Question about Amana Dryers
My Amana Electric Dryer Randomly stops working and it won't start up again , it can take up to an hour for it to work again. Model Number LE8407W2.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
There are safety sensors that will break the current when it gets too hot or if the sensors themselves are failing. This will shut the dryer off or make it quit heating. After cooling down or at random times the sensor may make connection again allowing the dryer to work. These can only be checked out using an OHM meter and must be checked when they are not allowing the dryer to run.
Posted on Jan 22, 2013
IFIXALL
  • 868 Answers
SOURCE: Amana heavy duty clothes dryer,
Belt idler pulley sounds dry, oil all rollers and belt pulley.Please leave a Rating! Thanx!
Posted on Jun 05, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: dryer won't run. Stops after 30secs
Sounds like the timer is going bad and it needs to be replaced. The time is located behind the knobs.
IF my answer has satisfied you please rate. Thank you
Posted on Feb 12, 2009
kachbibi1
  • 979 Answers
SOURCE: Dryer work turn on, buzzes when start is pushed
It may be just your timer switch. Look at all the wiring first. The receptacle to the plug, cord and into the back of the dryer.
Posted on Feb 15, 2009
  • 336 Answers
SOURCE: Electric Dryer Won't heat. Model Number LE8407W2.
I would replace the whole heater assembly. From the model number given, you can get the whole heater assembly for under $42. That's the element, thermal fuse, and the limit thermostat. Here is the link to the part. This is the best place for appliance parts. This is the part number AP4072871
http://www.appliancepartspros.com/part_details.aspx?part_id=4072871
Posted on May 17, 2010
heatman101
  • 43501 Answers
SOURCE: Amana DLE330RAW Elec Dryer starts then shuts off & wont turn on
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jul 12, 2010
Stop button doesn't work on Amana NED7200TW Electric Dryer.
Check the door switch to see if it "clicks" when you push and release it. If it clicks, then the control board will need to be replaced. Here is the part you will need to order.
Nov 01, 2012 | Dryers
AMANA HEAVY DUTY DRYER model #NDG2335AWW
m ost likely one of the rear drum support rollers is bad. the part number is 37001042.
Mar 21, 2012 | Amana NDG7800AW Gas Dryer
You lucked out there but better replace that start switch because it will do it again just when you don't want it tol
Feb 21, 2012 | General Electric Dryers
My amana DLG330RAW dryer won't stay on. it has a combo timer and start dial turn the dial to the timed settinG and push...dryer starts part way through the cycle, the dryer...
Hello PB,
What i would most suspect as being the problem of why the dryer just stops randomly before the cycle is done,is a problem with the door switch or the door catch...does the dryer restart as soon as you restart it?? if yes i would check that the door catch was broken so the door will pop open stopping the dryer. Also check the door switch using a meter set to measure ohms and see if the contact is burnt ( a good door switch will be zero ohms resistiance)
GENE
Sep 17, 2011 | Amana DLG330RAW Gas Dryer
Dryer won't turn over/start. When push start switch makes noise but won't turn. If hold door closed switch and turn manually while pushing start button it would work for awhile, but that has...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2011 | Amana Dryers
My Amana dryer won't start or power on pls help.
heatman101
Aug 15, 2011 | Amana NED7200TW Electric Dryer
heatman101
Jul 08, 2010 | Amana DLE330RAW Electric Dryer
I have a Amana Electric Dryer NED5500TQ. When I
It is possible that you could have a bad breaker in the panel. They will start to trip randomly when they are going bad. If not the dryer is drawing too many amps and the breaker is doing it's job. If the heating element is defective and drawing extra juice that could trip the breaker. Usually replacement breakers are not too expensive if you electrical panel is less then 20 years old and can be purchased at most home improvement stores. I would try replacing the breaker before you try repairing the dryer. If you install a new breaker and the problem continues to happen then you should check the dryer heating element. That component is what draws the most amps and would be the most common one for tripping the breaker.
Sep 25, 2009 | Amana NED5500TQ Electric Dryer
Dryer won't run. Stops after 30secs
Feb 11, 2009 | Amana ALG331RAW Gas Dryer
Dryers Logo
54 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
