Question about Rainbow Rainmate Air Purifier
Rainmate question I just set up my new rainmate in my son's room with the eucalyptus scent (he has a cold/cough), and I wanted to know how safe is the unit to keep running through the night, and how long will the water last until it runs dry (I filled the water up top the indicted line in the bowl as instructed.)
Hey im a dealer for Rainbow. RockyNR1 is correct but let me just add that you can fill it to over the line if you want as long as the 'misting' still happens, be careful not to place the machine too close to the edge of whatever it's on as it may fall off. The rainmate can be ran 24/7 (mine does :D)as a side note the only upkeep it should need (other than the water of course) is check the little hole on the bottem of the spinner. if that is ever clogged just punch it though with a toothpick.
Posted on Feb 06, 2009
Rainbow Rainmate Air Purifier Looking for information if the aromas/oils are safe in households with birds! Also, where can one find the MSDS documents for the oils etc.
I'm not sure if this will help or not. I never thought about the aromas/oils possibly being bad for any birds in the house. I ran mine in the small room I use as an office and I have a parakeet in this same room. She didn't have any ill effects from it. So I would suppose it would be okay. That or I have a tough old bird (which she is).
Nov 23, 2010 | Rainbow Rainmate Air Purifier
How much water should i use
I run mine day and night while home and clean and re-fill it every morning. I also use one of the room odor eliminators in my Rainmate. Fill the water one inch above the line about an inch off the bottom of the water container.
Aug 20, 2009 | Rainbow Rainmate Air Purifier
Shortness of breath, coughing when working out near unit.
I think you've answered your own question: "symptoms cease when unit is turned off".
I don't want to be alarmist, and I certainly do not suggest that there is anything unsafe about the Breeze AT.  Nevertheless, this machine generates ozone, which is an upper respiratory tract irritant.  It is absolutely vital that you follow the manufacturer's instructions to the letter when operating it. Personally, I would never want to be in the same room as a working ozone generator (and I know of at least one ozone generator where the instructions specifically tell you to keep out while it's working).
Your machine may be on a setting where it is producing more ozone than is desirable. If you no longer have the manual, you can download a copy at www.ecoquest.com (click on the DOWNLOADS tab, then on OTHER on the green bar. The Breeze AT is in the Owner's Manuals list.).
If in doubt, play safe!
Mar 05, 2009 | Ecoquest Breeze AT Living Air Purifier
Rainbow Rainmate making a screeching noise!
just take it to ur local dealer they will replace it or fix it.
Feb 12, 2009 | Rainbow Rainmate Air Purifier
I need a Rainmate instruction manual
I have one and it isn't much, it's just a single sheet.
If you want tell me what you need to know and I'll try to help you by telling you what I've learned while trying to understand how to operate the one I have.
Feb 11, 2009 | Rainbow Rainmate Air Purifier
I was just wondering if the fragrances contain oil in them?
You simply remove the spindle and wash it out, and the spin wheel too if ot gets a build up. I use an antiseptic sort of smelling scent in mine and it helps capture dust. That is part of the build uop on the spindle. Simply turn it on the spin wheel and remove it and then wash it under hot water and let the hot water course through the spindle to clean it out.
Feb 09, 2009 | Rainbow Rainmate Air Purifier
I just set up my new rainmate in my son's room with the eucalyptus scent (he has a cold/cough), and I needed to know how safe is it to leave the unit running overnight, and how long does it take for the...
Hey im a dealer for Rainbow. RockyNR1 is correct but let me just add that you can fill it to over the line if you want as long as the 'misting' still happens, be careful that the bowl is not near the edge of the surface as the spinning water might make it fall off the side. How long the water lasts is also very dependent on how large the room is that its in. Lastly you should be able to leave it run for 24/7
Jan 27, 2009 | Rainbow Rainmate Air Purifier
Got Rainmate yesterday and either my house is REALLY clean or it isn't working
i had the same problem. The goo pulled from the air gums up the small orifice atthe bottom of the stem that sticks down into the water. If the water cannot be pulled up into the stem and expelled out towards the bowl at high speed, it cannot work. Take the upper, motor half off, unplug it hold the plate with one hand and twist the stem 1/4 turn and it comes right off. Clean the crud (yes, its your own skin cells) and the hole with warm water and soap. put it back together and refill with water and it works like new. this is now monthly maintenance for me
HTH
May 16, 2008 | Rainbow Rainmate Air Purifier
Air Purifiers Logo
683 people viewed this question
Top Rainbow Air Purifiers Experts
jdthefixer
Andrew Taylor
Andrew Taylor
 Russ Hill
Russ Hill
Are you a Rainbow Air Purifier Expert? Answer questions, earn points and help others
