My system volume just keep cutting off and I can't find the stereo button
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Press all the buttons you can find , one of them is the volume button.
Posted on Jan 22, 2013
  • latrice petty Jan 22, 2013
    I meant while its playing the volume just opposed out and I have to power it off then on
Why does stereo amp cut out at higher volume
You seem to have the answers to your question. I would just resolder the connections anyway without checking. If it solves the problem you have saved yourself a lot of money. If it doesn't follow the other steps in order of cheapness!
May 03, 2013 | Audio Players & Recorders
My Studio Standard by Fisher stereo system's audio keeps breaking up.
Could be a defective volume control. After 20 years, it would not be surprising
Apr 10, 2013 | Fisher Studio Standard Am/fm Synthesizer...
The volume has went off on my tv. its a samsung le26b450c4w
First verify that the mute is disengaged (toggle the mute button). Second, check the sound configuration to make sure the internal speakers are on, or check the sound output to make sure it is going to the inputs of an external audio amplifier (stereo receiver) and that the external amplifier is working. Try a different input source - perhaps the problem is your cable feed or DVD player.
If the internal speakers are on, the volume is up, and you still don't get any sound from a known-good source (TV channel, DVD player, etc.), then try running the sound to a stereo system as described above.
If that works, you may have a shorted speaker amplifier (depending on the set's design, this may blow a fuse supplying power to both left and right amplifiers or a speaker protection circuit will keep the speakers disconnected). These aren't usually hard to repair, but if you find a blown fuse, fix the amplifier before replacing the fuse or you'll just waste another fuse.
Jan 09, 2012 | Samsung Televison & Video
Car stereo speaker only works with volume turned way up
try the fade button, if its a 4 speaker system you have balance left and right, and fade front and rear.
Dec 21, 2011 | Clarion Car Audio & Video
I have a boat and installed a jvc stereo and a kenwood 1000w amp to power my 10inxh jbl sub running off the stereo 4 6by 9 3 ways and 2 twitters volum cut out at 33 i do have the amp wired direct to the...
Sounds like you have a lot of equipment on your boat, cool. But you need to think about the load you are putting on the battery. If you don't have a way to charge the battery back up, you just keep getting the power lower and lower the more you play. Also, with that much draw, it probably doesn't take long before you experience this. Unless your engine is internal and has an alternator to it to recharge the electrical system. This will keep happening. A couple of choices you can make. Either downgrade your system to something that has less draw (definitely ditch the 1000w amp and sub), or you can put more batteries in your boat. Kinetik makes great audio batteries, but regardless of how many you put in your boat, there has to be a way to recharge them. You will probably need to recharge the battery after every use. Hope this helps
Aug 28, 2011 | Car Audio & Video
I have a Sony Eplod MEX-BT2800, all of a sudden the buttons/functions won't work, I currently have a CD in the player, the buttons to skip songs won't work and I can't even eject it. Also I...
Hi i removed the positive on the battery terminal and tried the stereo still no buttons work although the source button and volume work but thats it any ideas thank you
Jul 06, 2011 | Sony MEXBT2800 AMFMCD Car Stereo Receiver...
When i use the volume button on the remote a yellow icon comes up and i cant change the volume, help please
You may have the FIXED VOLUME LEVEL feature enabled in the AUDIO OPTIONS section of your TV's menu. You should be able to disable it from that menu as well if necessary.
This feature is often used when you are sending the audio signal out the rear audio output connectors of the TV to a stereo or home theatre system amplifier. That way you hear the TV audio through the stereo's large speakers instead of the small TV speakers. Then to raise the volume of the TV audio, you simply adjusting the volume of the stereo with the stereo remote instead of using the TV remote.
If the channel selector does not work either, then it's possible that you may have the CHILD LOCK feature engaged. See you owner's manual for instructions on how to disable the CHILD LOCK.
Good luck, I hope this was helpful.
Jul 04, 2011 | Televison & Video
It keeps saying protect when i turn up the volume
The stereo is not letting you turn the volume up enough to damage the speakers. That's all. It's a nice feature.
May 09, 2011 | Sony MHC-RXD9 Shelf System
Stereo cuts out at half volume.
You don't exactly define what "cuts out" means.... silence, protection or power off?
What makes you think it's thermal in nature?
Have you considered the speaker load impedance may be too low for the amp?
May 02, 2010 | Audio Players & Recorders
Overall Problem - Panasonic RX-ED707 won't work properly at all
only 1 reason for that faults :
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
Nov 14, 2007 | Panasonic RX-ED707 Boombox
 Grubhead
Grubhead
