Question about GE Spacemaker JVM1640SJ Microwave Oven
Remove control panel on je1640ga
I have a GE microwave (model JE1640GA) with a bad door switch. i can't remove the control panel to get to the door switches. There are no screws holding it on.
  • GE Master
  • 17,129 Answers
Click on : Microwave parts
Posted on Jan 22, 2013
3 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave does not turn off when door is opened
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so with a one-year guarantee.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 30, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: can"t find a replacement model
Ge customer service should be able to tell you waht model is a "drop-in replacement" for your model.
Just be sure to give them, the full model number found on the tag inside the cooking cavity.
GE Customer Service is here.
Posted on Jul 11, 2010
What can cause a microwave to come on when the door is opened, never seen this before and is very dangerous. it happens with or without time set.
The most likely problem is a faulty door switch, you can buy new switches, but you'd have to follow the diagram here to identify which of the 2 switches you need to replace: See Part # 26
http://www.partselect.com/Schematics/GE/00008593i01.gif
you can find the parts here:
GE WB24X830 Monitor Door Switch PartSelect
GE WB24X829 Secondary Door Switch PartSelect
Jul 14, 2014 | Microwave Ovens
Why is my je1640ga is not heating
You Most Likely Have A Defective Microwave Diode Or High Voltage Capacitor..Both Inexpensive & Easy To Replace..
Jun 30, 2014 | Microwave Ovens
Je1640ga 001
That's either a shorted high voltage diode or a failed magnetron.
See:
http://www.microtechfactoryservice.com/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.microtechfactoryservice.com/mag_test.html
You can order GE parts from the Pros here.
Jan 19, 2014 | Microwave Ovens
GE microwave (Model JE2160SF03) trips breaker when door opened
Remove the control panel, take pictures of the door switch wiring while they are still connected to the door switches, then remove the door switch assembly. Have someone at the appliance store check each switch and repair the ones that are defective.
I purchased a switch for $7, reinstalled the door switch assembly and the microwave is working fine now.
Jul 02, 2012 | GE Microwave Ovens
Ge xl1800 microwave door close fan keep running
That's usually a defective upper or lower door switch (or either switch's mount may be bad) or a stuck relay or bad electrolytic on the control circuit board.
Our file on door switches is here.
After you or a friend look that over, if you still have a problem, we repair these control boards for $39.95 with a one-year guarantee.
Instead of having yours repaired, you can buy a new control circuit board from the Pros here, our favorite supplier.
Jul 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge space maker Ge model jvm1650sh01.  Serial hg
It may be a defective upper or lower door switch (or either switch's mount may be bad) or a stuck relay on the control circuit board.
Jul 07, 2011 | GE Microwave Ovens
My 1998 ge GE JE1640GA 001 microwave, all buttons works,lights on, the problem is it will not heat,and the tuneable do no spin, please help
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 20, 2011 | Microwave Ovens
Can"t find a replacement model
Jul 10, 2010 | GE Advantium 120 Convection/Microwave Oven
William E. Miller
prototech@usa.net
Aug 25, 2009 | GE Microwave Ovens
GE JE1640GA does not heat, the control is working but when you put the time and start its not working.
The latch on the door of my microwave did not make a connection with the sensor inside.  The GE mechanic fixed this problem by slightly pushing the door upwards (with simple manual force).  That's it. It works fine now.
Aug 20, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
139 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
