Question about Sceptre X9G-NagaIV 19" LCD Monitor
The monitor gone blank white light nothing else
When I started recently, the monitor gone blank white. The light indicator blinking for a WHILE then gone off, I can not turn the monitor off or on by the indicator
  • 537 Answers
Check this FixYa thread:
http://www.fixya.com/support/t1372203-white_screen
It might be a loose cable or perhaps the video controller is bad. If the unit is out of warranty, you might be able to try to fix the cable.
Posted on Jan 27, 2009
L246WH blinking light problem
Probably the power supply is failing but periodically recovers briefly.
Jan 05, 2014 | LG L246WH-BN Monitor
Monitor will not power on
the best sway to deal with apple products is to bring it to apple themselves......9 out of 10 times they will fix it for nothing
Jan 11, 2013 | Apple Cinema Display 23" HD Monitor
Hey Experts! I need assistnace. My Samsung 2043BWX 20" monitor is black (or blank). I do have a flashing blue LED next to the power. When I plug the monitor in a power supple without being connected to the...
Actually, the ultra high voltage 'charger' for the florecence (a.k.a. your back light)has gone Kaput...
If your lucky, someone will have a monitor like yours that has the back light come on, but no picture (should get a similar blinking light situation, but a different code. Like... blink, hold, blink blink, hold, blink). In this situation (if your comfortable doing it) you can swipe the exciter from that monitor and put it in your monitor. Obviously this is a more economical way of repairing the monitor.
Just to be on the safe side (as the repair is blindingly easy. 6 screws, pop out, pop back in) DON'T touch any of the back side components. You WILL shock the supreme **** out of yourself. Between the heavy duty capacitors and the ultra high gain transformers on those things you could jump start a bus. So don't be fooled... those little transformers pack a mean sting.
Hope this helps...
Oct 11, 2010 | Samsung 2043BWX 20 inch Monitor
Hello I have a hp Pavilion DV3 1075us and recently It has started presenting some problems. I cannot initiate it the screen keeps blinking in an white flash in an interval of 4 sec. And the numlock and...
The blinking lights indicates the problem:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Also, if the computer starts up and nothing is happening, the lights are on and the screen is dark, then the CPU is broken.
Jul 04, 2010 | Computers & Internet
VX924 (Silver, Black) 19" LCD Monitor: monitor has suddenly gone white...
My VX924 did the same thing but now displays nothing and power switch light just blinks. According to an answer listed on previous page, it may have bad capacitors. I may have to take a look at them. Viewsonic repair facility examination of this monitor runs $70.
May 17, 2010 | ViewSonic VX924 19" LCD Monitor
Apple Cinema HD Display 30'' black screen, power light blinking
I don't know what might have happened, but a number of years ago I had an apple monitor and the power light on it started blinking, so I got in touch with apple and they told me that it's flashing an error code, so they told me what the blinking indicated and fixed it.
So I think the blinking of the power light on your monitor could be indicating an error code so I suggest you call apple and they will identify what the error is indicating.
Feb 11, 2010 | Apple Cinema HD 30" LCD Monitor
Syncmaster 941bw coming up blank
Hummm. Try to unplug everything, reconnect, than restart. If not working, try to plug your monitor on a different computer to diagnose what is wrong, the computer or monitor. It could also be your graphic adapter, verify that it is firmly attached to the motherboard.
Lastly, replace the defective part.
Mar 27, 2009 | Samsung 941BW LCD Monitor
SVA Color TFT LCD is white on start up but goes blank.
when i turn the computer on the light on the monitor blinks green but i cant get it to turn on..i have a black screen.
Jan 16, 2009 | Computers & Internet
Why is my Monitor blank when i switch on the pc?
Normally, blinking indicator lights and no display on the monitor indicating a wrong resolution or refresh rate frequency, that the monitor can not display it.
To fix, enter safe mode, and configure the display to the lowest resolution. After restart, you should be able to have the display.
Dec 31, 2008 | Intel D945GCCR Motherboard
After 15 -20 min my monitor goes blank
This could indicate a problem with the graphics card. Take the card out and clean it, then clean the slot that it fits into. (I normally use a small dry paintbrush).
Replace the card, making sure that you push it down gently but firmly and ensure that the plastic clip has gone back correctly that hold the card in place. Rescrew the card back to the casing correctly and reboot.
Hopefully this will resolve your problem. If it does not, to determine whether or not your graphics card is faulty. Change the monitor lead over to the onboard graphics port instead of the agp/pci port and reboot. If the monitor works properly with no problems, then you have a bad graphics card.
I hope this helps.
Nov 13, 2008 | Intel Motherboard
Sceptre X9G-NagaIV 19" LCD Monitor Logo
158 people viewed this question
Top Sceptre Computers & Internet Experts
Cleverer2
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
