Question about Jl Audio 300/4 Car Audio Amplifier
Green light blinks slowly on my JL Audio 300/4 amp
I just replaced the battery in my 2004 Avalanche and the receiver and subwoofer (bazooka) works, but the JL Audio 300/4 power amp is not working as the green light slowly blinks off and on. Help!
  • jlaufer4 Jan 28, 2009
    We found the problem to be the ground wire attached near the driver's side rear door. After reattaching with a new washer, everything worked. Thanks.
  • Jr20 Feb 03, 2009
    I have a Hollywood Amplifier 750w...and this green light keeps blinking on/off...i tested on my friend's car to check if it was a wrong connection on my car, but the same thing happened. Some one on the web told me it could be the solders inside the amp. is it true?
  • 4 Answers
I got autotech 1000 watt amp i had sony 1200 watt i had it hooked up the light stayed green and the autotech want say green it keeps blinking it wont stay solid
Posted on Jul 06, 2010
    Scholar:
  • 116 Answers
Check your fuse at the battery. While AGU glass fuses "look" good, when you read the voltage AFTER the fuse, you can only be getting 5 volts or so. I can't tell you how many times I have seen this.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
Can you use a bazooka ba1150 to power up an infinity 1230w sub? not a techie just happened to have these two items and was wondering if i can use them together. thanks.
This is an 150 RMS amp, but the ratings say it'll push 2 10's.
You probably won't get much out of that amp with a 1230 watt subwoofer.
The subwoofer you are wanting to run is 300 RMS, so you'll get half the power you could be pulling. But it would do okay I guess. Nothing like what you could get with a different amp though. You need like a 1000 watt amp to get the most out of your sub. But "YES" you can use them together.
Aug 01, 2010 | Bazooka BA1150 150 Watt Monoblock...
I have a JL total mobile audio T500.1 mono amp and it was playing then all the sudden it stopped and the power light which is usually green is now red and stays red and no sound comes from the subs any...
This happens when the amp goes into protection mode. 90% of the time, it means there is a short or has another issue inside the unit and has to be fixed or replaced. Hope this helps and good luck!
Jul 09, 2010 | Jl Audio Car Audio & Video
My Jl Audio 500/1, power light comes on but no power to subs
maybe it dont have enough to push it ,,did you try it before you buy it?
Mar 01, 2010 | Jl Audio 500/1 Car Audio Amplifier
I NEED A SUBWOOFER THATWILL FIT INT A 2008 MISUBISHI RAIDER CLUB CAB( SAME AS DAKOTA. ANY SUGGESTIONS
Hello andrewsa104,
If you are looking for something that is made specifically for vehicle, two possibilities are JL Audio Stealthboxes and MTX Thunderforms. These are generally "turn-key" systems with amps included. But check.
Here's a link to a thunderform that fits a 2002 - up Dodge Dakota Quad Cab.
A less expensive approach would be a generic powered subwoofer system that you fit under a seat or behind a seat. Many manufacturers offer such solutions, including Bazooka, MTX (thunderlink), Infinity (basslink), etc.
Hope this helps.
Oct 18, 2009 | Car Audio & Video
Got jl300/2 amp confused which subwoofer sounds good
Hello drsubhakar26,
JL W6's will perform well with from 150-600 watts RMS. W7's with from 150-500 watts. Less expensive Alpine Type R's work OK with from 200-500 watts RMS. Either of the brands will sound good. None of them will perform to their full potential with 300 watts RMS. Powering any sub with a 2-channel amp is a compromise. A monoblock is more efficient.
Hope this helps.
Jul 12, 2009 | Jl Audio Slash 300/2 Car Audio Amplifier
Jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Apr 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
JL 300/2 v2 Power Light Blinks, No sound out of Sub. Works in friends Car HELP
Are you sure you don't have any shorted wiring or defective speakers?
Sep 30, 2008 | Jl Audio 300/2 Car Audio Amplifier
Have a jl 500.1 amp
for that amp u need a compasitor to mantain the amps the amp draws the amp is being choked when the car is off and when its running its killing the cars charging system
Jun 25, 2008 | Jl Audio E1200 Car Audio Amplifier
Wrong connection
You should have blown a fuse. Check the main power fuse feeding the system (usually at the battery). If it appears to be good, you'll need a multimeter to check the voltage at the B+ and remote terminals of the amplifiers. Place the black meter lead on the ground terminal of the amp when testing. .
Dec 16, 2007 | Jl Audio 300/4 Car Audio Amplifier
Jl Audio 300/4 Car Audio Amplifier Logo
1,147 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
