Question about SATO CL408e Thermal Printer
How to reset network card - SATO CL408e Thermal Printer
Sim card rejected
Contact your Sim Card Provider to issue new sim with same number.This is the only way.Thanks for visiting fixya
Aug 06, 2011 | Nokia 1600 Cellular Phone
The jet direct card is not showing up on the configuration page
Two possible problems:
1. Bad formatter, not liklely if you have used this printer with this jet direct card for a while and have not removed the card from the printer.
2. More likely either bad or in need of reset jet direct card. I am going out on a limb and guessing that you have a Jet Direct 615 card. There is a small chance that the card just needs to be reset. To do this you must perform a cold reset of the printer. Any custom tray settings that you have made will be lost during this process as will any network settings. To cold reset, turn printer off and unplug the network cable. Hold the "checkmark" key and power on the printer. Keep holding the key until all three leds turn on solid. Release the checkmark key and use the arrow keys until "COLD RESET" shows in the display. Press the checkmark key and until will perform a cold reset and restart. Plug your network cable back in and print a configuration page. If card is working again great, if not, it is likely that the card is dead and will require replacement.
If card does work, you will want to ensure that the Jet Direct card has current firmware on it. Use the HP Download Manager to update the firmware on your Jet Direct card.
Good Luck.
Apr 18, 2011 | HP LaserJet 4200 Printer
I have a D-link DSL-500T modem, when i connect it to my Acer GX260 pc , i got this error ' Network Cable Unplugged' . I have try changing the cable but i got the same error. Then i try interchange the...
Can you try reset the network card and also reset the modem by pressing into the little hole on it for like 30 seconds? To reset the network adapter card, you can right click on the network connection of your LAN connection and click on diagnose if you are using Windows Vista. Then you will see the reset network adapter card option. Or you can follow the steps on the following link.
http://windows.microsoft.com/en-CA/windows-vista/Troubleshoot-network-adapter-problems
If you are using Windows 7, then the following link will include the steps about troubleshooting your network adapter card.
http://windows.microsoft.com/en-CA/windows7/How-do-I-fix-network-adapter-problems
Aug 18, 2010 | D-Link Computers & Internet
Resetting the adapter
Use the computer you are on to download the updated driver for the network adapter from the Toshiba Website. After you have the updated driver install it on the computer your having a problem on. Reboot the computer. If the problem is still there and you have a cable connected to the network connection and to the router, uninstall the network adapter from the device manager and reboot the computer. That should detect and install the adapter and resolve the problem. If it doesn't there is a problem with the network adapter and you will need to use the wireless of get a PCMCIA card to use for networking. Toshiba does use a replaceable Network card in some laptops, if nothing else above works and you don't want to get another card to plug in you may want to look into purchasing a new card from Toshiba to replace the old one.
Jul 22, 2010 | Toshiba Satellite A100-S8111TD Notebook
Can not make phonecalls or recieve
Reset the iPhone:
It has been observed that simply resetting the iPhone can resolve network issues.
Reset network settings:
In some cases resetting the network settings has also helped so tap Settings, tap General, tap Reset, tap Reset Network Settings.
This will restart your iPhone and will also delete any stored Wi-Fi passwords as well as DNS settings and more.
Place your SIM card again:
If your iPhone’s SIM card is not placed properly, it has been observed that it can cause network issues.
So a good idea would be to remove your iPhone's SIM card by pushing a straightened paper clip into the small hole on the top of the device to open the SIM tray, then check for debris inside the tray or SIM card slot, remove it by blowing into the slot or using compressed air and then placing the SIM card properly and then re-inserting the SIM tray.
The notion is that improper SIM contact can result absence of signal, so the above procedure could help.
Attaching scotch tape to the SIM card:
This is indeed the most ingenious methods, it appears that attaching a small piece of scotch tape to the outer side of the iPhone’s SIM card (the side of the SIM card that does not have metal contacts) can result in a surprising boost again borrowing from the notion that improper SIM contact can result in a weak signal.
May 28, 2010 | Apple iPhone 3G
What is a sim card reset code
A sim card is also referred to as a puk code which enables you to reset your sim card and all related pin codes in case you forget,
The puk is a network associated code and can be gotten from the sim card packet or directly from the network provider.
Cheers
May 02, 2010 | Samsung A177 Cell Phone
I have just bought a belkin network card, installed it correctly and attempted to connect it to my network. It connects, but after 5 minutes, disconnects and forces me to re-boot the router... I can't fix...
1. reset your router on factory reset and after try to connect your router, if you get success then you re configure your router agin with IP address 192.178.1.1
Mar 25, 2010 | Belkin 802.11g Wireless Desktop Network...
SATO CL408e Thermal Printer Logo
44 people viewed this question
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
pkwc
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
