Question about Makita 7 1/4" Circular Saw 5007NB
My Makita circular power saw works then stops working, then starts again. Why is this happening?
  • Makita Master
  • 885 Answers
Things to check: With the saw running, safely grab the cord by the boot and pull and twist it around. This is where a break frequently occurs inside the cord and when the saw is held in certain positions the break will either open or close. If the cord's OK, unplug the saw and remove the brush caps and check the brushes. If the brushes are less than 1/4" long or the springs are burnt or broke they won't make good contact with the armature. If the cord & brushes are OK your next recourse is to replace the switch (Makita PN 651172-0).
Posted on Jan 23, 2013
picatudo
  • 239 Answers
SOURCE: i have makita petrol stone cutter.it starts but wont take revs
it needs more gas adjust the screw on the carburator
Posted on Feb 07, 2009
outdoorsman5
  • 631 Answers
SOURCE: I cannot get a perfect 45 degree angle with my
When using the gauge on your saw it is off on the 45 degree cut? If so you might have to use a tri Square every time you want to cut a 45. Sometimes the lock gauge for the 45 angle may be off some. When you put a tri square on the board you cut it is not a true 45 even though the saw says it is?
Posted on Jul 29, 2009
SOURCE: Makita Saw blade brake doesn't work.
i have a makita still saw put i pull cored but it dose'nt start
Posted on Jan 21, 2010
rowdy45176
  • 2176 Answers
SOURCE: I have a makita circular saw 5704r. I droped the
it is a retaining ring and you need a special pair of pliers to remove this. If the guard is sticking remove the blade and lube and try and blow out with compressed air, if other let me know and I will try and help.
Posted on Jan 31, 2010
rowdy45176
  • 2176 Answers
SOURCE: The return spring for the blade guard on my Makita
there should be a hole in the housing towards the back of the saw, you can go to Makitatools.com and download a breakdown for this tool.
Posted on Feb 03, 2010
My Makita DSS610 18v cordless circular saw stopped working mid cut. I changed the battery to another, fully charged, one but still nothing. Tried again next day, with both batteries, still nothing.
Hello Derek, it seems that your motor or motor brushes have failed please contact the manufacture about replacing the motor brushes.
Sep 15, 2016 | Makita Saws
My Electric saw works intermittently
Could be it's overheating. Clean out all sawdust from the vents on th e motor body, and wherever else you find sawdust. Check that you're using a sharp blade. Check all wiring connections are secure. You maay need to remove the cover behind the on off switch to check thatb all the push on connectors are pushed on tight.
Jan 21, 2013 | Makita 7 1/4" Circular Saw 5007NB
How to get motor out of houseing on a makita 5007MG circular saw
The armature and field will need to come out. It's quite a bit of work to swap everything over. Here is a parts diagram which should help.
Makita 5007MG diagram
Aug 06, 2012 | Makita 5007MG Factory Reconditioned 7 14...
Makita LS 1212F brake
The brake on these saws is a controlled by the switch; it allows power to only one side of the field when you release the switch thus pulling the motor to a stop. In order to get your brake working again you have to replace the switch with Makita part number 651923-1, Switch TG70B. You can put in a generic switch that fits but the blade will spin slowly to a stop every time you release the switch, which you may have now.
Jun 29, 2012 | Saws
Makita ls 1211
The 'brake' on tools like this is actually a function of the switch allowing some current to flow to one side of the armature to magnetically stop the motor & blade. If the motor works fine but it is no longer breaking you need a new power switch. You need Makita part number 651923-1 for an LS1211 saw.
May 21, 2012 | Saws
Makita "7 1/4 inch" circular saw poblem. the saw seems to lose power soon into ripping boards. if you letit sit andcool, it will work again, but will quickly cease upagain. the saw blade seems to go...
Clean the armature and install new brushes, the armature is burned with carbon and loses its ability to conduct electricity properly. Make sure to in between every copper rib on the armature so it doesn't ground itself back out.
Oct 06, 2010 | Makita 5007MG 7 1/4 Inch Magnesium...
Instructions or diagrams on how to replace a power cord for a makita circular saw.
here's a article on how to fix it.
http://www.amazines.com/Electronics/article_detail.cfm/78565?articleid=78565
May 05, 2010 | Makita 7 1/4" Circular Saw 5007NB
Makita 7 1/4" Circular Saw 5007NB Logo
259 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
