Question about Standard Horizon Eclipse Fixed Mount Vhf Marine Radio
No sound light is on, channel 16 shows up, but no sound from the radio.
    Champion:
    New Friend:
  • 227 Answers
Try turning your gain up
Posted on Dec 20, 2013
Would like to scan programmed channels
The person who programmed your radio decided if and how the channel scanning would function, and whether or not the person using the radio would be able to program a scan list, and if so, which switches or buttons to use. It was all determined using computer software and by connecting the computer to the radio. Maybe you have a 3-position switch. Maybe by putting the switch in a certain position, you can program the scan list yourself. Maybe when the switch is in the right position, then pressing a side button turns on a green light to indicate that you've just added that channel to your scan list. Pressing the same side button again turns off the green light to indicate that you've just removed that particular channel from the scan list. Do this for all 16 channels, then put the 3-position switch into the scan-on position. Instead of a 3-position switch, the person who programmed your radio may have decided that the 2-position concentric switch would be used for programming your scan list. If you're lucky, then your radio has an LCD display. If so, then select PROG and look for a blinking square symbol to tell you when to program your scan list and look for a letter Z with an arrow on it to tell you that your radio is scanning. On the other hand, the person who programmed your radio with a computer may have decided that you did not need to have and of these options enabled.
Feb 07, 2014 | Motorola Radio Communications
How to enable all channels
The CP185 is dealer programmable for up to 16 channels. You would need to see an authorized Motorola dealer to have the radio reprogrammed to your additional FCC assigned frequencies.
Best regards.
Jun 09, 2012 | Motorola CP185 (16 Channels) Two Way Radio
How to replace the front panel light
Meter light is an easy fix if you can get ahold if an led light.Now the channel is a different ball game.The radio will have to be taken aprt. The channel display is a 16 leg chip.You will have to go in and unsoilder the one thats in it sounds easy, it isn't then you will have to replace it and soilder all 16 legs without touching the one next to it, thats if you can get it out without messing up the board...A cb shop sure sounds good at this moment doesn't it.
Apr 12, 2010 | Cobra 29 LTD CB Radio
Channel selector , part of digit burned out!like on ch. 19 it looks like 13!!
The LED channel displays on these radios are replaced as a unit. Look on eBay for replacements. They are usually available quite cheap and are rather straight forward to replace.
Jan 25, 2010 | Cobra 29 LTD CB Radio
Screen locked can 16 (model HX270S)
Hi there, I think you might have the priority channel switched on. Look for a button labeled PRI or somthing like that, press it once or if that fails press for 3 seconds.
Apr 24, 2009 | ICOM Informatique Icom IC-F11S 5W 2ch VHF...
I have a MTX8000 Handie-Talkie FM Radio It is a 16 channel radio
You're on scan mode but have no channel in scan list. You might have to go to scan PROGRAM mode and select the channel you want to scan then press a side button to put that channel in the scan list then will scan.
radcom907
Mar 15, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
More channles
You would need to have the radio reprogrammed using Motorola proprietary software, which is available to authorized Motorola dealers. The cost of reprogramming is typically between $25 and $40 in US dollars. GP328 radios can be programmed to have between 1 and 16 channels.
Oct 06, 2008 | Motorola Radio Communications
Standard Horizon Eclipse Fixed Mount Vhf Marine Radio Logo
Top Standard Horizon Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Standard Horizon Boating Expert? Answer questions, earn points and help others
