system is in valet. If the unit is manufactured by Audiovox (Prestige, Pursuit, Code (new)) turn ignition on, press and hold valet switch for approx. five seconds, release, LED will illuminated solid to show system is in valet.
If you are attemting to manually override the system, turn ignition on, press and release valet switch to disarm.
Aug 21, 2012 | 1995-1997 Chevy Tahoe Ignition Starter...
I have 2004 chev tahoe w/ a viper remote starter system,but no key fob. I replaced the car battery & now the cars computer won't let it start. How do I reset the computer?
The car's computer wont let it start?
Well, if you changed the battery and the viper alarm is the issue; locate the push button valet/programming switch. Turn the ignition on, press and release the switch. The alarm will disarm and you can start the vehicle.
To put the alarm in valet, turn the ignition on then off, within 10 seconds press and release the valet switch. The LED will illuminate solid to show that the system is in valet.
Aug 20, 2012 | 5900 SST 2-Way Security System / Remote...
My security system won't disarm on my 1999 chevy blazer
Is this an aftermarket alarm? If so, first locate the valet switch. It should be a black push button. Next, turn the ignition on, press and release the valet switch. This should disarm you aftermarket alarm. This is the most common manual disarm procedure for Directed (avital, python, Automate, Viper) and Audiovox (prestige, pursuit, code).
If this is the factory alarm and, you don't have the remote. Unlock the vehicle using your key in the driver's door.
Aug 16, 2012 | Vehicle Parts & Accessories
I bought my car used with an aftermarket prestige alarm w/ remote start. Battery and alternator went bad. They have been replaced. The car will not turn on and alarm remote is not working.
Locate a black push button switch under the dash or near the drivers side kick panel (older model), or the alarm has a push button LED light(newer model) or the Valet switch is in the antenna(newest model). Turn the ignition on, press and release the switch one time. This should disarm the alarm.
For programming: turn ignition on, press and release the valet switch three times: you will hear one chirp from the alarm, press the lock button on the remote. Press and release the valet one time, you will hear two chirps from the alarm, press the unlock button on the remote. Repeat as necessary. Turn igniton off to exit programming. Test remote for proper functioning.
Jul 16, 2011 | Prestige Appliances Vehicle Parts &...
I have a prestige remote Audio box starter remote alarm on a 2002 Toyota Camry.I unplugged the sensor and the car still doesn't start.can you help me i am out of the state need to get home.
Locate the valet switch( black push button), turn ignition on, press and release valet switch. the valet switch is plugged onto the main control unit. You can find the main control unit by tracing the harness that you unplugged from the shock sensor. The valet switch is plugged into a two pin plug and has a blue end. Trace the wire to the valet switch.
Jul 10, 2011 | Prestige Remote Start
How to disable or reset a Prestige car alarm. Purchased a used car with an after market Prestige alarm installed. Alarm somehow tripped and shut off the ability to start the car. I can't find a valet...
The valet switch,on the newer Prestige alarms, is a push button LED or, it's incorporated into the antenna. In both cases, turn the key to the on position, then press and release the valet switch. The alarm will respond with two chirps confirming that it is disarmed. You may now start the vehicle. After you successfully disarmed the alarm, turn the key to on position, press and hold the valet switch for approximately 5 seconds, the LED will come on solid. Turn the key off.The alarm is now in valet. You can take it out of valet in the same manner.
Oct 28, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
The alarm wont let my car start. i turn the key and now response. how do i get the engune out of sleep
look for your valet switch. It should be under the dash(a little red button). put the key in the ignition, turn all the way until the instrument cluster lights on, then press on the valet switch for a couple of seconds until you hear the alarm chirp. You're now in valet mode and it should be ok to start the cart.
Oct 28, 2009 | Audiovox Prestige Code Alarm Remote Alarm...
How do I disarm a audiovox prestige car alarm?
Locate the valet/override switch (button), (if you can't locate it, try tracing the wires under the dash from the main unit, usually a black and gray or black and red set of wires). Turn key to "RUN" position then press the button, the alarm's LED should light up solid at this time indicating valet mode as been set.
Jun 14, 2009 | APS20B Prestige Keyless Remote Alarm
The car arms but the alarm does not chirp
try turning your key on and flip the valet switch, your alarm is most likely in valet mode (youll know cause the led stays on) if that doesnt work, turn the key on and off then toggle thye valet switch 3x and that'll turn off silent mode. Good luck, Martin @ lessco electronics
Feb 25, 2009 | Car APS25CH Prestige 2 Button Remote...
Prestige Aps101n Car Alarm Security System Logo
32 people viewed this question
Top Prestige Electronics Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Prestige Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
