Question about Body Glove Earglove Bluevoice Bluetooth Headset (7810001) Headset
Volume trouble I have no idea how to turn up the volume on my body glove bluevoice blue tooth.
  • Anonymous Mar 21, 2014
    turn up mic volume on blue tooth
  • 3 Answers
The top button on the control surface, the one with the green flashing LED, is the volume control. When the unit is "ON" pushing the button up or down raises or lowers the volume, simple. When you connect it to the charger that same green light will turn red while charging. If you push the top button forward (up) at the same time you press the lower button (power) the LED will flash 1-3 times. Three flashes is fully charged and one means it's getting low.
This is a great head set. I just sat on mine and broke the ear piece. I'm looking for another as we speak! It's worth more than it's current retail price by far!!!
Posted on May 11, 2009
How do I pair my phone to the bluethooth on car radio
Depends on the car stereo.
Although generally you would need to change the "channel" to Blue Tooth, and make sure Blue Tooth is turned on on your phone. Press the appropriate button (in mose cases if a new BT device is detected you would push the volume knob). Once the pair sequence has started, a pass code should be displayed. Verify the pass code on your phone and press the volume knob again to pair.
What is the make and model of the radio? This will help us find more specific instructions for you. Thanks!
Apr 06, 2015 | Cell Phones
Bt-100 bluetooth speaker volume to low can't turn up
There are several issues that may be causing the volume to be very low.
SPEAKER VOLUME:
(1) When you press the Vol+ button on the speaker does it make a beep sound? (It should, even if it can not longer go up or lower).
(2) Be sure to continue pressing the Vol+ Button to ensure that the volume does increase.
(3) While this is rarely an issue, may want to check that the speaker is charged.
DEVICE VOLUME:
*Please note that some devices have a separate volume control aside from a blue tooth devices volume adjustment.
(1) Ensure that Media Volume is on.
(2) Ensure that the volume is turned up on the device by using the devices Vol+ controls
MEDIA VOLUME:
*Please also note that the media being used (Youtube, Hulu, Music Player, etc.) may ALSO have a separate volume control aside from a blue tooth devices volume adjustment.
(1) Check that the volume within the media is turned up as well.
Hope this helps! You can also contact customer service for DIgix at 1-866-770-3688 for further assistance.
Jun 30, 2014 | Digix BT-100 Portable Bluetooth Wireless...
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
Any idea how to turn the bluetooth on on a sony
No code should be nessicary but you due need to make sure your have the actual blue tooth adaptor for the sony unit itslef its says blue tooth ready but you have to purchase the adaptor for it
Mar 05, 2010 | Car Audio & Video
How do I set the clock on my Ranger professional with Blue Tooth
Press dimmer switch 3 sec, then when first two digits (hour( of clock flashes set hour using Phone Volume switches. Press dimmer again to set minutes, then when done press Dimmer once more to activate the clock. It displays in military configuration (e.g., 1:30 PM will read as 1330 Hrs) See user manual page 8
Jul 14, 2009 | Ranger TR-966 CB Radio
Having trouble connecting Explorer 320 to Samsung Blackjack II
Push And Hold The On Off Switch On The Blue Tooth Till It Flashes Blue And Red. Then Search For The BlueTooth When Found Push The Button On The Blue Tooth Again. Hope This Helps
Jan 04, 2009 | Plantronics Explorer 320 Wireless Headset
Instuctions
1. Turn on the blue tooth headset
2. Press both volumes keys together so light flashes red/green
3. turn on phones blue tooth
4. Find device and select.
Jul 15, 2008 | Sony Ericsson Akono HBH-300 Consumer...
Blue tooth hs 801
hi, first press call and volume key simultaneously for 4 sec, then it will turn on. then make search on your mobile for bluetooth device and connect with it. then it will ask for passcode, type any number... while mobile is connecting continue pressing its volume key until it connects... and then here u r connected with ur headset...
May 24, 2008 | Motorola Mobility HS801 Consumer Headset
Body Glove Earglove Bluevoice Bluetooth Headset (7810001) Headset Logo
169 people viewed this question
Top Body Glove Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Body Glove Radio Communication Expert? Answer questions, earn points and help others
