Question about GPS
My Navman 80T won't charge in the car using the cable it came with, any ideas?
Charge doesn't last long when done through the computer and it doesn't seem to be charging when plugged into my car cigarette lighter.
Your cigarette plug may have a short in I had the same problem with my phone charger and had to replace the cigarette outlet
Posted on Jan 22, 2013
Asus charger won't charge
Stop using that charger. I sounds like you have a break in the wire and when you hold it in the right position, the two pieces touch and current flows. Unfortunately the heat is probably being caused by arcing and is a potential fire hazard.
Apr 06, 2017 | ASUS Original 19v 3.42a Ac Adapter Charger...
Lenovo Ideapad Z570: Battery indicator shows the Power is plugged in & charging. But the Battery charge percentage doesn't increase. How to fix this?
The battery might be nearing the end of it's useful life and needs to be replaced. The battery only lasts for so long then it has to be replaced.
Buy a battery on ebay base on your computer's Make and model, not the model of the battery.
May 14, 2012 | Lenovo IdeaPad Z560 Notebook
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
Dear HTC, my phone is not charging properly & not showing any display regarding the charging
replace the battery- sounds like it's completely shot. If it still doesn't try- use a micro usb cable attached to a PC- if it still won't charge/come on- the charge board is gone, and you will likely need to replace the phone
Jun 22, 2011 | HTC Touch P3450 Smartphone
My Garmin nuvi 265 was working fine until 2 weeks ago. We got a screen message saying that the XM traffic was not supported, and then noticed that the unit no longer could be charged using the car...
The traffic receiver is in the car charger cable. The charger should have a red light on if it is getting power. If the light is on and the unit is not charging and you have no traffic, the charger cable is bad. If the light is off, then either the fuse did not fix the problem, blew again, or is somehow not sitting properly in the charger. Another thing you can check is by using the unit in another vehicle. If it works fine there, then the charger is not making good contact with your vehicle outlet for some reason. You will probably have to buy a new traffic receiver charging cable.
May 04, 2017 | Garmin nuvi 265 Car GPS Receiver
I've changed my battery just last November. I did
Well, if the Batt don't hold charge then check the regulator on the bike with an Ohmmeter you can buy one at an Auto parts shop....motor running you should see 14.5 V if not then the Reg is out!!!
May 24, 2011 | 2001 Harley Davidson FXDWG Dyna Wide Glide
My asus notebook won't charge i just bought last five days ago, and now it won't charge.. i tried to remove the battery and attach the adapter, but it still doesn't open..
if it wont charge it most likely has a bad battery...if you just bought it, I would suggest returning it for a replacement. Make the vendor or manufacturer make good on their product.
May 12, 2011 | ASUS Eee 4G Notebook
Navman f20 will charge fron usb port on computer but not with in car charger
If it's not the original Navman usb loader then there's a easy solution to this : With a sharp knife carefully open the usb cable : you'll see four tiny cable's with different colours . You;ll have to cut two of those four cables ; Leave the black and red cable intact.
Use some tape to fix the cut in the usb cable. Now you can use your car charger and your navman won't go into usb mode.
Dec 08, 2009 | Navman F20 GPS Receiver
Navman won!t charge from in car charger or mains adapter but will charge from garmin in car charger
Your Navman will not run in car unless the output on the charger is 1000ma or 1a. you need to buy a genuine charger, motorola phone chargers do not have the output to run the unit
Jul 22, 2008 | Navman F20 GPS Receiver
Can NavMan 520 charge via USB?
that is probably due to the battery being totaly dead,
try using a mobile phone charger (nokia),
usb is for data transfers.
Jan 04, 2008 | Navman iCN 520 GPS Receiver
GPS Logo
185 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
