Question about KitchenAid Kitchen Aid - KBFS22EWMS
Icemaker/stopped operating/(when elctronic control lost power and restarted again
    New Friend:
  • 169 Answers
Make sure the swing arm is all the way down and not hanging on anything.
Posted on Jan 22, 2013
My BI98 u-line ice machine won't stop making ice even with bin arm up.
I would suspect the switch controlled by the tray full sensing arm/bail. That's kind of like the main power switch for the ice maker. You can remove the outer cover from the ice maker with the power unplugged! Then look at the mechanical operation of that lever as it relates to the switch. The lever should cause the switch to open and shut off the timer motor. Some times you can buy the timer separately otherwise you replace the whole icemaker. Don't forget to remove power and turn off the water before you remove the old icemaker.
Oct 15, 2014 | U-Line BI-98
Icemaker starts then stops
The drop sensor is faulty, fooling the machine that the ice has harvested so it restarts. Eventually you will just have a solid block of ice. Replace sensor (magnetic reed switch)
Mar 08, 2014 | U-Line Icemaker
Hi, I recently been have a problem with my 1998 Honda, passport. While driving my Honda it would shut down then starts again on its own while rolling. At times it would not start again on its own you need...
sure, rolling in gear you mean. (same effect as push starting a car with M/T) what speed did it restart, 5mph or 50 or 85mph.?)
what transmission. A/T or M/T? BEG ERROR there !
shut down,?
you mean stalls,
and engine can do 3 things
run too slow (way below 800RPM idle , illegal idle speeds)
stalls (rpm goes to zero or you find zero power from the engine )
if you stop the car, and the engine stalls that is an engine stall.
or run perfectly.
does your model have a tachometer to you can see RPM?
and if idle controls work,
not posting the trans type, (non body does here) makes answers near impossible. infact most will just ignore you posts.
with a M?T car the engine immediately returns (hot ) to 800rpm
and is regulated very closely by the EFI brain (PCM)
if not you are seeing IDLE control failure.
with and A/T there is no MT clutch and when you stop
the autoclutch drags (wastes fuel like mad) and puts a huge load
on the engine, stopped say at a red light. the idle controls
on A/t are greatly taxed here.
so RPM can drop real low. fail. or stall. below 800
a stall happens at about 400 RPM.
the M/T can at any time be restarted on the fly (moving)
but just dumping the clutch. or just waiting as you coast in gear.
this is how push starting any M/T car works.
but on an A/T car , on the fly restarts take huge speeds.
and only works on A/T that have 2 oil pumps.
the A/T with no rear pump , the A/T can not be push starter
or coast restarted, if the front pump is dead(engine stalled)
im not looking up your tranny spec. because you never stated, it.
my engine stalls. (not tranny slip)
1: bad 12vdc power to any EFI system component.
2: never ever tuned up per the free operators guide in glove box.
3: lost engine compression. 1 or all cylinders.
4: lost spark. (or timed wrong, early cars have distributors)
5: bad fueling. too much or too little
when the engine runs , does the MIL, CEL glow running
btw the CEL also glows, at all stalls. the lamp only means.
I HAVE ELECT power, now.... only.
Sep 11, 2013 | Honda Cars & Trucks
Lg lmv1630bb microwave
Unless you are successful with a hard reset of the elctronics you are SOL and need to get a new control board. Check out the attached for parts Search Over 2 1 Million Appliance Parts
Aug 31, 2017 | Microwave Ovens
Icemaker stopped working
You will have to determine whether the problem is due to no water getting to the icemaker or a control problem in the icemaker unit.
There is a water valve near the bottom of the refrigerator where water from the outside source enters the refrigerator. This valve sends water to the icemaker (and probably the water dispenser) when the refrigerator controls call for water. These valves can malfunction, and the water lines can get blocked.
The other possibility is that something inside the icemaker controls has malfunctioned, and it is not calling for water.
Oct 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
How do you clear que on a c6300 photosmart
Windows XP Operating System
Restart the Print Spooler device
  1. Open Administrative Tools.
  2. On the Windows taskbar, click Start , and then click Control Panel .
  3. Click Performance and Maintenance . NOTE: This step is not necessary in XP Classic View.
  4. Click Administrative Tools .
  5. Double-click Services .
  6. Click Print Spooler .
  7. Click Stop to stop the Print Spooler.
  8. Click Start to restart the Print Spooler.
  9. Click OK .
  10. Restart the computer.
  11. Try the print job again.
Manually clear the print queue
  1. Return to the Printers and Faxes folder that you opened in the previous steps.
  2. Right-click the name of the product, and then click Open .
  3. Click Printer , and then click Cancel All Documents .
  4. Click Yes to confirm the action.
  5. If documents remain in the print queue, restart the computer.
  6. Try printing again.
Windows Vista Operating System
  1. Return to the Printers folder that you opened earlier in this document.
If the issue continues, proceed to the next step. Restart the Print Spooler device
  1. On the Windows taskbar, click the Windows icon (c01319360.gif ), click Control Panel , and then click Administrative Tools .
  2. Double-click Services .
  3. On the User Account Control window, click Continue .
  4. Click Print Spooler .
  5. Click Stop to stop the Print Spooler.
  6. Click Start to restart the Print Spooler.
  7. Click OK .
  8. Restart the computer.
  9. Try the print job again.
Oct 03, 2009 | HP Office Equipment & Supplies
Kia Sportage Engine Problems Start and Dies after 5 meter run...
did you check gas tank? for dirt or moisture.
something also crankshaft sensor
Aug 19, 2009 | 2000 Kia Sportage
Samsung RS2545SH refrigerator just stopped making ice. any advice?
Samsung Fridge  RS2545SH stopped cooling. The fridge section is about 50/55 and freezer is around 45. It wont go below. At one point, there was rumbling rattling sound from the compressor. Icemaker also stopped woprking.
Jul 18, 2009 | Samsung RS2630SH Side by Side Refrigerator
Icemaking cycle automaticall self stops and cleaning light blinks
ice machine runs one cycle and freezes ice will not release ice block to wire cutter. then after a few minutes the cleaning light starts blinking
Jun 11, 2009 | Kenmore 51lb. Clear Ice Maker
Icemaker stopped
Ok that means you need a new water valve. That is the part that the water supply from the wall connects to.
Dec 05, 2008 | GE GSS22JFMWW Side by Side Refrigerator
KitchenAid Kitchen Aid - KBFS22EWMS Logo
310 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
