We're can I buy a new power supply for a Vidikron Vision model 40? What is the normal failure mode for these units? None of the caps have bulges.
  • 5,138 Answers
Go to this website LCDalternatives . they sell repair kits for boards.
Posted on Jan 22, 2013
  • 8 Answers
SOURCE: RCA L26W11 26 in. HDTV
try pts or vance baldwin
Posted on Feb 12, 2008
budmrtn
  • 11361 Answers
SOURCE: power supply has blown fuse found two caps bad
You can contact them to see when they will have it back instock: http://www.shopjimmy.com/power-supply-unit-partnum-from-olevia-lt42hvi.htm
This the part number EEC-PWFSP27-000
Posted on Dec 06, 2009
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Posted on May 10, 2010
budmrtn
  • 11361 Answers
SOURCE: Lightning strike nearby caused momentary power
Main AC fuse is encased in the black shrink tubing, labeled with Fx next to two pin white AC input terminal; http://assets.shopjimmy.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/s/j/sj1av4u20c17400.jpg
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=Sanyo+DP42848+&stock=all&limit=100
Posted on Jun 17, 2010
budmrtn
  • 11361 Answers
SOURCE: I need a power supply schematic
Service manual; http://www.my.electronicshelponline.com/uploads/Insignia_Xoceco_LC-37HV41_NS-LCD37HD-09_LCD_TV_SM.pdf
Power supply is only $32.
http://bestbuy.partsearch.com/Model/Best Buy Company Incorporated/Insignia/NSLCD37HD09.aspx?SearchTerm=True
http://s807.photobucket.com/albums/yy352/budm/Insignia NS-LCD37HD-09/
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Posted on Oct 15, 2010
Vidikron projector Crystal One
Try Googling (Vidikron)(model)(manual) without parens.
May 06, 2017 | Vidikron Crystal One Lcd Projector
Rca model 132wd22 no picture and no sound
Hi Carl
Good... nice to see someone knows about Caps.
If Switch Mode Power Supply is working OK
Then it can only be bad Connectors orMotherboard failure.
Warranty???
Feb 18, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Insignia lcd lt20s power supply doesen't work (no turn on)
Possible that the power supply has failed. It can be due to failure of the SMPS- switch mode power supply - unit .Normally the switching drive IC or drier can be short and so there will be no chopping to the transformer. You need to understand this basic circuit so as to trace the fault.
Please check this link for support.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Dec 23, 2011 | Insignia Televison & Video
Sangsum 40 model LN40A450C1DXZA i can't turn it on. there is a flashy light on the right side of the tv. the only way to stop it is unplugging the tv.Thanks in advance Bill
The tv have a power supply board problems and it is the causes of this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jul 10, 2011 | Samsung LA40A450 40 in. LCD TV
Vidikron vision 40 2003 Power will not come on now and no power light. Occassionally will come on after 10 minutes after turning on but then shut down
The capacitors on the power supply need to be replaced. When you take apart the projector, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video For similar problem on Runco projector. Very easy fix.
May 23, 2011 | Vidikron Office Equipment & Supplies
Hi i have a grundig gu22dvd the power supply keeps turning off can i buy a new poers lead and transformer
helen366, if unit continues to do same thing, I suggest you contact Grundig for warranty service to put it right again!!! You must tell them that it should not have premature failure of the internal "switch-mode-power-supply" and they should replace the unit with new or refurbished same model free of charge.
12fixlouie
Sep 24, 2010 | Grundig GU22DVDPX 22 in. LCD TV
Vizio VX37L POWERS OFF
You need to check the DC output voltages of the main power supply, you may have failed power supply or shorted inverter board that causes the power supply to go into shut down mode.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 19, 2010 | Televison & Video
AL1610 code h4
This problem is fuser (the section that gets hot) related. It could be one or more of the following things :
Thermistor failure
Heater lamp failure
MCU PWB failure
Thermostat failure
Power supply failure
Interlock (door) switch failure
It could be that the thermistors(monitoring temperature) are just dirty and need cleaning or the thermostat has blown. THe heater lamp inside the fuser roller may have stopped working or their is a power supply issue to the fuser.
You could try pulling the fuser unit out of the copier and checking it / clean it. With these models its usually easier and cheaper to buy a whole new fuser unit.
You could try resetting the fuser error code in service mode.
To enter the service mode press the following keys
Clear (then) Density select (then) Clear (then) Density select (while in this mode do not adjust anything else as this could further damage your system)
enter "14" (with the copy quantity keys) and press copy key. Now restart the copier.
Feb 21, 2010 | Sharp Office Equipment & Supplies
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
Electro Med Services...
