Question about Whirlpool Home
I have an older aqua glass tub that has a controller made by tridelta Industries inc. they are no longer in business and I cant find the controller # CA 3585
I need controller CA 3585 it is a 240 volt controler that is air switch operated and has a controller for the 240Volt heater as well. The pump however is 120volt 3/4 hp
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 52 Answers
That control and the pump are no longer made. That system is very old.
What brand of pump do you have? If you can get me that information I will be able to find a solution for you.
Rod
www.uspartscenter.com
Posted on Jan 31, 2013
3 Suggested Answers
slingspade
  • 6 Answers
SOURCE: My new heater does not work on my hot tub.
Test across both terminals at the same time. If you are getting 230V, disconnect power and check the resistance across the terminals. For 4kW, you should get roughly 13 ohms. If not, the element is bad.
If you get 0 Volts across the terminals, the tub is not heating. ManyBalboa packs switch both leads to the same leg of power, so you can get 120V to ground from each terminal, but you get 0V from terminal to terminal.
The clincher here is that the "heater on" light is off. I would double-check the pressure switch. You should test it with the tub running in heat mode. Disconnect one of the flag terminal leads from the switch, THEN test for continuity across the terminals. If you get none, you have either low flow or a bad pressure switch. You can verify by jumping the two wires together and see if the "heat" light comes on. Again, check for flow. I would run any of these tests with the filter removed. The symptoms you describe are very commonly caused by a dirty filter causing low flow. Again, pressure switch test. A bad sensor would cause the "current temp" to read too high, and a hi-limit problem would cause the little "heater-on" light to flash. Unless that little light is just dead (I've never seen it go bad), everything you say points to the pressure switch (or a dirty filter).
Posted on Dec 13, 2009
  • 80 Answers
SOURCE: I have a Swirl Bath jetted tub that decided to
The switch is avaliable online, it is a very common failure, sometimes the switch will stay on and not shut off, sometimes it is the other way around. If the pump is accessable the switch is easy for most handymen to switch out. Be sure to unplug the pump before starting the job. Type is Jacuzzi air switch in google and take you pick of suppliers. the switch can cost 20 to 30 dollars depending on the supplier.
Posted on Jul 04, 2010
I need to find an air actuated timer for a spa tub.
replacement units will be available from any good spa and pool shop
Jul 06, 2015 | Cars & Trucks
Hot Tub won't Turn On.
First check the breaker box for the house and see if it has power.
Jun 26, 2015 | Home
Aquabrass tub drain control lever cover separated from nut
lock tight red or stronger will bond it together . but forget remove it after
Nov 16, 2013 | Aqua Brass Deckmount 5 pc tub set with...
Aquabrass tub drain control: cover separated from nut
Try using jb weld or another type of epoxy that is water proof. 100% silicone caulk may also be worth a try.
I have an Aqua Glass Jaccuzzi that I haven't used in 10 years. The last time it was used it worked perfectly. Now I can't turn it on at all. I don't remember is just the round dial that
Check the circuit breaker and make sure you have power to the pump.
If you have power to the pump and it is not operational when the tub is full of water and you are in it then I would say you have a serious problem.
Most all of the older control that Aquaglass has used in the past have been discontinued.
You may want to visit this link and identify your control before you begin t trouble shoot your system.
Rod
US Parts Center
888-521-6183
Feb 27, 2013 | Whirlpool Safety Bath Walk In Bathtub -...
I have a Swirl Bath jetted tub that decided to start running on it's own. The motor has a air actuated timer switch that I suspect is the problem. I've looked for the switch in multiple sites without any...
Jun 27, 2010 | Home
Business in Australia urgently requires hydraulic schematics plan, flow rates and work pressures, pump and hydraulic motor speeds etc. for Crushtek 12/5 Screen - thank you.
CRUSHTEK IS NO LONGER IN BUSINESS...THIS SHOULD HELP:
for calls outside of the USA 001-775-356-9554
Postal Address:
Ericson Industries Inc.
260 Freeport Blvd,
Sparks, NV.
USA 89431
IF THIS HELPS MAYBE U COULD SPONSOR ME. I REALLY DESIRE A JOB IN AUSTRALIA.
THX,
JOHN
Jan 12, 2010 | Computers & Internet
Aqua glass whirlpool tub leaks. looking for closure caps to close off the jets for good.
To my knowledge there are no closure caps for your tub; you can however purchase new jets with new seals if the tub is leaking through the jets.
Aug 29, 2009 | Home
Diaphram defective and microswitch not being activated
You should be able to go to any search and type LEN GORDON air switch for a source.
Nov 16, 2008 | Aqua Flo Aquaflo Tub - Master Tmcp with...
Home Logo
94 people viewed this question
Top Whirlpool Home Experts
Donni Steen
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
