Question about Hotpoint Washing Machines
Water will not heat up washer works as normal
  • Hotpoint Master
  • 17,130 Answers
Possible that the element has failed or that there is damage to the wiring to the element or there is switching from the controller.
You need to check this out one by one.
Please click : element
Posted on Jan 22, 2013
The circuit breaker shutts off when my washer strats heating water
it may be the next stage after the water is hot and it turns off selecting the next operation
Apr 14, 2014 | Zanussi Washing Machines
Whirlpool quiet partner 2 , not filling with water
First try resetting your error code if there is one from your manual, then try the below.Also check to make sure your thermal fuse is good as well then do below.
Try pressing normal wash -heat dry-normal wash-heatdry- normal wash-heat dry- norma wash - heat dry. all the lights should come on. then after a little bit. keep pressing start till disher washer gets back to normal shut down. Sometimes this uses other features and opens contacts that are rarely used and recycles the processor in control panel reactivating stuck contact solenoids.If none of this works your control panel needs replaced cost 100 up to 200 dollars. Remember to rate my solution and this is how i earn my achievements here on FixYa.
Apr 25, 2012 | Dishwashers
The clean light flashes on and off continusuly and washer will not start a new load
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 13, 2011 | Dishwashers
Samsung WA80v3 connected to cold water supply. Does it heat water during wash cycle or does it have to be connected to hot water supply if heat is required?
It will heat the water as normal, even though it is a cold fill only washer.
Just select prog as normal, washer will do rest.
May 18, 2011 | Washing Machines
Control panel got soaked. Panel lights up as normal and does everthing but work - no pump, no water movement. Washer was stopped mid cycle with water in it, naturally.
remove all connectors 1 at a time and make sure theres no corrosion or moisture that can kill system signals,then if theres moisture,carefully dry out boards with heat then again check connections
Mar 03, 2011 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool auto load not filling with water to wash, but will go to rinse cycle
There are 2 inlet valves 1 for hot water and 1 for cold. Sounds like your hot water valve is either faulty or the hot water valve to it is off. The machine normally fills with hot water as it doesn't have a heating element to heat the water and fills with the cold water to rinse
Feb 24, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Water is not going into my dishwasher --worked for 13 months fine and now having a problem. When I turn it on the motor runs and rattles - louder than before, but no water is going into the dishwasher. We...
try running a diagnostic run on the washer. Push heated dry, normal, heated dry, normal on your cycle selection panel. After you push that sequence all the lights will light up and then it will go through a test run. This fixed my washer that had the same symtoms as yours. For some reason the diagnostic run reset the washer and it ran like new. I also checked to make sure the overfill float in the bottom of the washer could move up and down freely. It is a small white disc float. If it is stuck in the up position your washer won't fill up. Besides those suggestions, my level of mr. fix it knowledge is limited. I hope this helps.
Jan 11, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
On the normal cycle of my Duet front load washer at 37 minutes the machine stops and flashes F5. I push the reset button then the start button and the machine works fine after that.
HI. This is a Water temperature sensor error.
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Replace failed component.(Most common issue will be a failed water temp sensor)
Jul 25, 2009 | GE WBVH6240F Front Load Washer
Zanussi ZWF 1432 washing machine
because theres more water it takes a lot longer to heat.
May 04, 2008 | Zanussi ZWF1430W Front Load Washer
Electrolux ESL 6225
before you operate the dishwasher get your water as hot at the sink as you can this will prevent filling the dish washer with cold water and i would use powder or liquid now if you not sure of your heating element turn your washer to dry close the door for about 2-3 minutes get a glass of cold water open the door and pour water on the element if it sizzles its working
Feb 12, 2008 | Electrolux 23 in. ESL624 Built-in...
Washing Machines Logo
13 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
