Question about Panasonic NN-H275 Microwave Oven
NN-SA636WX microwave arcing
My Panasonic NN-SA636WX microwave arcs when i put liquids in it. there is a burnt spot on the rectangular thing on the side wall. I have read that this part needs replacing but can't seem to find a place to buy it. What is it called and are there any online sites where I can purchase one?
  • Panasonic Master
  • 17,130 Answers
If there is spark please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is leaking and sparking to the ground. As you have mentioned it was stored, it is quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Now switch the microwave power on and use a cup of water to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. Replace with same type. If not check the waveguides within the cabin for food particles that can burn and spark, check for rust that can corrode and spark when the ceramic paint has worn out.
If there is heating without any issues, you can use the microwave safely
Click this link:Waveguide
Posted on Jan 22, 2013
3 Suggested Answers
SOURCE: looking for a replacement user manual for
Try this site and click on "Downloads" then give your model number.
https://panasonic.ca/english/customercare/customercare.asp
Posted on Dec 29, 2010
  • 6771 Answers
SOURCE: My Panasonic NN-T994 Microwave oven
From your description it does indicate a magnetron problem, you would be further ahead replacing the microwave oven when you consider the expense of the repair involved.
Posted on Feb 23, 2011
Panasonic microwave model NN-H275: Oven door doesn't open; Makes crackling or arcing sound when turned on;
If you do not see actual arcing in the cavity making the noise it is probably components on the inverter. Too exppensive to repair. Get a new one. Dont like or trust the inverters.
Jun 25, 2017 | Panasonic Microwave Ovens
It just beeps when plugged in cannot press anything to start it timer menu does light up model # nn-sn960s panoasonic micro wave
Panasonic Microwave - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Microwaves
Rating: 2.6 - ‎53 votes
After looking, door was starting to arc and burn around the edges in three places, ...You can't leave this oven unattended for a minute or you could be calling 911! ... In October 2014 I purchased a Panasonic microwave model NN-SA661S. ... The timeremits "4 beeps" when the time is up; other microwaves, continue to beep ...
[PDF]operating instructions - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/microwaveoven/.../nn-sn651_nn-sn661...
PanasonicModels no. nn-sn651b ... nn-sn661s .... Use this appliance only for its intended use as described in this manual. do ... Thank you for purchasing a Panasonic MicrowaveOven. ... you press Start. note: The Glass Tray can turn in either direction. ..... If a pad is pressed and no beep is heard, the unit did not or cannot accept the
Jan 19, 2016 | In Microwave Ovens
Panasonic genius sensor 1250w
follow this test and fix it. God bless you
  1. Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  2. Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity paint.
Oct 27, 2013 | Microwave Ovens
My Panasonic NN-T994 Microwave oven died today. Would run for a few seconds with a clicking sound and an electrical smell. I removed the cover, restarted and found arcing from the area of what I think is...
Feb 23, 2011 | Panasonic NN-T994SF Microwave Oven
This is actually a one-year-old Panasonic Inverter NN H965WFX 1250 watt microwave. The light inside flickers and staggers a bit, and the microwave does not heat or cook properly. The first time this...
Inside is a screen which sometimes arc. These are normally available from the dealers and is not very expensive. Microwaves are dangerous and repairs are better left to trained people.
Jan 03, 2018 | Panasonic NN-H965 Microwave Oven
Looking for a replacement user manual for Panasonic Microwave Oven Model # NN-SA636WX
Dec 04, 2010 | Panasonic Microwave Ovens
Arcing and then went dead. Can see arcing from top vent behind fan blade
owwwww! i say,,,owwwww! again.....
its time you dumped this unit,,,to fix it will cost barn nearly as much as a new one
Jul 01, 2010 | Panasonic NN-P295SF Microwave Oven
Our microwave continually arcs when you start it up, so we quickly turn it off.
on the inside of the oven on the right you will find a small square of mica this is the wave guide cover have a look and see if it burnt or out of shape if it is then unplug the unit and remove and replace it make sure u clean the area where it sits as food can get behind the cover hope this helps
Oct 15, 2009 | Panasonic NN-H264 Microwave Oven
Arcing inside and there is now a small hole on the panel side. Is this fixable?
It looks like there's lightning (arcing) inside my microwave When you see arcing inside your microwave, it's because of food or liquid left in the cavity or on the wave-guide cover:
  • If the wave guide has any burn spots, replace it and clean the unit well.
  • If the cavity has any burn spots, spot-sand it smooth and touch it up with microwave interior paint.
Note… If there are any burn holes in the cavity, don't use the unit-seek help from a qualified appliance repair technician.
Thanks for contacting Fixya
Jun 20, 2009 | Microwave Ovens
Sparks, noise and burning smell
If it is burning and arcing at the antenna, it is probably arcing in the wave guide area. Probably will have to replace unit. I have had some success by removing the antenna, sanding and repainting the burnt areas of the cavity and sanding off any burnt marks on the antenna. Need to look at top of mag to see if also arcing there too.
Jun 16, 2017 | Panasonic NN-2555A Microwave Oven
Panasonic NN-H275 Microwave Oven Logo
178 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
